Genesys WDE connector could not make connection to SIP Softphone
Hi All expert here,
  I am trying to use genesys sip softphone Ver 9.0.017.04 instead of embedded sipendpoint. I am using VPN back to genesys system. Ive configured the required setting according to deployment guide. When I luch sip softphone and wde, sip softphone waiting for agent login, wde prompts can not connect to SIP endpoint. From WDE log , I can see it's trying to connect to SIP client but logs say client actively refuse it. For SIP endpoint I am using HTTP with default port 8000. I can see from my pc resource monitor that port 8000 is listening. For interaction-worksapce setting sipendpoint.uri using default (localhost or 127.0.0.1):8000. WDE is trying to connect to my vpn ip assigned 10.2.2.2 and port 8000. Can anyone advise how can I fix this issue to make wde work with sip softphone?    Thanks All.....
21-10-30 00:34:55.556 [ 39] INFO ation.HttpRestClient - CreateTcpClient() – host: 10.2.2.2 – port: 8000
21-10-30 00:34:57.606 [ 39] DEBUG ation.HttpRestClient - CreateTcpClient() – SocketException: System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 10.2.2.2:8000
at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port)
at Genesyslab.Desktop.Modules.SIPEndpointCommunication.Channels.HTTP.HttpRestClient.CreateTcpClient()
21-10-30 00:34:57.606 [ 39] DEBUG ation.HttpRestClient - Request() – ExceptionNo connection could be made because the target machine actively refused it 10.2.2.2:8000
21-10-30 00:34:57.606 [ 39] ERROR ndpointCommunication - The IW SIP Endpoint is not available at this time. Exception while communicating with Endpoint:
at Genesyslab.Desktop.Modules.SIPEndpointCommunication.Channels.HTTP.HttpRestClient.Request(IHttpRequest request)
at Genesyslab.Desktop.Modules.SIPEndpointCommunication.Channels.HTTP.HttpServiceSIPEndpoint.RequestHTTPService(String method, String service, String reqMethod, String content)
at Genesyslab.Desktop.Modules.SIPEndpointCommunication.Channels.HTTP.HttpServiceSIPEndpoint.set_Options(Dictionary`2 value)
at Genesyslab.Desktop.Modules.SIPEndpointCommunication.SIPEndpoint.ConfigureAndStartEndpoint()
WDE is no longer using SIP Endpoint, it is using an external SIP device, SIP Softphone in this case, so registration should be only at the Softphone.
Remove the Role permission to call SIP Endpoint (WDE plugin) as you won’t be using it anymore.
Then let WDE use the SIP Softphone DN just by registering on the Place containing that DN.
Hi cavagnaro,
Thanks for your advice. do you mean "SIP Endpoint- can use Embedded SIP Endpoint" under IWSIPTasks? After uncheck, I am not seeing WDE look for http client and port  but WDE still not connect to SIP softphone. Softphone status showing same waiting for agent login. Please advise if you have any idea....Thanks
Now you have 2 different softwares, SIP Softphone has no clue of WDE and WDE has no clue on SIP Softphone, Bria, SIP Hardphone whatsoever
What is expected is that at Tlib level you see the DN register and succeeds. That is it.
Hi cavagnaro,
Thanks again. I tried with 3rd party Microsip and it can register and working. But for SIP softphone,whatever I alter the config and try, it doesn't seem registered. The config is quite simple on microsip. Can advise how can I put same config on SIP softphone to get registered.
MicroSIp setting example as follow;
SIP Server : stc.greennet.com
SIP Proxy : 10.10.3.129:5160
Username : 4006
Domain : stc.greennet.com
SIP Softphone
on proxy, I just put domain name value, the rest of config as default
I would remove all the STUN/TURN references, bad idea to put invalid values when they are still valid for the app
Does your SIP Server receive any REGISTER attempt?
Hi cavagnaro,
When I try to register as standalone, softphone status show registered but not able to make any call to/from. When register as connector mode, status just showing waiting for agent login and nothing happened after agent login, can make call to/from.
I saw Register request message on SIP server log and Unauthorized as well.
REGISTER sip:stc.greennet.com SIP/2.0
Via: SIP/2.0/UDP 10.10.3.129:5080;branch=z9hG4bKac1902982255
Max-Forwards: 69
From: “Genesys Softphone” sip:4006@STC;tag=1c1234304587
To: sip:4006@STC
Call-ID: 1065851586111202111159@10.10.3.129
CSeq: 1 REGISTER
Contact: sip:4006@10.10.3.129:5080;ac-feu=985-10-182-7
Expires: 1800
User-Agent: Mediant VE SBC/v.7.40A.100.021
Content-Length: 0
01:12:00.865: Unable to resolve number for DN:4006
01:12:00.865: trunk ip addr 10.10.3.129
01:12:00.865: gateway ‘Gateway’ associated with address ‘10.10.3.129’
01:12:00.865: Assocaited transport for the device [1058] changed from [:0:0] to [10.10.3.129:5080:1]
01:12:00.869: TRNMNGR: internal domain stc.greennet.com
01:12:00.869: SIPTS: handle registration event 0
01:12:00.869: Sending [0,UDP] 556 bytes to 10.10.3.129:5080 >>>>>
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 10.10.3.129:5080;branch=z9hG4bKac1902982255;received=10.10.3.129
To: sip:4006@STC;tag=00FF43BC-9A69-4F6E-ACEC-665E741C7377-357596
CSeq: 1 REGISTER
WWW-Authenticate: Digest realm=“SIPSwitch_STC”,qop=“auth”,algorithm=MD5,nonce=“3A3A7894-2420-47B3-A3F2-2DCF3B05DEB6”,opaque=“5349505377697463685f535443”
Expires: 1800
Contact: sip:4006@10.10.3.129:5080;ac-feu=985-10-182-7;expires=1800
Content-Length: 0
01:12:00.869: $-NET:SIP::0:375
01:12:00.912: $+NET:SIP::0:0
01:12:00.912: SIPTR: Received [0,UDP] 648 bytes from 10.0.3.109:5080 <<<<<
Via: SIP/2.0/UDP 10.10.3.129:5080;branch=z9hG4bKac518006396
Max-Forwards: 69
To: sip:4006@STC
CSeq: 2 REGISTER
Authorization: Digest username=“4006”,realm=“SIPSwitch_STC”,uri=“”,nonce=“3A3A7894-2420-47B3-A3F2-2DCF3B05DEB6”,cnonce=“00004bf4”,nc=00000001,qop=auth,algorithm=MD5,opaque=“5349505377697463685f535443”,response=“21b8137fa531ba5131525fc06735ece4”
Expires: 1800
Content-Length: 0
01:12:00.912: Unable to resolve number for DN:4006
01:12:00.912: trunk ip addr 10.10.3.129
01:12:00.912: gateway ‘Gateway’ associated with address ‘10.10.3.129’
01:12:00.912: Assocaited transport for the device [1059] changed from [:0:0] to [10.10.3.129:5080:1]
01:12:00.912: TRNMNGR: internal domain stc.greennet.com
01:12:00.912: SIPTS: handle registration event 0
01:12:00.912: SIPTS_Auth::AuthenticateSipRequestNew internal
01:12:00.912: {Authorization Failed:363} Wrong Checksum
01:12:00.912: Sending [0,UDP] 555 bytes to 10.10.3.129:5080 >>>>>
Via: SIP/2.0/UDP 10.10.3.129:5080;branch=z9hG4bKac518006396;received=10.10.3.129
To: sip:4006@STC;tag=00FF43BC-9A69-4F6E-ACEC-665E741C7377-357597
CSeq: 2 REGISTER
WWW-Authenticate: Digest realm=“SIPSwitch_STC”,qop=“auth”,algorithm=MD5,nonce=“59359315-CEA5-4A82-A447-C67738C5F91F”,opaque=“5349505377697463685f535443”
Expires: 1800
Content-Length: 0
Your DN has a password? 1st Unauthorized is expected in that case so the endpoint sends then the password configured for that user.
Have you followed this doc?
https://docs.genesys.com/Documentation/SP/latest/dep/SoftphoneWDE
But how does Genesys softphone get the SIP registration info from WDE? Genesys softphone is not listening on the ip and port.
What do you mean? It doesn’t matter. Sip server sends the sip request to the DN associated to the agent login, the place you selected when login into wde.
Enviado de meu SM-S918B usando o Tapatalk
