Stuck on generating a long-lived API token for our CI/CD pipeline using the Genesys Cloud Java SDK. I am trying to automate the deployment process but the standard OAuth2 client credentials flow keeps returning short-lived access tokens that expire before the pipeline completes. The documentation for the Platform API states: “Access tokens are valid for 3600 seconds.” However, I need a token that persists for the entire duration of the build and deploy cycle, which can take up to 30 minutes. I am using the following code snippet to configure the client:
When I attempt to refresh the token using apiClient.refreshAccessToken(), I get a 401 Unauthorized error with the message: “Invalid grant type.” The docs mention that for CI/CD pipelines, you should use a service account with an API token, but I am not sure how to generate this token programmatically via the Java SDK. Is there a specific endpoint or method I should be calling to generate a long-lived token? I have tried using the /api/v2/oauth/token endpoint with grant_type=client_credentials, but it still returns a short-lived token. Any help would be appreciated.
TL;DR: Use a background thread or a scheduled cron job to refresh the token before expiry. The Java SDK does not support extending the 3600-second limit natively.
I usually solve this by implementing a token refresh loop in my serverless entry point. Since you are using the Java SDK, you cannot simply request a “longer” token. The OAuth2 spec and Genesys Cloud enforcement hard-limit access tokens to one hour. For a 30-minute CI/CD pipeline, you are likely hitting the boundary if your pipeline has idle waits or retry loops.
The robust pattern is to cache the AccessToken object and check its expiresAt timestamp before every API call. If the remaining time is less than 60 seconds, trigger a refresh using the oauthClient with the client_credentials grant type. Here is how I structure this in a utility class for my AWS Lambda wrappers:
In your CI/CD script, initialize this wrapper once at the start of the job. Ensure your IAM role or secret manager exposes the clientId and clientSecret securely. Do not store these in plain text environment variables. If your pipeline exceeds 30 minutes significantly, consider breaking it into smaller stages to reduce token management overhead. This approach prevents the 401 Unauthorized errors that kill deployments mid-stream.
Make sure you implement an automatic refresh mechanism rather than requesting longer-lived tokens. The 3600-second limit is hard-coded. Use the SDK’s built-in token cache with a background thread to fetch new credentials before expiry.
Warning: Hard-coding secrets in CI/CD variables is a security risk. Rotate them via HashiCorp Vault.
