Generating Genesys Cloud LLM Gateway Embeddings via Python SDK with Validation and Vector Sync
- A Python module that constructs and validates embedding generation payloads, submits them to the Genesys Cloud LLM Gateway API, tracks latency and accuracy metrics, synchronizes results with an external vector database via callbacks, and maintains governance audit logs.
- This tutorial uses the Genesys Cloud LLM Gateway API endpoint
/api/v2/llm/gateway/embeddingsand the officialgenesys-cloud-sdk-pythonpackage for authentication and configuration. - The implementation covers Python 3.9+ with
pydanticfor schema validation,httpxfor atomic POST operations, and standard library modules for metrics and logging.
- OAuth 2.0 Service Account or Public Client with scopes:
llm:gateway:embeddings:write,llm:gateway:models:read - Genesys Cloud Python SDK version 2.0.0+ (
pip install genesys-cloud-sdk-python) - Python 3.9+ runtime
- External dependencies:
pydantic[email],httpx,tenacity,numpy
The Genesys Cloud SDK handles OAuth 2.0 token acquisition and automatic refresh. You configure the client with your organization domain, client identifier, and secret. The SDK caches the access token in memory and refreshes it before expiration.
from genesyscloud import Configuration, ApiClient
import os
def initialize_genesys_client() -> ApiClient:
"""Initialize the Genesys Cloud API client with OAuth2 client credentials flow."""
configuration = Configuration()
configuration.host = os.environ.get("GENESYS_CLOUD_ORG_DOMAIN", "myorg.mypurecloud.com")
configuration.client_id = os.environ.get("GENESYS_CLOUD_CLIENT_ID")
configuration.client_secret = os.environ.get("GENESYS_CLOUD_CLIENT_SECRET")
# SDK automatically handles token refresh.
# Scopes are requested at the API level, not client initialization.
api_client = ApiClient(configuration)
return api_client
The SDK attaches the Authorization: Bearer <token> header automatically. You must ensure your OAuth application has the llm:gateway:embeddings:write scope granted in the Genesys Cloud admin console.
You must validate input text against inference engine constraints before submission. The LLM Gateway API enforces maximum token limits and requires specific payload structures. You will define a Pydantic model to enforce schema rules, validate token counts, and apply dimensionality reduction directives.
from pydantic import BaseModel, Field, field_validator
import tiktoken
# Model constraint matrix for common LLM Gateway models
MODEL_CONSTRAINTS = {
"text-embedding-3-small": {"max_tokens": 8191, "max_dimensions": 1536, "default_dimensions": 1536},
"text-embedding-3-large": {"max_tokens": 8191, "max_dimensions": 3072, "default_dimensions": 3072}
class EmbeddingPayload(BaseModel):
input_texts: List[str] = Field(..., min_length=1, max_length=2048)
model: str = Field(..., pattern=r"^text-embedding-3-(small|large)$")
dimensions: Optional[int] = None
encoding_format: str = Field(default="float")
@field_validator("input_texts")
@classmethod
def validate_token_limits(cls, v: List[str], info) -> List[str]:
model_name = info.data.get("model")
if not model_name or model_name not in MODEL_CONSTRAINTS:
raise ValueError(f"Unsupported model: {model_name}")
max_tokens = MODEL_CONSTRAINTS[model_name]["max_tokens"]
tokenizer = tiktoken.encoding_for_model("gpt-3.5-turbo")
for idx, text in enumerate(v):
token_count = len(tokenizer.encode(text))
if token_count > max_tokens:
raise ValueError(f"Input at index {idx} exceeds {max_tokens} token limit. Found {token_count} tokens.")
return v
@field_validator("dimensions")
@classmethod
def validate_dimensions(cls, v: Optional[int], info) -> Optional[int]:
if v is None:
return None
max_dim = MODEL_CONSTRAINTS[model_name]["max_dimensions"]
if v < 1 or v > max_dim:
raise ValueError(f"Dimensions must be between 1 and {max_dim} for model {model_name}")
return v
def to_api_body(self) -> dict:
"""Construct the exact JSON payload for POST /api/v2/llm/gateway/embeddings."""
body = {
"input": self.input_texts,
"model": self.model,
"encoding_format": self.encoding_format
if self.dimensions:
body["dimensions"] = self.dimensions
return body
This schema enforces token limits using tiktoken, validates dimensionality reduction directives against the model matrix, and constructs the exact request body the API expects.
Step 2: Atomic POST Execution with Retry and Normalization
You will submit the validated payload using httpx with automatic retry logic for 429 Too Many Requests responses. The LLM Gateway API returns vector arrays. You must verify the response format and trigger automatic L2 normalization if the inference engine returns unnormalized vectors.
import httpx
import numpy as np
from tenacity import retry, wait_exponential, stop_after_attempt, retry_if_exception_type
import json
class EmbeddingGenerator:
def __init__(self, api_client: ApiClient):
self.api_client = api_client
self.base_url = f"https://{api_client.configuration.host}"
self.endpoint = "/api/v2/llm/gateway/embeddings"
@retry(
retry=retry_if_exception_type(httpx.HTTPStatusError),
wait=wait_exponential(multiplier=1, min=2, max=30),
stop=stop_after_attempt(5)
def generate_and_normalize(self, payload: EmbeddingPayload) -> dict:
"""Submit atomic POST request, handle 429 retries, and verify/normalize vectors."""
headers = {
"Accept": "application/json"
# SDK provides the current valid bearer token
token = self.api_client.configuration.access_token
headers["Authorization"] = f"Bearer {token}"
request_body = payload.to_api_body()
with httpx.Client(timeout=30.0) as client:
response = client.post(
f"{self.base_url}{self.endpoint}",
headers=headers,
json=request_body
# Explicit status code handling
raise PermissionError("OAuth token expired or invalid. Refresh credentials.")
if response.status_code == 403:
raise PermissionError("Missing llm:gateway:embeddings:write scope.")
if response.status_code == 422:
raise ValueError(f"Schema validation failed: {response.json().get('message')}")
response.raise_for_status()
data = response.json()
# Format verification and automatic normalization trigger
validated_data = self._verify_and_normalize_vectors(data, payload.model)
return validated_data
def _verify_and_normalize_vectors(self, data: dict, model: str) -> dict:
"""Verify response structure and apply L2 normalization if required."""
if "data" not in data or not isinstance(data["data"], list):
raise ValueError("Invalid API response structure: missing 'data' array.")
normalized_embeddings = []
for item in data["data"]:
vector = np.array(item["embedding"], dtype=np.float32)
# Check if vector is already normalized (L2 norm ~ 1.0)
norm = np.linalg.norm(vector)
if not np.isclose(norm, 1.0, atol=1e-3):
# Automatic normalization trigger for safe generate iteration
vector = vector / norm
normalized_embeddings.append({
"index": item["index"],
"embedding": vector.tolist(),
"original_norm": float(norm)
data["data"] = normalized_embeddings
data["normalization_applied"] = True
return data
The tenacity decorator handles 429 rate-limit cascades with exponential backoff. The normalization routine ensures all vectors maintain unit length, which prevents cosine similarity distortion during retrieval.
Step 3: Vector Synchronization, Metrics, and Audit Logging
You will implement callback handlers for external vector database synchronization, track generation latency, compute embedding accuracy rates, and generate structured audit logs for model governance.
import logging
from typing import Callable, Dict, Any
from dataclasses import dataclass
logging.basicConfig(level=logging.INFO, format="%(asctime)s | %(levelname)s | %(message)s")
logger = logging.getLogger("llm_gateway_embedder")
@dataclass
class GenerationMetrics:
request_id: str
model: str
input_count: int
latency_ms: float
token_count: int
normalization_triggered: bool
audit_log: Dict[str, Any]
class EmbeddingOrchestrator:
def __init__(self, generator: EmbeddingGenerator, vector_db_callback: Callable[[Dict], None]):
self.generator = generator
self.vector_db_callback = vector_db_callback
self.metrics_history: list[GenerationMetrics] = []
def process_batch(self, payload: EmbeddingPayload) -> GenerationMetrics:
"""Execute full generation pipeline with metrics and sync."""
request_id = f"req_{int(start_time * 1000)}"
# Semantic coherence verification pipeline
self._verify_semantic_coherence(payload.input_texts)
result = self.generator.generate_and_normalize(payload)
# Synchronize generating events with external vector databases via callback handlers
sync_payload = {
"request_id": request_id,
"model": payload.model,
"embeddings": result["data"],
"timestamp": time.time()
self.vector_db_callback(sync_payload)
# Calculate approximate token count for audit
total_tokens = sum(len(tokenizer.encode(t)) for t in payload.input_texts)
audit_entry = {
"action": "embedding_generation",
"dimensions": payload.dimensions,
"status": "success",
"input_count": len(payload.input_texts),
"tokens_processed": total_tokens,
metrics = GenerationMetrics(
request_id=request_id,
model=payload.model,
input_count=len(payload.input_texts),
latency_ms=round(latency_ms, 2),
token_count=total_tokens,
normalization_triggered=result.get("normalization_applied", False),
audit_log=audit_entry
self.metrics_history.append(metrics)
logger.info(json.dumps(audit_entry))
return metrics
error_audit = {
"status": "failed",
"error_type": type(e).__name__,
"error_message": str(e),
logger.error(json.dumps(error_audit))
raise
def _verify_semantic_coherence(self, texts: list[str]) -> None:
"""Pre-flight check to prevent vector distortion during LLM scaling."""
for idx, text in enumerate(texts):
if not text or text.strip() == "":
raise ValueError(f"Input at index {idx} is empty or whitespace only.")
if len(text) < 3:
raise ValueError(f"Input at index {idx} is too short for meaningful semantic representation.")
The orchestrator wraps the generator, enforces semantic coherence checks before submission, tracks latency and token counts, triggers the external vector database callback, and writes structured JSON audit logs for governance compliance.
The following script combines authentication, validation, generation, and orchestration into a single runnable module. Replace the environment variables with your Genesys Cloud credentials.
import os
import json
import httpx
import numpy as np
import tiktoken
import logging
from typing import List, Optional, Dict, Callable, Any
"text-embedding-3-small": {"max_tokens": 8191, "max_dimensions": 1536},
"text-embedding-3-large": {"max_tokens": 8191, "max_dimensions": 3072}
@classmethod
raise ValueError(f"Input at index {idx} exceeds {max_tokens} token limit.")
return v
@classmethod
if v is None:
return None
max_dim = MODEL_CONSTRAINTS[info.data.get("model")]["max_dimensions"]
raise ValueError(f"Dimensions must be between 1 and {max_dim}")
return v
body = {"input": self.input_texts, "model": self.model, "encoding_format": self.encoding_format}
if self.dimensions:
return body
@retry(
headers = {
"Accept": "application/json",
"Authorization": f"Bearer {self.api_client.configuration.access_token}"
headers=headers,
json=payload.to_api_body()
raise PermissionError("OAuth token expired or invalid.")
return self._verify_and_normalize_vectors(response.json())
def _verify_and_normalize_vectors(self, data: dict) -> dict:
raise ValueError("Invalid API response structure.")
normalized = []
normalized.append({"index": item["index"], "embedding": vector.tolist(), "original_norm": float(norm)})
return data
@dataclass
request_id: str
model: str
input_count: int
latency_ms: float
token_count: int
self.vector_db_callback({"request_id": request_id, "embeddings": result["data"], "timestamp": time.time()})
audit_entry = {
"action": "embedding_generation", "model": payload.model,
"dimensions": payload.dimensions, "status": "success",
"input_count": len(payload.input_texts), "tokens_processed": total_tokens,
"latency_ms": round(latency_ms, 2), "request_id": request_id
request_id=request_id, model=payload.model,
input_count=len(payload.input_texts), latency_ms=round(latency_ms, 2),
token_count=total_tokens, normalization_triggered=result.get("normalization_applied", False),
return metrics
logger.error(json.dumps({"action": "embedding_generation", "status": "failed", "error": str(e), "request_id": request_id}))
raise
raise ValueError(f"Input at index {idx} is empty.")
if len(text) < 3:
raise ValueError(f"Input at index {idx} is too short.")
def mock_vector_db_sync(payload: Dict) -> None:
"""Simulates external vector database ingestion."""
logger.info(f"Vector DB Sync Triggered: {len(payload['embeddings'])} vectors for {payload['request_id']}")
# Initialize SDK client
config = Configuration()
config.host = os.environ.get("GENESYS_CLOUD_ORG_DOMAIN", "myorg.mypurecloud.com")
config.client_id = os.environ.get("GENESYS_CLOUD_CLIENT_ID")
config.client_secret = os.environ.get("GENESYS_CLOUD_CLIENT_SECRET")
api_client = ApiClient(config)
generator = EmbeddingGenerator(api_client)
orchestrator = EmbeddingOrchestrator(generator, mock_vector_db_sync)
# Construct payload with dimensionality reduction directive
payload = EmbeddingPayload(
input_texts=[
"Customer reported intermittent latency during peak hours.",
"Agent escalated the ticket to tier two support.",
"System logs indicate database connection pool exhaustion."
model="text-embedding-3-small",
dimensions=512 # Dimensionality reduction directive
metrics = orchestrator.process_batch(payload)
print(f"Generation complete. Latency: {metrics.latency_ms}ms | Tokens: {metrics.token_count}")
print(f"Generation failed: {e}")
- What causes it: The OAuth access token has expired, or the client credentials are invalid. The SDK does not auto-refresh if the refresh token is missing or misconfigured.
- How to fix it: Ensure your OAuth application uses the
client_credentialsgrant type with a valid refresh token, or re-initialize theApiClientto trigger a new token exchange. Verify theGENESYS_CLOUD_CLIENT_IDandGENESYS_CLOUD_CLIENT_SECRETenvironment variables. - Code showing the fix: The SDK automatically calls the token endpoint when
access_tokenis stale. If manual refresh is required, callapi_client.refresh_access_token()before the POST request.
Error: 403 Forbidden
- What causes it: The OAuth application lacks the
llm:gateway:embeddings:writescope. Scope restrictions are enforced at the API gateway level. - How to fix it: Navigate to the Genesys Cloud admin console, locate your OAuth application, and add
llm:gateway:embeddings:writeto the scope list. Re-authorize the client to apply changes.
- What causes it: You have exceeded the LLM Gateway rate limits. Genesys Cloud enforces per-organization and per-model concurrency caps.
- How to fix it: The
tenacityretry decorator in Step 2 handles this automatically with exponential backoff. If failures persist, implement request queuing or batch size reduction in your orchestration layer.
Error: 422 Unprocessable Entity
- What causes it: The payload violates schema constraints. Common causes include exceeding
max_tokens, requestingdimensionsgreater than the model maximum, or passing empty strings. - How to fix it: Review the Pydantic validation errors. Ensure
dimensionsfalls within theMODEL_CONSTRAINTSmatrix. Strip whitespace from input texts before validation.
