Apply hits a wall. 422 Unprocessable Entity. Provider is doing jack all here. Claims schema is invalid. Pasting the exact JSON into Architect UI works fine. It’s the properties block structure. Terraform might be flattening the keys or sending an empty array.
Logs show the request payload looks different than what the UI sends. Type field gets stripped somewhere in serialization.
Provider: genesys/genesyscloud v1.12.0
Terraform: 1.7.4
Workspace: staging
GC Org: us-east-1
Tried commenting out required. Still dies. Tried genesyscloud_dataaction with a simple type = string schema. That applies. Breaks as soon as properties is added.
PureCloudPlatformClientV2 rejects the map conversion because the API layer validates the schema field as a raw JSON string, not a nested object, and the provider’s internal serialization drops the additionalProperties flag in versions prior to 1.2.5. You’re seeing that 422 because the gateway parses the resulting string and finds a malformed properties block when the map gets flattened incorrectly during the POST request. Use a heredoc to bypass the provider’s map handling entirely so the JSON hits the endpoint exactly as defined without any key reordering. This matches the EventBridge rule expectations too since the webhook payload won’t trigger if the schema validation fails on the backend, and you’ll waste hours debugging why the Lambda never fires when the data action is actually broken. Stop fighting the Terraform provider quirks and pass the raw string to avoid the silent failures that happen when jsonencode strips out null fields that the schema spec requires. The API docs explicitly state the schema must be a string representation, so trust the raw input over the provider’s helper functions. I’ve seen this same 422 pop up on architect flow imports too when the JSON structure isn’t exact, so lock the format down now before it breaks your CI pipeline. The genesyscloud_resource_api is the only way to get consistent results if the dataaction resource keeps choking on simple types. PureCloudPlatformClientV2 also throws a hissy fit if you mix integer and string types in the required array, so double check that sku is actually the only required field you need. The EventBridge event bus will drop the message silently if the schema doesn’t match the incoming payload shape, so getting this right prevents downstream Lambda timeouts. Just paste the raw JSON and move on.
Heredoc works, but jsonencode keeps type safety inside the module. The API throws 422 because the contract expects a string blob for the schema definition. PureCloudPlatformClientV2 validation rejects the map structure outright. Pact provider verification fails if the consumer sends a map and the provider expects a string field. You’ll hit the same wall in the test suite. Keep additionalProperties set to false. Schema validation lets garbage through otherwise. the earlier post’s suggestion is the way to go. Just make sure the required array matches the consumer pact exactly. The qty field needs to be optional in the contract if it’s not in that list. The 422 response usually includes a message field pointing to the schema validation error. Check the logs. The properties block needs to be a serialized JSON string, not a nested object. Terraform handles the conversion, but the API is strict. If the contract test sends the wrong type, the verification step crashes. You can reproduce the error by mocking the provider response with a map type instead of a string. The sku description helps in the UI, but the type definition is what matters for the validation logic. jsonencode handles the escaping automatically. Heredoc is fine for static configs, but dynamic properties break it. Stick with the function call. It’s safer for CI pipelines.
