GVP 7.6 install issue.
Hi all,
Simple GVP 7.6 install
Windows 2003 Standard server SP2 updated, jre6 installed, telera user is in the admin group
Core: 7.6.450.06 - install ok
EMPS: 7.6.450.08 - install ok
Dispenser: 7.6.000.11 - install ok
LDAP is running, telnet working, applications can write the directory while installing (Admin/password)
Watchdog is running (not in safe mode)
In a browser I can see that all processes running (Sca, Netmgt etc.), but when I click the “EMPS server”, it says: EMPSServer is not running
Logs and gvp.ini are attached.
Any idea?
Bandorka
Can’t see any attachment :frowning:
Can you paste Watchdog log content here?
Sure, upload was failed. Here it is:
[2011/03/08 15:36:57.953] A6C <<< DebugLog Start, pid=2276, ModuleVersions=WatchDog.exe: 7.6.450.06;cnace54.dll: 5.4;CnInet.dll: 7.6.450.06;Logger.dll: 7.6.450.06;HuntListMgr.dll: 7.6.450.06;SSLEAY32.dll: ;LIBEAY32.dll: ;, Hostname=eti-cocivr1, HostIP=10.133.186.4, maxsize=262144 >>>
[2011/03/08 15:36:57.953] A6C <<< Adding log flags >>> :0x3
[2011/03/08 15:37:05.140] A6C SCAServer.cpp:120 C=77:L=1:U=0 SCALookupServer >> STANDALONE mode lookup.
[2011/03/08 15:37:05.140] A6C SCAServer.cpp:159 C=77:L=1:U=0 SCALookupServer >> LocalMode [1].
[2011/03/08 15:37:05.140] A6C SCAIniGen.cpp:2097 C=77:L=1:U=0 seedINI >> LocalMode [1], Source INI [C:\GVP\CN\config\gvp.ini].
[2011/03/08 15:37:05.203] A6C <<< DebugLog destructing >>>
[2011/03/08 15:37:05.203] A6C <<< DebugLog Start, pid=2276, ModuleVersions=WatchDog.exe: 7.6.450.06;cnace54.dll: 5.4;CnInet.dll: 7.6.450.06;Logger.dll: 7.6.450.06;HuntListMgr.dll: 7.6.450.06;SSLEAY32.dll: ;LIBEAY32.dll: ;WatchDogPS.dll: 7.6.450.06;, Hostname=eti-cocivr1, HostIP=10.133.186.4, maxsize=262144 >>>
[2011/03/08 15:37:05.203] A6C <<< Adding log flags >>> :0x3
[2011/03/08 15:37:05.968] A6C CWatchDog.cpp:5706 C=11:L=2:U=0 Sent trap [id = 101, desc = CallNet Services Started: EMPS]
[2011/03/08 15:37:09.265] DC CWatchDog.cpp:3239 C=11:L=2:U=650 Web notification received: query string [notifyprocess=WatchDog&action=ping], other info [RemoteAddr=10.133.186.4&PortNum=9810]
[2011/03/08 15:38:12.015] B90 <<< Adding log flags >>> !
:!,:0x1F
[2011/03/08 15:38:14.406] CE0 CWatchDog.cpp:5949 C=11:L=4:U=0 getDataElement: requested attrib id [1026, wdAPTable], num indices [0], index value [0]
[2011/03/08 15:38:14.421] CE0 IMgtData.h:213 C=1:L=8:U=6 IMgtData::serviceRequest requested MIB [wdAPTable], fetched MIB [wdAPTable], time taken [15 msec]
[2011/03/08 15:38:14.421] CE0 INetMgtDataImpl.h:252 C=18:L=4:U=0 ELSE pRetList[x-1]->clear()
[2011/03/08 15:38:16.078] C08 CWatchDog.cpp:4744 C=11:L=8:U=0 Checking all processes
[2011/03/08 15:38:16.078] C08 CWatchDog.cpp:5092 C=11:L=8:U=0 Checking process [NetMgt, pid = 420]
[2011/03/08 15:38:16.078] C08 ThreadPoolEx.cpp:309 C=1:L=8:U=4 Threadpool [CWatchDog.cpp:1109] : Queuing client data [0x15ead48]
[2011/03/08 15:38:16.078] C08 ThreadPoolEx.cpp:677 C=1:L=8:U=4 Threadpool [CWatchDog.cpp:1109] : New worker thread not started because there are 2 idle threads [active = 1, total = 3] to handle 1 pending orders
[2011/03/08 15:38:16.078] A4C ThreadPoolEx.cpp:778 C=1:L=16:U=4 Threadpool [CWatchDog.cpp:1109] : item spent [0 msec] in queue; enqueue snapshot [current threads:3, active threads:1, pending items:1]; dequeue snapshot [current threads:3, active threads:2, pending items:0]
[2011/03/08 15:38:16.078] A4C ThreadPoolEx.cpp:524 C=1:L=16:U=4 Threadpool [CWatchDog.cpp:1109] : Processing client data [0x15ead48]
[2011/03/08 15:38:16.078] A4C CWatchDog.cpp:5386 C=11:L=8:U=651 Ping thread started
[2011/03/08 15:38:16.078] A4C CWatchDog.cpp:5439 C=11:L=8:U=651 Ping 0x15ead48: Process [NetMgt] ping returned 0 after 0 msec. Last ping time stamp [Tue Mar 08 15:38:16 2011
[2011/03/08 15:38:16.078] C08 CWatchDog.cpp:5092 C=11:L=8:U=0 Checking process [SPS, pid = 1192]
[2011/03/08 15:38:16.078] A4C CWatchDog.cpp:5439 C=11:L=8:U=651 Ping 0x15ead48: Process [SPS] ping returned 0 after 0 msec. Last ping time stamp [Tue Mar 08 15:38:16 2011
[2011/03/08 15:38:16.078] C08 CWatchDog.cpp:5092 C=11:L=8:U=0 Checking process [Scheduler, pid = 2076]
[2011/03/08 15:38:16.078] A4C CWatchDog.cpp:5439 C=11:L=8:U=651 Ping 0x15ead48: Process [Scheduler] ping returned 0 after 0 msec. Last ping time stamp [Tue Mar 08 15:38:16 2011
[2011/03/08 15:38:16.078] C08 CWatchDog.cpp:5092 C=11:L=8:U=0 Checking process [PageCollector, pid = 2596]
[2011/03/08 15:38:16.078] A4C CWatchDog.cpp:5439 C=11:L=8:U=651 Ping 0x15ead48: Process [PageCollector] ping returned 0 after 0 msec. Last ping time stamp [Tue Mar 08 15:38:16 2011
[2011/03/08 15:38:16.078] C08 CWatchDog.cpp:5092 C=11:L=8:U=0 Checking process [SCA, pid = 2616]
[2011/03/08 15:38:16.078] A4C CWatchDog.cpp:5439 C=11:L=8:U=651 Ping 0x15ead48: Process [SCA] ping returned 0 after 0 msec. Last ping time stamp [Tue Mar 08 15:38:16 2011
[2011/03/08 15:38:16.078] C08 CWatchDog.cpp:4733 C=11:L=8:U=0 Waiting 5000 msec on shutdown event
[2011/03/08 15:38:19.984] B90 CWatchDog.cpp:2993 C=11:L=8:U=650 CWatchDog::ProcessNotificationEx entry
[2011/03/08 15:38:19.984] B90 CWatchDog.cpp:3018 C=11:L=8:U=650 Rcvd query string [notifyProcess=watchdog&action=shutdown&process=watchdog&shutdowntype=graceful]
[2011/03/08 15:38:19.984] B90 ThreadPoolEx.cpp:309 C=1:L=8:U=4 Threadpool [CWatchDog.cpp:1109] : Queuing client data [0x15f2a70]
[2011/03/08 15:38:19.984] B90 ThreadPoolEx.cpp:677 C=1:L=8:U=4 Threadpool [CWatchDog.cpp:1109] : New worker thread not started because there are 2 idle threads [active = 1, total = 3] to handle 1 pending orders
[2011/03/08 15:38:19.984] A4C ThreadPoolEx.cpp:778 C=1:L=16:U=4 Threadpool [CWatchDog.cpp:1109] : item spent [0 msec] in queue; enqueue snapshot [current threads:3, active threads:1, pending items:1]; dequeue snapshot [current threads:3, active threads:2, pending items:0]
[2011/03/08 15:38:19.984] A4C ThreadPoolEx.cpp:524 C=1:L=16:U=4 Threadpool [CWatchDog.cpp:1109] : Processing client data [0x15f2a70]
[2011/03/08 15:38:19.984] A4C CWatchDog.cpp:3239 C=11:L=2:U=650 Web notification received: query string [notifyProcess=watchdog&action=shutdown&process=watchdog&shutdowntype=graceful], other info
[2011/03/08 15:38:19.984] A4C CWatchDog.cpp:1862 C=11:L=8:U=0 CWatchDog::terminateProcess entering; process name [watchdog], pid [0], shutdown type [GRACEFUL]
[2011/03/08 15:38:19.984] A4C CWatchDog.cpp:1962 C=11:L=4:U=0 Notifying process [name = WatchDog, pid = 2276] of GRACEFUL shutdown
[2011/03/08 15:38:19.984] A4C CWatchDog.cpp:2075 C=11:L=8:U=0 CWatchDog::terminateProcess exiting
[2011/03/08 15:38:19.984] C08 CWatchDog.cpp:5706 C=11:L=2:U=0 Sent trap [id = 102, desc = CallNet Services (EMPS) shutdown (type = GRACEFUL) initiated]
[2011/03/08 15:38:19.984] C08 CWatchDog.cpp:4776 C=11:L=2:U=0 CallNet Services (EMPS) shutdown (type = GRACEFUL) initiated
[2011/03/08 15:38:19.984] C08 CWatchDog.cpp:4883 C=11:L=4:U=0 Shutdown: Process [SCA] is being notified to shutdown
[2011/03/08 15:38:21.093] C08 CWatchDog.cpp:4883 C=11:L=4:U=0 Shutdown: Process [SPS] is being notified to shutdown
[2011/03/08 15:38:22.203] C08 CWatchDog.cpp:4883 C=11:L=4:U=0 Shutdown: Process [Scheduler] is being notified to shutdown
[2011/03/08 15:38:23.312] C08 CWatchDog.cpp:4883 C=11:L=4:U=0 Shutdown: Process [PageCollector] is being notified to shutdown
[2011/03/08 15:38:28.421] C08 CWatchDog.cpp:4883 C=11:L=4:U=0 Shutdown: Process [NetMgt] is being notified to shutdown
[2011/03/08 15:38:29.531] C08 CWatchDog.cpp:5029 C=11:L=8:U=0 Shutdown: fn exit
[2011/03/08 15:38:30.031] A6C <<< DebugLog destructing >>>
[2011/03/08 15:38:31.062] 176C <<< DebugLog Start, pid=5984, ModuleVersions=WatchDog.exe: 7.6.450.06;cnace54.dll: 5.4;CnInet.dll: 7.6.450.06;Logger.dll: 7.6.450.06;HuntListMgr.dll: 7.6.450.06;SSLEAY32.dll: ;LIBEAY32.dll: ;, Hostname=eti-cocivr1, HostIP=10.133.186.4, maxsize=262144 >>>
[2011/03/08 15:38:31.062] 176C <<< Adding log flags >>> *:0x3
[2011/03/08 15:38:38.234] 176C SCAServer.cpp:120 C=77:L=1:U=0 SCALookupServer >> STANDALONE mode lookup.
[2011/03/08 15:38:38.234] 176C SCAServer.cpp:159 C=77:L=1:U=0 SCALookupServer >> LocalMode [1].
[2011/03/08 15:38:38.234] 176C SCAIniGen.cpp:2097 C=77:L=1:U=0 seedINI >> LocalMode [1], Source INI [C:\GVP\CN\config\gvp.ini].
[2011/03/08 15:38:38.296] 176C <<< DebugLog destructing >>>
[2011/03/08 15:38:38.296] 176C <<< DebugLog Start, pid=5984, ModuleVersions=WatchDog.exe: 7.6.450.06;cnace54.dll: 5.4;CnInet.dll: 7.6.450.06;Logger.dll: 7.6.450.06;HuntListMgr.dll: 7.6.450.06;SSLEAY32.dll: ;LIBEAY32.dll: ;WatchDogPS.dll: 7.6.450.06;, Hostname=eti-cocivr1, HostIP=10.133.186.4, maxsize=262144 >>>
[2011/03/08 15:38:38.296] 176C <<< Adding log flags >>> *:0x3
[2011/03/08 15:38:38.875] 176C CWatchDog.cpp:5706 C=11:L=2:U=0 Sent trap [id = 101, desc = CallNet Services Started: EMPS]
[2011/03/08 15:46:34.921] 1234 CWatchDog.cpp:3239 C=11:L=2:U=650 Web notification received: query string [notifyProcess=watchdog&action=shutdown&process=watchdog&shutdowntype=graceful], other info
[2011/03/08 15:46:34.921] 17F8 CWatchDog.cpp:5706 C=11:L=2:U=0 Sent trap [id = 102, desc = CallNet Services (EMPS) shutdown (type = GRACEFUL) initiated]
[2011/03/08 15:46:34.921] 17F8 CWatchDog.cpp:4776 C=11:L=2:U=0 CallNet Services (EMPS) shutdown (type = GRACEFUL) initiated
[2011/03/08 15:46:44.421] 176C <<< DebugLog destructing >>>
[2011/03/08 15:46:44.984] 153C <<< DebugLog Start, pid=5452, ModuleVersions=WatchDog.exe: 7.6.450.06;cnace54.dll: 5.4;CnInet.dll: 7.6.450.06;Logger.dll: 7.6.450.06;HuntListMgr.dll: 7.6.450.06;SSLEAY32.dll: ;LIBEAY32.dll: ;, Hostname=eti-cocivr1, HostIP=10.133.186.4, maxsize=262144 >>>
[2011/03/08 15:46:44.984] 153C <<< Adding log flags >>> *:0x3
[2011/03/08 15:46:52.171] 153C SCAServer.cpp:120 C=77:L=1:U=0 SCALookupServer >> STANDALONE mode lookup.
[2011/03/08 15:46:52.171] 153C SCAServer.cpp:159 C=77:L=1:U=0 SCALookupServer >> LocalMode [1].
[2011/03/08 15:46:52.171] 153C SCAIniGen.cpp:2097 C=77:L=1:U=0 seedINI >> LocalMode [1], Source INI [C:\GVP\CN\config\gvp.ini].
[2011/03/08 15:46:52.250] 153C <<< DebugLog destructing >>>
[2011/03/08 15:46:52.250] 153C <<< DebugLog Start, pid=5452, ModuleVersions=WatchDog.exe: 7.6.450.06;cnace54.dll: 5.4;CnInet.dll: 7.6.450.06;Logger.dll: 7.6.450.06;HuntListMgr.dll: 7.6.450.06;SSLEAY32.dll: ;LIBEAY32.dll: ;WatchDogPS.dll: 7.6.450.06;, Hostname=eti-cocivr1, HostIP=10.133.186.4, maxsize=262144 >>>
[2011/03/08 15:46:52.250] 153C <<< Adding log flags >>> *:0x3
[2011/03/08 15:46:52.828] 153C CWatchDog.cpp:5706 C=11:L=2:U=0 Sent trap [id = 101, desc = CallNet Services Started: EMPS]
[2011/03/08 16:05:11.125] A44 CWatchDog.cpp:3239 C=11:L=2:U=650 Web notification received: query string [notifyprocess=WatchDog&action=ping], other info [RemoteAddr=10.133.186.4&PortNum=9810]
[2011/03/08 16:07:23.046] 15C8 CWatchDog.cpp:5706 C=11:L=2:U=0 Sent trap [id = 102, desc = CallNet Services (EMPS) shutdown (type = UNGRACEFUL) initiated]
[2011/03/08 16:07:23.046] 15C8 CWatchDog.cpp:4776 C=11:L=2:U=0 CallNet Services (EMPS) shutdown (type = UNGRACEFUL) initiated
[2011/03/08 16:07:32.546] 153C <<< DebugLog destructing >>>
[2011/03/08 16:09:55.000] 87C <<< DebugLog Start, pid=2120, ModuleVersions=WatchDog.exe: 7.6.450.06;cnace54.dll: 5.4;CnInet.dll: 7.6.450.06;Logger.dll: 7.6.450.06;HuntListMgr.dll: 7.6.450.06;SSLEAY32.dll: ;LIBEAY32.dll: ;, Hostname=eti-cocivr1, HostIP=10.133.186.4, maxsize=262144 >>>
[2011/03/08 16:09:55.015] 87C <<< Adding log flags >>> *:0x3
[2011/03/08 16:12:54.859] 87C SCAServer.cpp:120 C=77:L=1:U=0 SCALookupServer >> STANDALONE mode lookup.
[2011/03/08 16:12:54.875] 87C SCAServer.cpp:159 C=77:L=1:U=0 SCALookupServer >> LocalMode [1].
[2011/03/08 16:12:54.875] 87C SCAIniGen.cpp:2097 C=77:L=1:U=0 seedINI >> LocalMode [1], Source INI [C:\GVP\CN\config\gvp.ini].
[2011/03/08 16:12:54.968] 87C <<< DebugLog destructing >>>
[2011/03/08 16:12:54.968] 87C <<< DebugLog Start, pid=2120, ModuleVersions=WatchDog.exe: 7.6.450.06;cnace54.dll: 5.4;CnInet.dll: 7.6.450.06;Logger.dll: 7.6.450.06;HuntListMgr.dll: 7.6.450.06;SSLEAY32.dll: ;LIBEAY32.dll: ;WatchDogPS.dll: 7.6.450.06;, Hostname=eti-cocivr1, HostIP=10.133.186.4, maxsize=262144 >>>
[2011/03/08 16:12:54.968] 87C <<< Adding log flags >>> *:0x3
[2011/03/08 16:12:56.781] 87C CWatchDog.cpp:5706 C=11:L=2:U=0 Sent trap [id = 101, desc = CallNet Services Started: EMPS]
[2011/03/08 16:16:50.406] C6C CWatchDog.cpp:3239 C=11:L=2:U=650 Web notification received: query string [notifyprocess=WatchDog&action=ping], other info [RemoteAddr=10.133.186.4&PortNum=9810]
[2011/03/08 16:17:32.531] C6C CWatchDog.cpp:3239 C=11:L=2:U=650 Web notification received: query string [notifyprocess=WatchDog&action=ping], other info [RemoteAddr=10.133.186.4&PortNum=9810]
Any idea?
Or need some more information?
The only weird messages I’m seeing are:
Did you changed the localconfig parameter in gvp.ini?
No it has the original settings as you can see in the watchdog section from gvp.ini:
[WatchDog]
LdapBindPwd=admin123
LdapPort=389
LdapRootDIT=o=genesys
LdapServer=eti-cocivr1
LdapTeleraType=CORE;EMPS;
LdapUser=cn=Manager
Processes=NetMgt;PageCollector;Scheduler;SPS;SCA
ProvServer=eti-cocivr1
ProvUser=Admin
SCACurrentObject=WatchDog
SCAGenerated=1
SCAParentObject=cn=eti-cocivr1,ou=Servers,o=genesys
backupconfigurl=
clsid={8FE4A8FD-AA7A-11D2-8B07-00105AA452F4}
configurl=
exe=WatchDog
gvptenancy=0
iniretrievaltimeout=30000
localconfig=0
logfile=WatchDog.log
loglevels=*:0x3
logmaxsize=262144
logulids=
maxnoresponsepings=5
maxsoapserverthread=200
memorythresholdpercentage=90
restartonhang=1
serverversion=7.6.45
shutdownonfailure=0
soapport=8001
system=EMPS
systemcheckfrequencysecs=300
templatelink=cn=WatchDog,cn=$version$,cn=Core
I fight with his issue for three days, and I have absolutely no idea what’s wrong. But I guess it’s something trivial, but no and no and no :frowning:
thanks for the answer
Why you dont just reinstall all gvp. Remember do it locally, remote desktop IS NOT supported.
Antivirus MUST NOT be installed.
The only message you get is EMPS Server not running?
Have you try the EMPS URL? http://eti-cocivr1:9810/spm? or http://10.133.186.4:9810/spm?
Is this a single box deployment?
Yes it is a single box env. The url is working, but say no emps, but able to login. the emps tree is empty.
we think maybe an iis issue?
Seems more an LDAP issue, is the ldap up???
Sure, up and running. Can open via ldapbrowser app.
Solved: The IIS install overwrite some files, so I should reinstall SP2 again, and voila.
grrrhhh :slight_smile:
Thanks for the answers
Bandorka
ISS? After GVP??? Bad installation process then. ISS is first.
No Cav, IIS before GVP AND before SP2. The issue was that IIS deployed after SP2…
Bandorka
what deploy do you mean??
So, the admin gay deployed windoz+sp2, but didn’t deploy iis. Then I deployed iis, and then gvp. But provisoning server didn’t want to start. This was the issue. And the solution: reinstall sp2, after install iis. And gvp started to work.
So, we had to reinstall windows sp2, after install iis6 on windows. After that GVP started to operate.
admin gay? lol, we dont care about his sexual preference lol
Thanks for the info but still is strange
good you solve it :slight_smile:
Grrrhh :-)) Cav: GUY
