GetExternalContactAction returning empty results for phone lookup
Hey folks,
Stuck on a weird one with the GetExternalContactAction in Architect. We’re trying to pull customer data from a simple REST API before the call hits the queue. The endpoint works fine in Postman, but inside Architect, the result set is always empty.
Here’s the JSON for the action:
 "actionType": "GetExternalContactAction",
 "settings": {
 "uri": "https://api.internal.com/lookup/phone",
 "method": "GET",
 "queryParams": {
 "number": "{{contact.phone_number}}"
 "resultMapping": {
 "firstName": "$.data.firstName",
 "lastName": "$.data.lastName"
The trace shows the request goes out, and we get a 200 OK. The response body looks like this:
 "success": true,
 "data": {
 "firstName": "Jane",
 "lastName": "Doe"
But the contact attributes stay blank. I’ve checked the data type of contact.phone_number and it’s a string. Is the JSON path syntax wrong, or is there a specific format for the phone number in the query param?
Tried swapping {{contact.phone_number}} with a hardcoded E.164 string just to test, same result. Empty set.
Anyone see this before?
