GIS disconnect problem
I am having difficulties with keeping connection alive between GIS and GIS client. I am using GIS 7.1.xxxx and also using a session timer that automatically re
egisters every 45 seconds. Yet, there still seems to be a problem from time to time when I try to update something using GIS. The problem usually happens if I idle for a few minutes before issuing a command.
my sessionTimeout is set to 3600 so it should give me plenty of time.
Does anyone have any ideas as to why this would happen?
i had the same problem and I’ve overcame it by using a timer send a trivial request to the server CfgPerson [DBID = 1] which will never return any thing and at the same time keeps my connection open all the time
I have also tried timer, but it did not cut it for me I used to have a similar problem so what I did was:
  1. recreate connection to GIS every time user submits something
  2. try to recreate connection after catching an exception try{}catch{}finally{}
I hope it helped!
Guys,
I’m new to gis and am devloping an app to talk to GIS. The problem is that I error out every time I try and recive notiifcation of the stat. It’s more than likely my code. But I’ll post for you to review and even send me some sample code
Dim class1 As New GISStatisticClass
stat_value = “Error”
class1.SubscribeToStatistic(theHost, Session, StatServer, Tenant, objecttype, objectname, statistic)
Dim subscriptions1 As New StatServiceService.statisticSubscriptions
Dim subscription1 As New StatServiceService.statisticSubscription
subscription1.scope = “all”
subscription1.statisticId = “statref1”
    Dim subscriptionArray1(1) As StatServiceService.statisticSubscription
    ' ReDim subscriptionArray1(1)
    subscriptionArray1(0) = subscription1 '.scope = "all" ' .SetValue(subscription1, 0)
    ' subscriptionArray1(0).statisticId = "statref1"
    subscriptions1.statisticSubscription = subscriptionArray1
    Dim notification1 As New StatServiceService.notification
    notification1.mode = StatServiceService.notificationMode.Polling
    notification1.timeout = "15"
    Dim response1 As StatServiceService.retrieveSubscribedStatisticsResponse
    response1 = class1.port_stat.retrieveSubscribedStatistics(subscriptions1, notification1)
    Dim value1 As StatServiceService.statisticValue
    value1 = response1.statisticValues.GetValue(0)
    lstat_value = CType(value1.eventValues.GetValue(0), StatServiceService.eventValue).LValue
    stat_value = Convert.ToString(lstat_value)
    Console.WriteLine(("Retrieved statistic value = " & stat_value))
    class1.unsubscribe()
End Sub
