Handling 5xx Failures: Implementing a Dead Letter Queue for Genesys Cloud Webhooks
  • A Python application that subscribes to Genesys Cloud outbound events, processes them, and routes failures to a durable Dead Letter Queue (DLQ).
  • This solution uses the Genesys Cloud Event Streams API and AWS SQS as the underlying message broker.
  • The programming language covered is Python 3.10+ using the requests library and boto3 for AWS integration.
  • Genesys Cloud OAuth Client: A confidential client with the scope event:subscribe to register webhooks.
  • AWS Account: Access keys with permissions to create and send messages to SQS (sqs:CreateQueue, sqs:SendMessage).
  • Runtime: Python 3.10 or higher.
  • Dependencies:
    • requests (for HTTP calls to Genesys and local processing)
    • boto3 (for AWS SQS interaction)
    • pydantic (for payload validation)
    • fastapi and uvicorn (for the local webhook receiver endpoint)
Genesys Cloud uses OAuth 2.0 for API access. For webhook subscriptions, you need a valid access token generated via the Client Credentials flow. In a production environment, you should cache this token and refresh it before expiration.
import requests
from typing import Optional
class GenesysAuth:
    def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
        self.client_id = client_id
        self.base_url = base_url
        self.token_expiry: float = 0
        Retrieves a fresh OAuth2 access token if the current one is expired or missing.
        if self.token and time.time() < self.token_expiry - 60:
            return self.token
        url = f"{self.base_url}/oauth/token"
        data = {
            "scope": "event:subscribe"
        headers = {
        response = requests.post(url, data=data, headers=headers, auth=(self.client_id, self.client_secret))
        response.raise_for_status()
        token_data = response.json()
        self.token = token_data["access_token"]
        self.token_expiry = time.time() + token_data["expires_in"]
        return self.token
# Initialize Auth
# Replace with your actual credentials
auth_client = GenesysAuth(
    client_id="YOUR_CLIENT_ID",
    client_secret="YOUR_CLIENT_SECRET"
Step 1: Define the Webhook Receiver and Processing Logic
You need an HTTP endpoint to receive events from Genesys Cloud. When a 5xx error occurs during internal processing, you must not return a 5xx to Genesys immediately if you want to preserve the event for later retry via your DLQ. Instead, acknowledge receipt (200 OK) and push the raw payload to your DLQ.
This example uses FastAPI for the receiver and Pydantic for validation.
from fastapi import FastAPI, Request
from pydantic import BaseModel, ValidationError
import logging
import json
# Configure logging
app = FastAPI()
class GenesysEvent(BaseModel):
    Simplified model for a Genesys Cloud outbound event.
    Adjust fields based on the specific event type (e.g., Conversation, Interaction).
    eventType: str
    timestamp: str
    entity: dict
@app.post("/webhook/genesys")
async def handle_genesys_webhook(request: Request):
    Receives webhooks from Genesys Cloud.
    Returns 200 OK immediately to prevent Genesys from retrying the HTTP call.
    Offloads processing to a background task or queue.
        body = await request.json()
        event = GenesysEvent(**body)
        logger.info(f"Received event: {event.eventType} at {event.timestamp}")
        # Simulate business logic that might fail with 5xx
        process_event(event)
        return {"status": "success"}
    except ValidationError as e:
        # Malformed payload from Genesys (rare)
        logger.error(f"Validation error: {e}")
        return {"status": "error", "message": "Invalid payload"}, 400
        # Critical error: We still return 200 to Genesys to stop their retry loop
        # and push to DLQ instead.
        logger.error(f"Internal processing error: {e}")
        # In a real scenario, you would push the original request body to DLQ here.
        # For this tutorial, we assume the DLQ push happens in the process_event function
        # or a separate background worker.
        return {"status": "accepted_for_dlq"}, 200
def process_event(event: GenesysEvent):
    Simulates business logic. Raises an exception to trigger DLQ logic.
    if "fail" in event.eventType.lower():
        raise Exception("Simulated 5xx Internal Server Error")
    logger.info("Event processed successfully")
Step 2: Implement the Dead Letter Queue Pusher
When process_event fails, you must serialize the event and send it to an SQS queue. This queue acts as your DLQ. You will later have a consumer worker that attempts to reprocess these messages.
import boto3
from botocore.exceptions import ClientError
class DLQManager:
    def __init__(self, queue_url: str, region_name: str = "us-east-1"):
        self.sqs_client = boto3.client('sqs', region_name=region_name)
        self.queue_url = queue_url
    def push_to_dlq(self, event_payload: dict, error_message: str):
        Sends a failed event to the SQS Dead Letter Queue.
        message_body = {
            "original_event": event_payload,
            "error_context": {
                "message": str(error_message),
                "timestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime())
            response = self.sqs_client.send_message(
                QueueUrl=self.queue_url,
                MessageBody=json.dumps(message_body)
            logger.info(f"Message sent to DLQ. MessageId: {response['MessageId']}")
        except ClientError as e:
            logger.critical(f"Failed to send to DLQ: {e}")
            raise e
# Initialize DLQ Manager
# Replace with your actual SQS Queue URL
dlq_manager = DLQManager(queue_url="https://sqs.us-east-1.amazonaws.com/123456789012/genesys-failures-dlq")
Step 3: Integrate Error Handling into the Receiver
Modify the FastAPI endpoint to catch exceptions from process_event and delegate to the DLQManager.
            # Catch the 5xx-like error
            logger.error(f"Processing failed for event {event.timestamp}: {e}")
            # Push to DLQ for later retry
            dlq_manager.push_to_dlq(body, e)
            # Return 200 to Genesys to acknowledge receipt
        # Catch-all for unexpected errors (e.g., JSON decode error)
        logger.critical(f"Unexpected error: {e}")
        # Even here, we return 200 to stop Genesys retries, but log critically
Step 4: Configure the Genesys Cloud Webhook Subscription
You must register your endpoint with Genesys Cloud using the Event Streams API. This step uses the requests library to call the Genesys API directly.
def register_webhook(auth: GenesysAuth, endpoint_url: str):
    Registers a new webhook subscription in Genesys Cloud.
    token = auth.get_access_token()
    url = f"{auth.base_url}/api/v2/analytics/events/subscriptions"
    headers = {
    payload = {
        "name": "DLQ-Enabled-Webhook",
        "description": "Webhook with DLQ for 5xx failures",
        "type": "webhook",
        "events": [
                "name": "conversation",
                "type": "conversation"
        "configuration": {
            "endpoint": endpoint_url,
            "secret": "my-webhook-secret",  # Optional, for signature verification
            "retryPolicy": {
                "maxRetries": 3,
                "retryIntervalMs": 1000
    response = requests.post(url, json=payload, headers=headers)
    if response.status_code == 201:
        logger.info("Webhook registered successfully")
        return response.json()
    else:
        logger.error(f"Failed to register webhook: {response.status_code} {response.text}")
        raise Exception("Webhook registration failed")
# Example usage
# register_webhook(auth_client, "https://your-public-endpoint.com/webhook/genesys")
Below is the full, copy-pasteable Python script. It includes the FastAPI app, the DLQ manager, and the authentication logic. You will need to run this with uvicorn.
import os
import json
import logging
import requests
import boto3
# Configure logging
# --- Configuration ---
GENESYS_CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
GENESYS_CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
GENESYS_BASE_URL = os.getenv("GENESYS_BASE_URL", "https://api.mypurecloud.com")
SQS_QUEUE_URL = os.getenv("SQS_QUEUE_URL")
AWS_REGION = os.getenv("AWS_REGION", "us-east-1")
# --- Authentication ---
class GenesysAuth:
    def __init__(self, client_id: str, client_secret: str, base_url: str):
            return self.token
        data = {
        return self.token
auth_client = GenesysAuth(GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, GENESYS_BASE_URL)
# --- DLQ Manager ---
class DLQManager:
    def __init__(self, queue_url: str, region_name: str):
        message_body = {
            "error_context": {
            raise e
dlq_manager = DLQManager(SQS_QUEUE_URL, AWS_REGION)
# --- FastAPI App ---
app = FastAPI()
    eventType: str
    timestamp: str
    entity: dict
            logger.error(f"Processing failed: {e}")
# --- Registration Helper ---
def register_webhook(endpoint_url: str):
    token = auth_client.get_access_token()
    url = f"{auth_client.base_url}/api/v2/analytics/events/subscriptions"
    headers = {
    payload = {
        "name": "DLQ-Webhook",
        "type": "webhook",
        "events": [{"name": "conversation", "type": "conversation"}],
        "configuration": {
            "secret": "my-secret"
        print("Webhook registered")
    else:
        print(f"Failed: {response.text}")
    import uvicorn
    uvicorn.run(app, host="0.0.0.0", port=8000)
Error: 401 Unauthorized on Webhook Registration
  • Cause: The OAuth token is expired, invalid, or the client credentials are incorrect.
  • Fix: Verify your CLIENT_ID and CLIENT_SECRET. Ensure the token is refreshed before making the API call. Check the logs for response.raise_for_status() errors.
Error: SQS ClientError: AccessDenied
  • Cause: The AWS IAM role or user associated with the script does not have sqs:SendMessage permissions.
  • Fix: Update your IAM policy to include:
        "Effect": "Allow",
        "Action": "sqs:SendMessage",
        "Resource": "arn:aws:sqs:REGION:ACCOUNT-ID:QUEUE-NAME"
Error: Genesys Cloud Returns 429 Too Many Requests
  • Cause: Your webhook endpoint is responding too slowly, or you are making too many API calls to Genesys in a short period.
  • Fix: Ensure your FastAPI endpoint returns a response within 5 seconds. If you are processing data synchronously, offload it to a background task or queue immediately. For API calls, implement exponential backoff.
