Is there any chance that the IVR application will not be executed in case of numerous simultaneous calls to it? I am not using VTPs, I am in GVP 8. My Maximum Concurrent Sessions is set to no limit (blank) for the IVR profile being used.
How to handle such an issue? I can only think of a strategy modification when it exits from the red exit on the Play application block. Any ideas?
Of course it is possible. You have to specify how much “channels” have each LRG within GVP configuration. The default value from the RM is used, if this parameter on LRG level is empty.
You are right, I missed that… Thanks Kubig
Is there a way to monitor how many ports are being used?
You can find out this information in SIP server log, where you can find SIP NOTIFY messages, which contains currently count of used ports and total ports number. I do not know about another way and I mean that no other way exists yet.
Thank you very much!
You’re welcome
You should be able to monitor the number of active channels through EMS.
