GVP TTS/ASR Configuration
Hi there,
I’m trying to set up TTS and ASR in GVP 7.6 with Nuance Recognizer 9.0 and Nuance RealSpeak 4.5 and i can’t find any information on the correct configuration options.
Has anyone ever successfully deployed/configured this, and do you have the correct configuration options that are used.
Ben
The GVP deplyment guide says how to integrate them. On how to configure TTS MRCP or ASR should be a task of your saler…
