group of queues name inside template formula
yes you can. i explained how a few posts back. it’s similar to custom agent state.
Had to increase the “by using VBScript”…you can the way you did it, but as by using simple VBScript functions to get the DN name and Alias is not an option right now.
Your method does work and solves your issue, ugly in a developer eye but works fine on a user POV.
Cheers
