Just noticed that the custom UI drops the WebSocket connection immediately after sending a message via POST to /api/v2/conversations/messages/{conversationId}/communications/{communicationId}/messages. The handshake on wss://webchat.{org}.mypurecloud.com/api/v2/conversations/messaging/external/contacts is successful, and I receive the initial greeting. However, upon sending a JSON payload with to and text fields, the server returns a 1000 Close code. No error message is broadcast on the socket. Is the conversationId in the POST URL required to match the session ID from the handshake, or should I be using a different endpoint for outbound messages in a pure Guest API implementation?
Oh, this is a known issue with the guest token expiry. the websocket drops because the token used for the handshake expires before the message is processed, triggering a 1000 close. you need to refresh the token by sending a message to the conversation with a new expires_in claim before sending.
Yep, this is a known issue with the guest token expiry. the websocket drops because the token used for the handshake expires before the message is processed, triggering a 1000 close. you need to refresh the token by sending a message with a new expires_in claim before sending.
To fix this easily, this is to implement a proactive token renewal mechanism within your WebSocket handler. The 1000 close code often indicates that the server-side validation of the guest token fails due to expiry or scope mismatch during the message commit. You should not wait for the error. Instead, monitor the token’s expires_in value. When it drops below a threshold, send a message to refresh the session context before attempting the actual message send.
In Rust, you can manage this with a background tokio::time::interval that checks the token status. Ensure your WebSocket client re-authenticates using the new token if the connection is dropped unexpectedly.
let token_expiry = Duration::from_secs(token.expires_in - 30);
tokio::time::sleep(token_expiry).await;
// Trigger token refresh logic here before sending message
Note: Ensure your API client handles the 401 Unauthorized response gracefully to avoid infinite loops during the refresh process.
The problem here is relying on client-side timing for token renewal in a serverless environment. SvelteKit server routes are stateless and ephemeral. If you try to manage expires_in logic in the browser, race conditions will kill your WebSocket. The suggestion above about refreshing via POST is technically correct but misses the architectural reality of a lightweight widget. You need a proxy.
- Create a SvelteKit
+server.jsroute for/api/genesys/refresh. - Use the
@genesys/cloudSDK in the server environment to validate the current token. - If
expires_in < 300, callPOST /api/v2/oauth/tokenwith your service account credentials to get a fresh access token. - Return this new token to the client.
- The client should only send the WebSocket handshake when it holds a valid token.
This avoids exposing your client secret in the browser. Do not try to parse JWTs in the client. It is insecure and brittle.
// src/routes/api/genesys/refresh/+server.js
import { json } from '@sveltejs/kit';
import { PlatformClient } from '@genesys/cloud';
export async function POST() {
const client = PlatformClient.create();
// Assume server-side OAuth2 flow is already configured in env
const token = await client.auth.getAccessToken();
if (!token || token.expires_in < 300) {
// Trigger silent refresh via SDK
await client.auth.login('oauth2', {
client_id: process.env.GC_CLIENT_ID,
client_secret: process.env.GC_CLIENT_SECRET
return json({ token: client.auth.getAccessToken().access_token });
Stop fighting the browser’s network stack. Push the auth logic to the server. It is cleaner and more reliable.
