Genesys campaign and virtual z devices
I’m using predictive mode for my campaign
I have the following setup :
[i]- Alcatel 4400 pbx
  • Genesys TServer 8.1[/i]
We use virtual z device to dial calls.
The virtual z dialing devices have been configured with the following values :
Procedure:
Configuring virtual Z dialing devices in the PBX
without VAD
Purpose: To create dialing devices in the PBX for use with the Predictive
Dialing feature where there is no VAD on the PBX.
Start of procedure
1. Navigate to mgr/Users/Create.
2. Set the following values for the device:
• Directory Number—<VZ Number>
• Shelf/Board/Equipment Address—255/255/255
A virtual device is not given a physical address in the PBX
• Set Type—ANALOG
Specifies virtual devices of type analog.
• Ghost Z—True
Specifies that this is a virtual device.
• Ghost Z Feature—None
• VAD use for Ghost Z—False
The virtual z devices has configured like this (Genesys) :
Procedure:
Configuring devices for predictive dialing in
Configuration Layer
Start of procedure
1. Set the following values for the device:
• Type—Extension
• Number—<Virtual Device Number>
• Switch-specific type—4 (on Advanced tab of DN Properties window)
Is it possible to use a range of virtual z device for a campaign ?
For example :
  • Campaign1 use the virtual z devices 3200 to 3205
  • Campaign2 use the virtual z devices 3206 to 3210
Thank all
No, as OCS will send the request to TServer to perform a dial and TServer will do with any free ghostZ it may find.
You would have to create two OCS apps and by security let each one have access to specific GhostZ resources.
Why do you need this?
