GVP Composer Parameters for Debugging
Hello, I want to simmulate an incomming call with parameters in my callflow,
According to Composer help this is possible:
http://genesyslab.info/wiki/index.php?title=Debugging_Voice_Applications#Creating_a_Debug_Launch_Configuration
“You can pass CTI Input variables in a Debugger call. Input variables in a callflow diagram can be initialized in a Debugger call using the Extra Parameters field in the Run / Debug Configurations > Application Settings tab. The Parameter names should match the “Input” variable defined in the Entry Block of the Callflow diagram.”
What it doesn´t say is HOW to write the parameters keys and values, can anyone help me out?
Thanks!
Nevermind, I figured it out
key1=value1;key2=value2
​works
:wink: good work, you can see those too in MCP logs BTW.
And the separator is “;” (semi-colon)
PS: I have answered same question on G-community, guess your post/question :slight_smile:
Yes Kubig it was me, thanks, I did figure it out by the time you posted it but it´s still useful for corroboration and I do appreciate the help, and also thank for the info cavagnaro.
One more thing, if a parameter must contain ; character the hay to write it is to encode it as %3B
for example
user_data=loginId%3BclientNumber;ucid=123
would produce 2 variables:
user_data=loginId;clientNumber
ucid=123
