Go SDK 400 on analytics widget POST despite schema validation
payload := analytics.Widget{
 Title: "Queue Perf Matrix",
 Type: "matrix",
 Metrics: []analytics.Metric{{ID: "acw", Aggregation: "sum"}, {ID: "talk", Aggregation: "average"}},
 Visualization: analytics.Visualization{Rows: []string{"queueId"}, Cols: []string{"date"}},
genesyscloud-go SDK hits a 400 Bad Request on the dashboard widget creation endpoint even though the widget schema validates locally. We’ve got data source checks passing yet the atomic POST fails at format verification before the auto data fetch fires, and the payload sits well under the 12KB limit.
  • Go 1.21
  • SDK v1.78.0
  • Environment: us1
Skip the SDK struct and push a raw JSON payload through the REST client. The ADMIN UI completely ignores the widget if the DASHBOARD:MANAGE SCOPE isn’t attached to the service account, and you’ll hit that 400 wall every single time. You’ll need to explicitly set the VISUALIZATION ROWS and COLS as flat string arrays instead of the SDK’s default pointer types, plus the endpoint expects a blank ID field on creation.
client := platformclientv2.NewPlatformClient()
client.Config.OAuthScopes = []string{"dashboard:manage", "analytics:query"}
body := []byte(`{"title":"Queue Perf Matrix","type":"matrix","metrics":[{"id":"acw","aggregation":"sum"},{"id":"talk","aggregation":"average"}],"visualization":{"rows":["queueId"],"cols":["date"]},"id":""}`)
res, _ := client.RestClient.Post("/api/v2/analytics/dashboards/"+dashboardId+"/widgets", "application/json", body)
Honestly, the SDK just mangles the type assertion. Drives me up the wall every time. Check the response headers before you panic about the schema.
Problem
The Go SDK struct serializes those nested visualization arrays incorrectly when the client marshals it to JSON. You end up sending null pointers instead of flat string lists, which trips the validation layer on the dashboard service. Switching to a direct HTTP POST in your pipeline usually bypasses the SDK quirks entirely. You don’t need to fight the serializer when a raw JSON body works perfectly fine. Even the official platformclientv2 Python client struggles with this if you force it through the typed models instead of passing a dict.
Code
Here is how I handle widget provisioning in my CI runners. Python requests handles the encoding cleanly, and you can wrap it in a retry loop for those transient 429s. Make sure the service account has dashboard:manage and analytics:read attached, otherwise the auth layer rejects it before the payload even hits the queue.
import requests
headers = {
 "Authorization": f"Bearer {access_token}",
 "Accept": "application/json"
payload = {
 "title": "Queue Perf Matrix",
 "type": "matrix",
 "metrics": [
 {"id": "acw", "aggregation": "sum"},
 {"id": "talk", "aggregation": "average"}
 "visualization": {
 "rows": ["queueId"],
 "cols": ["date"]
response = requests.post(
 "https://api.mypurecloud.com/api/v2/analytics/reporting/settings/dashboards/query",
 headers=headers,
 json=payload
print(response.status_code, response.text)
Error
If you forget to strip the id field before creation, the platform throws a 409 Conflict instead of the 400 you’re seeing. Missing metrics or using an unsupported aggregation like median on acw will also break the request. Always check the X-RateLimit-Reset header before spinning up another chunk. The API throttles hard on bulk widget pushes and you’ll burn through your token window fast.
Question
Are you handling exponential backoff in your deployment script, or just hammering the endpoint until it accepts the payload?
Cause: The Go SDK struct serialization is busted for nested visualization arrays. When you instantiate the widget object, the Visualization fields default to nil pointers. The marshaller sends null instead of empty arrays. The analytics endpoint rejects null on required fields. You’re hitting the validation gate because the payload shape doesn’t match the strict schema. This is why the gateway resolver fails when batching these requests through DataLoader.
Solution: Drop the SDK struct for the creation payload. The gateway handles batching, but the initial POST needs a clean JSON blob.
  1. Build a raw map structure.
  2. Marshal that map manually.
  3. Pass the resulting byte slice to the REST client.
widgetPayload := map[string]interface{}{
 "type": "matrix",
 "metrics": []map[string]string{
 {"id": "talk", "aggregation": "average"},
 "visualization": map[string]interface{}{
 "rows": []string{"queueId"},
 "cols": []string{"date"},
body, _ := json.Marshal(widgetPayload)
// Pass body to client.Post with Content-Type application/json
This bypasses the pointer logic entirely. The API gets exactly what it expects. No more 400s from the serializer.
The raw JSON workaround resolves the serialization fault. Defining Visualization.Rows and Visualization.Cols as explicit strings bypasses the SDK null pointer. This setup maintains Frankfurt data residency per GDPR Article 32. The request doesn’t trigger the validation gate anymore. Endpoint remains stable.
