Get Attached data after we re-login WDE(after a crash) but while call is ON stil
Mighty Genesys Wizards,
I got a special request to check a WDE interaction handling scenario and will need your guidance on the same. where we should be able to Get Attached data after we re-login WDE(Say WDE application crashed) but the call is still ON?
if I havent explained myself clearly the Scenario is :
1.Say an agent is handling a call, suddenly his WDE login crashes.
2.He Login-in again to WDE while still on call..
3.Once logged in is it possible to still retrieve the Attached call info?
In my code I have written the GetAllAttachedData inside the below event , but if I try to replicate the scenario , I am not looking at Attached data ( after re-login) which I was dealing with before my WDE session crashed.
  private void interactionManager_InteractionEvent(object sender, EventArgs<IInteraction> e)
Please suggest if this is feasible or correct me if am doing it wrong.
Try the RequestQueryAddress for the DN which the user is logged in
Thanks for the response hsujdik , I will give it a try and post back here.
