GIM DB not being populated
My GIM DB is not being populated. All jobs end as successful but there is no data in the G_CALL table even though there is a lot of info in the Icon DB.
In the GIM logs I can’t see any errors except a lot of these:
2015-03-16 12:06:09,003 INFO  ecp-1-6860   30000 TransformUD$FillStgUdhVoice.runStep (TSERVER) - enter
2015-03-16 12:06:09,003 DEBUG ecp-1-6860   35000 SQLUtils.executeUpdate (if exists (select 1 from sysobjects where id = object_id('dbo.STG_UDH_V') and type = 'U') DROP TABLE dbo.STG_UDH_V,294318208,null) - enter
2015-03-16 12:06:09,003 DEBUG ecp-1-6809   35000 SQLSTATE=S0001; error code=16954; Executing SQL directly; no cursor.
2015-03-16 12:06:09,003 DEBUG ecp-1-6809   35000 SQLUtils.queryAndScan - exit(elapsed 0 ms) returning 1
Could this be my problem? Should I talk to my DB engineer for this?
Regards,
Mihai
Can you post your jdbc string for the GIM DAP?
Check on what stored procedure the process terminated and try to run this query directly from SQL studio
I didn’t start new topic , I have the same issue on my ICON_CORE when I run transformation Job.
2022-04-28T15:40:33,300 DEBUG ecp-176 35000 SQLUtils.executeUpdate (DAP_GIM@5[d][15],IF OBJECT_ID(‘dbo.TMP_MERGE’,‘U’) IS NOT NULL DROP TABLE dbo.TMP_MERGE,null) - enter
2022-04-28T15:40:33,300 DEBUG ecp-176 35000 SQLUtils.executeUpdate - exit(elapsed 0 ms) returning 0
2022-04-28T15:40:33,300 DEBUG ecp-176 35000 COMMIT: DAP_GIM@5[d][15]; called by com.genesyslab.gim.etl.jobs.extract.MergeMoveStep.run(MergeMoveStep.java:341)
2022-04-28T15:40:33,300 INFO ecp-176 30000 MergeMove: .insertIRs4ConCalls2TmpMerge () - enter
2022-04-28T15:40:33,300 DEBUG ecp-176 35000 SQLUtils.queryAndScan (DAP_GIM@5[d][15],SELECT IRID,ROOTIRID INTO dbo.TMP_MERGE FROM (SELECT (u.c1_ROOTIRID) IRID,(u.c2_ROOTIRID) ROOTIRID,(ROW_NUMBER() OVER(PARTITION BY u.c1_ROOTIRID ORDER BY u.c2_ROOTIRID ASC)) XX_ROW_NUMBER FROM ((SELECT (c1.ROOTIRID) IRID,(c1.ROOTIRID) c1_ROOTIRID,(c2.ROOTIRID) c2_ROOTIRID FROM dbo.G_CALL c1 INNER HASH JOIN dbo.G_CALL c2 ON c1.MERGECALLID = c2.CALLID) UNION (SELECT (c1.ROOTIRID) IRID,(c1.ROOTIRID) c1_ROOTIRID,(c2.ROOTIRID) c2_ROOTIRID FROM dbo.G_CALL c1 INNER HASH JOIN dbo.G_CALL c2 ON c1.PARENTCALLID = c2.CALLID)) u WHERE u.c1_ROOTIRID <> u.c2_ROOTIRID) T WHERE XX_ROW_NUMBER = 1; SELECT @@ROWCOUNT) - enter
2022-04-28T15:40:33,316 DEBUG ecp-176 35000 SQLSTATE=S0001; error code=16954; Executing SQL directly; no cursor.
2022-04-28T15:40:33,316 DEBUG ecp-176 35000 SQLSTATE=S0000; error code=8625; Warning: The join order has been enforced because a local join hint is used.
same error pn indexes
2022-04-28T15:42:07,238 DEBUG ecp-196 35000 SQLUtils.executeUpdate (DAP_GIM@5[2b][14],IF NOT EXISTS (SELECT 1 FROM sysindexes WHERE id = object_id(‘TMP_UP_UDE_FT_223’) AND name = ‘PK_TMP_UP_UDE_FT_223’ AND indid > 0 AND indid < 255) CREATE UNIQUE NONCLUSTERED INDEX PK_TMP_UP_UDE_FT_223 ON TMP_UP_UDE_FT_223(INTERACTION_RESOURCE_ID ASC),null) - enter
2022-04-28T15:42:07,254 DEBUG ecp-196 35000 SQLUtils.executeUpdate - exit(elapsed 16 ms) returning 0
2022-04-28T15:42:07,254 DEBUG ecp-196 35000 COMMIT: DAP_GIM@5[2b][14]; called by com.genesyslab.gim.etl.jobs.transform.core.TransformUD.createIndexOnTmpTable(TransformUD.java:3589)
2022-04-28T15:42:07,254 INFO ecp-196 30000 TransformUD$LoadFact.populateTmpUdeTable - exit(elapsed 219 ms) returning 0
2022-04-28T15:42:07,254 INFO ecp-196 30000 TransformUD$LoadFact.runStep - exit(elapsed 766 ms) returning 0
2022-04-28T15:42:07,254 DEBUG ecp-196 35000 COMMIT: DAP_GIM@5[2b][14]; called by com.genesyslab.gim.etl.server.CallableTransactionStep.runTransaction(CallableTransactionStep.java:66)
2022-04-28T15:42:07,254 DEBUG ecp-196 35000 CLOSE: DAP_GIM@5[2b][14]; called by com.genesyslab.gim.etl.util.Disposer.dispose(Disposer.java:36)
2022-04-28T15:42:07,269 DEBUG ecp-17b 35000 SQLSTATE=S0001; error code=16954; Executing SQL directly; no cursor.
Br,
