GVP and Avaya S8720
Anyone using GVP with an Avaya S8720?
How have you got it connected TDM/E1 or SIP/H323? Any recommendations?
Cheers,
Ben
Hi Ben,
I have experience with using GVP with Avaya S8700/8710 via SIP. The main recommendation is - find someone experienced with configuration of Avaya SES (SIP Enablement Services). It will save you a lot of time :slight_smile: as most of the configuration has to be done on Avaya side. Of course, I assume that you have experience with VoIP (SIP, RTP etc.) and it won’t be your first GVP installation :wink:
If you have any questions then feel free to ask… I will try to remember how we did it
Hi Rene,
Thanks for the reply. I’ve already got GVP installed and connected to a Meridian via E1 but that switch is being replaced…
I know I can use E1 with the Avaya but if there are benefits to SES (and it isn’t a real pain to do) then will look into going that route.
Cheers
