Hi there,
could you help me to solve one problem..I have tested Gplus Adapter for Microsoft Dynamics CRM 4.0 version 7.6.100.01 on WinServ 2008 (IIS 7), SQL 2008 and faced with the problem: According to guide i have to create a new virtual directory to Microsoft Dynamics CRM > ISV and i have done all stages but can’t start application from …\ISV\GenesysGplusAdapter" Web Site . Always i get error "404 Error in application /ISV/GenesysGplusAdapter’ with trying to go to /ISV/GenesysGplusAdapter/default.aspx.. I tried to make something in IIS, but all time i got a fail.
There is a part of logs:
2011-08-23 17:12:48,849 [1] INFO Genesyslab.GPlus.MsCrm4.Web.Global [(null)] - Application_Start: appBase=/ISV/GenesysGplusAdapter/
Product Version: 7.6.100.01
Adapter Version: 7.6.100.9967
AIL Version: 2.1.0.9967
CLR version: 2.0.50727.3053
OS version: Microsoft Windows NT 6.0.6001 Service Pack 1
Processor Count: 1
Pointer Size: 4
Machine name: SQL2008
User: Administrator
Domain: CRM
Code base: file:///C:/GCTI/Gplus Adapter for Microsoft/WebRoot/bin/Genesyslab.GPlus.MsCrm4.DLL
2011-08-23 17:12:49,309 [1] INFO Aria.Ail.Connection.GenConfigConnection [(null)] - Will connect to config server with clientType: ThirdPartyApp and userName gplus_adapter_mscrm_user
2011-08-23 17:12:49,847 [10] INFO Aria.Ail.Connection.GenConnectionManager [(null)] - Connecting to Config-Server: cfg:2020 (appName=Gplus_CRM) (primary: cfg:2020 (appName=Gplus_CRM))
2011-08-23 17:12:52,614 [10] INFO Aria.Ail.Connection.GenConfigConnection [PSDK-ConfigServer] - Session usage is not enforced.
2011-08-23 17:12:52,620 [10] INFO Aria.Ail.Connection.GenConfigConnection [PSDK-ConfigServer] - Trying obtain server protocol version…
2011-08-23 17:12:52,839 [10] INFO Aria.Ail.Connection.GenConfigConnection [PSDK-ConfigServer] - Server Protocol version <CfgProtocol 5.1.3.75> is obtained.
2011-08-23 17:12:52,840 [10] INFO Aria.Ail.Connection.GenConfigConnection [PSDK-ConfigServer] - Trying to register client…
2011-08-23 17:12:53,032 [10] INFO Aria.Ail.Connection.GenConfigConnection [PSDK-ConfigServer] - Client is registered, sessionId: ‘90’.
2011-08-23 17:12:53,033 [10] INFO Aria.Ail.Connection.GenConfigConnection [PSDK-ConfigServer] - Client protocol version: CfgProtocol 5.1.3.70
2011-08-23 17:12:53,033 [10] INFO Aria.Ail.Connection.GenConfigConnection [PSDK-ConfigServer] - Server protocol version: CfgProtocol 5.1.3.75
2011-08-23 17:12:53,033 [10] INFO Aria.Ail.Connection.GenConfigConnection [PSDK-ConfigServer] - Bound protocol version: CfgProtocol 5.1.3.70
2011-08-23 17:12:53,034 [10] INFO Aria.Ail.Connection.GenConfigConnection [PSDK-ConfigServer] - LastUpdateId (20937) is set.
2011-08-23 17:12:53,035 [10] INFO Aria.Ail.Connection.GenConfigConnection [PSDK-ConfigServer] - Loading the Schema from the resources …
2011-08-23 17:12:53,788 [10] INFO Aria.Ail.Connection.GenConfigConnection [PSDK-ConfigServer] - Schema loading done
2011-08-23 17:12:55,103 [10] INFO Aria.Ail.Connection.GenConnectionManager [(null)] - Connected to Config-Server: cfg:2020 (appName=Gplus_CRM)
2011-08-23 17:12:58,631 [Ail-Internal] WARN Aria.Util.BlockingHolder1[[Aria.Ail.Model.PApplication, Aria.Ail, Version=2.1.0.9967, Culture=neutral, PublicKeyToken=1b5ac55cd0473ac9]] [Config-Server] - Exception being thrown: Required CME object attribute CfgServerInfo/timeout/@value was not found. в Aria.Util.ThreadUtil.GetCurrentThreadStackTrace() в Aria.Util.BlockingHolder1.ThrowException(Exception exception)
в Aria.Ail.Config.CfgObjectRepository1.<>c__DisplayClassc.<GetObjectByDbid>b__9(Exception ex) в Aria.Ail.Config.CfgObjectRepository1.<>c__DisplayClassc.b__a(XPathNavigator nav)
в Aria.Ail.Config.CfgRetriever.<>c__DisplayClass3.b__1(IEnumerable1 navs) в Aria.Ail.Config.CfgRetriever.<>c__DisplayClass8.<GetObjects>b__6(IMessage message) в Aria.Ail.Connection.GenFuture1.HandleMessage(IMessage message)
в Aria.Ail.Connection.AbstractGenConnection2.<>c__DisplayClass7.<>c__DisplayClassb.<Send>b__3(IMessage responseMessage) в Aria.Ail.Util.GenMessageDispatcher.DispatchToReferenceIdListeners(IMessage message) в Aria.Ail.Util.GenMessageDispatcher.Dispatch(IMessage message) в Aria.Ail.Connection.AbstractGenConnection2.Dispatch(IMessageDispatcher dispatcher, IMessage msg)
в Aria.Ail.Connection.GenConfigConnection.<.ctor>b__0(IMessage msg)
в Aria.Ail.Connection.GenConnectionManager.<>c__DisplayClass5.b__1()
в Aria.Util.ScheduledInvoker.Task.RunTask()
в Aria.Util.ImmediateInvoker.Invoke(VoidMethod method)
в Aria.Util.ScheduledInvoker.Run()
в System.Threading.ThreadHelper.ThreadStart_Context(Object state)
в System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
в System.Threading.ThreadHelper.ThreadStart()
and this error continues and in the end all connections were closing…
2011-08-23 17:12:59,178 [Ail-Internal] WARN Aria.Util.BlockingHolder1[[Aria.Ail.Model.PServerApplication, Aria.Ail, Version=2.1.0.9967, Culture=neutral, PublicKeyToken=1b5ac55cd0473ac9]] [Config-Server] - Exception being thrown: Required CME object attribute CfgServerInfo/timeout/@value was not found. в Aria.Util.ThreadUtil.GetCurrentThreadStackTrace() в Aria.Util.BlockingHolder1.ThrowException(Exception exception)
в Aria.Util.BlockingHolderListener1.RaiseException(Exception raisedException) в Aria.Util.BlockingHolder1.ThrowException(Exception exception)
2011-08-23 17:12:59,343 [15] INFO Aria.Ail.Connection.GenConnectionManager [(null)] - Connecting to Interaction Server: GAD01:7002 (appName=Gplus_CRM) (primary: GAD01:7002 (appName=Gplus_CRM))
2011-08-23 17:12:59,718 [14] INFO Aria.Ail.Connection.GenConnectionManager [(null)] - Connected to T-Server TServer_SIP: IVR01:13000
2011-08-23 17:12:59,723 [SelectorThread] INFO Aria.Ail.Connection.TServerConnection [PSDK-TServer_SIP] - Primary connected
2011-08-23 17:13:00,082 [SelectorThread] INFO Aria.Ail.Connection.TServerConnection [PSDK-TServer_SIP] - Backup connected
2011-08-23 17:13:00,085 [15] INFO Aria.Ail.Connection.GenConnectionManager [(null)] - Connected to Interaction Server: GAD01:7002 (appName=Gplus_CRM)
2011-08-23 17:13:40,989 [5] WARN Genesyslab.GPlus.MsCrm4.Web.Global [(null)] - Received ‘stop’ notification from web server. (immediate: False)
2011-08-23 17:13:41,002 [14] INFO Aria.Ail.Connection.GenConnectionManager [(null)] - T-Server TServer_SIP connection shutting down
2011-08-23 17:13:41,002 [14] INFO Aria.Ail.Connection.GenConnectionManager [(null)] - Closing connection
2011-08-23 17:13:41,178 [15] INFO Aria.Ail.Connection.GenConnectionManager [(null)] - Interaction Server connection shutting down
2011-08-23 17:13:41,179 [15] INFO Aria.Ail.Connection.GenConnectionManager [(null)] - Closing connection
2011-08-23 17:13:41,250 [10] INFO Aria.Ail.Connection.GenConnectionManager [(null)] - Config-Server connection shutting down
2011-08-23 17:13:41,250 [10] INFO Aria.Ail.Connection.GenConnectionManager [(null)] - Closing connection
2011-08-23 17:14:11,369 [5] WARN Genesyslab.GPlus.MsCrm4.Web.Global [(null)] - Received ‘stop’ notification from web server. (immediate: True)
Help plz, thanks in advance…
