After deploying an application to IIS 7 on Windows Server 2008, I have noted the error below in the Windows Event Viewer - this is causing a HTTP 500 Server Error in the MCP logs. Effectively it doesn’t seem to be able to find the DLLs in the “bin” folder; I cant find any reference in the Genesys documents that indicate this needs to be done as a separate process.
Exception information:
Exception type: HttpCompileException
Exception message: d:\eloyalty\gvp.applications\voxfer\include\getWebRequestData.aspx(21): error CS0246: The type or namespace name ‘JObject’ could not be found (are you missing a using directive or an assembly reference?)
Has anyone ever come across this before?
Lee
