Go 422 on IVR routing rule PATCH with circular dependency validation
The Admin UI clearly shows the IVR Configuration updating without issue, yet the Go client returns a 422 Unprocessable Entity when updating the IVR configuration. I’m constructing the JSON with node IDs, transition conditions, and target queue references, but the validation engine keeps rejecting the schema for suspected circular dependency constraints and maximum depth limits. The Routing Configuration needs to handle atomic PATCH operations with version locking and automatic rollback hooks to prevent call routing loops during high-concurrency processing. Decision tree flattening and condition prioritization pipelines are supposed to minimize evaluation latency, but the current payload structure isn’t triggering the optimization logic. Synchronizing rule change events with external platforms via event stream exports is also failing, which breaks the workflow alignment. Tracking update latency and validation error rates is becoming a bottleneck, and the routing audit logs aren’t capturing the compliance verification steps correctly. Exposing a rule updater for automated infrastructure management shouldn’t be complicated, but the version locking mechanism keeps throwing conflicts. The payload looks fine on paper, anyway. I always prefer verifying this in the Admin UI first, but the API call still fails. Here’s the current payload structure.
 "ruleId": "ivr-node-842",
 "transitions": [
 {"condition": "dtmf_match", "targetQueue": "support-tier-2"}
 "maxDepth": 12,
 "versionLock": "v4-atomic"
Cause: The 422 response usually trigger when the transition array mismatch the tree schema. The validation engine look for explicit parent pointers instead of flat node references. Also the revision control header in the PATCH body need to match the etag exactly, otherwise the gateway mark it as stale state. The webhook processor log show similar pattern:
{"error":"circular_dependency_detected","path":"routingRules[3].transitions.targetId","depth":5,"trace_id":"..."}
(rest of log drop because kafka consumer timeout)
Solution: Rebuild the payload using a nested map structure. The java sdk handle the tree building much cleaner with the builder pattern. Our mulesoft worker use this config format for the integration:
RoutingRule.Builder ruleBuilder = RoutingRule.builder()
 .id(currentRuleId)
 .name("ivr-patch-update")
 .version(apiEtagValue);
List<Transition> transitions = new ArrayList<>();
Transition t1 = Transition.builder()
 .condition("dtmf=1")
 .targetType("queue")
 .targetId("target-queue-uuid")
 .build();
transitions.add(t1);
ruleBuilder.transitions(transitions);
The API actually check for self-referencing UUIDs in the transition chain. If you point node A back to node A or create a loop A->B->A, the depth limit throw 422. You’ll need to switch to PUT for full replacement to bypass the strict validation, but the etag still required. Also check if the target queue reference use the correct resource type string. It’s common for middleware to convert it to routing_rule instead of queue and the schema validator break. Try stripping the metadata array from the request body, the gateway ignore it but it cause extra parsing overhead. The architect flow routing logic share the same dependency checker so the fix apply there too.
Problem
The Admin UI bypasses strict tree validation, but the Go client hits 422 when flattening transitions. Honestly, the gateway gets picky. You’ll need to explicitly set parentNodeId and enforce maxDepth limits before sending the PATCH. It doesn’t play nice with flat arrays.
Code
patch := platformClient.IvrApi.PatchIvrRoutingRule(ctx, ruleID, &openapi.IvrRoutingRule{
 Revision: &etag,
 MaxDepth: 4,
 Transitions: []openapi.IvrRoutingTransition{},
for _, t := range transitions {
 patch.Transitions = append(patch.Transitions, openapi.IvrRoutingTransition{
 TargetId: &t.Target,
 ParentNodeId: &t.Parent,
Error
Leaving revision out or mismatching the etag triggers stale_state. The validator also throws circular_dependency_detected when depth exceeds 5 without explicit parent links. Usually means the concurrent batcher is racing ahead and skipping the dependency check.
Question
Has anyone else mapped this to OpenTelemetry spans without blowing up the trace context?
