Is it possible to configure the Edge BYOC registration logic to handle token expiration gracefully without dropping active SIP sessions?
We are seeing a 403 Forbidden error in the Edge logs immediately after the OAuth token refresh cycle completes. The SIP trunks successfully register, but subsequent INVITEs fail with a 403 from the Genesys Cloud core. This happens consistently every hour when the access token rotates.
Environment details:
Genesys Cloud Version: 2024-04
Edge Version: 2.1.5
ServiceNow Integration: Data Actions pushing ticket updates via REST API
The webhook payload for the Data Action is under 10KB, so size limits are not the issue. The error appears to be a race condition between the token refresh and the SIP signaling. We have verified the client credentials in ServiceNow match the Edge configuration.
Cross-referencing the Edge documentation suggests the registration should persist across token rotations, but our logs show a hard reset. Has anyone encountered similar behavior with BYOC trunks? We need to maintain session continuity for our call center agents.
Make sure you verify the SIP credential rotation policy in your BYOC trunk configuration, as the standard OAuth refresh cycle often outpaces the SIP registrar’s cache invalidation window. The suggestion above regarding force_reauth_on_403 is technically correct for immediate mitigation, but it treats the symptom rather than the root cause of the registration desynchronization.
Cause:
The 403 Forbidden error occurs because the Genesys Cloud core validates the SIP INVITE against the current active OAuth token. When the token rotates, the Edge SIP proxy still holds the previous token in its local session cache. The proxy attempts to route the INVITE with the stale token, resulting in a 403 from the core. This is exacerbated in multi-region BYOC setups where clock skew between the Edge node and the Cloud authentication service can create a brief window of invalid credentials.
Solution:
Implement a proactive token refresh buffer and ensure the SIP registration is tied to the token lifecycle. Update your BYOC trunk configuration to include a token_refresh_buffer_ms setting that triggers re-registration before the token expires. Additionally, configure the Edge SIP proxy to clear its credential cache on successful token refresh.
This configuration ensures that the SIP proxy proactively updates its credentials before the token expires, preventing the 403 error from occurring in the first place. Monitoring the SIP registration logs for 200 OK responses after each token refresh will confirm that the new configuration is working as expected.
This is actually a known issue… The SIP proxy requires explicit re-authentication headers after OAuth rotation. Ensure force_reauth_on_403 is true in your config. See KB-9921: Edge BYOC Token Refresh for the exact JSON schema required.
