Genesys Composer Problem
Hi Guys,
I have successfully installed composer and want to build a sample strategy for routing to check routing is done and orchestration server is running or not successfully.
While trying to make a new .NET composer project, i am receiving the error that " Unable to find systems.security.dll, check your WSE and .NET installed paths.
I checked in preferences and gave the correct paths of .NET aspnet_compiler and WSE Microsoft.Web.Service3.dll and this system.security file is also present in the folder. Please need guidance on this. Thanks
What version exactly of Composer and Eclipse are you using?
Version is 8.1
Exactly version, please :slight_smile: Composer is only in release 8.1
I am using latest version together with .Net projects and all is working as expected, but I remember that I have encountered similiar issue with older versions. So, suggest to upgrade.
Thanks for the help :slight_smile:
8.1.003.64 is the exact version
should I upgrade the .NET framework or composer?
Composer :slight_smile: You are using very old and very “bug” version:-) Currently, the composer is just a plug-in to the Eclipse. So, as first download latest Eclipse (I think it is Luna at this moment) and after that download and deploy the Composer plug-in. In other hand, is good to have latest version of .Net - the 3.5 version as minimum. The WSE should be installed separately.
Oh okay thanks alot :))
But is latest composer compatible with older genesys components?
Can you please share the download link of the latest one, or suggest any other place where i can get the media? thanks again
Only through the Genesys web sites, where you must have an account.
I have installed composer 8.1.301.02 as a plugin on Eclipse Juno 4.2.
However i am not able to connect to configuration server. My framework components are version 8.5.
I get the following error
Error connecting to configuration server
“Error registering. Code 41; Client’s encoding doesn’t match with current server mode”
Can anyone provide a light into this.
Thanks in Advance
It seems like encoding mismatch - check what encoding set using your confserv and Eclipse - they must match.
Encoding in confserv and Composer is UTF-8..
Have you allowed the “allow-mixed-encoding” option or not?
No. It is default value “False”.
Should i change it to “True”?
I think, it should help in your scenario
Should this be done in the configuration file or the options?
I am using confserv 8.5
I prefer using the configuration file which should lead to update the options in cfg database.
Thanks..
It did work after changing the configuration file and restarting confserv. :slight_smile:
Great :slight_smile: Would be interest find out if the Composer/Eclipse was really used UTF-8 encoding char set for communication with confserv.
