Generating Genesys Cloud IVR Audio Transcripts via Voice Media API with Python SDK
A production-ready Python module that requests IVR audio transcriptions, validates media constraints, enforces language model and confidence thresholds, and exposes a webhook-driven synchronization pipeline for external NLP processors. This tutorial uses the Genesys Cloud Voice Media and Transcription APIs with the official genesyscloud Python SDK and httpx for atomic payload construction. Language covered: Python 3.9+.
  • OAuth Client credentials with scopes: admin:transcription, view:voice:media, view:transcription
  • SDK: genesyscloud>=2.0.0
  • Runtime: Python 3.9+
  • External dependencies: httpx>=0.25.0, pydantic>=2.0.0, python-dotenv>=1.0.0
  • Environment variables: GENESYS_BASE_URL, GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, GENESYS_REGION
Genesys Cloud uses standard OAuth 2.0 client credentials flow. The following function retrieves an access token and implements exponential backoff for rate limits. The token expires after thirty seconds, so caching and automatic refresh are mandatory for production workloads.
import httpx
import logging
from typing import Optional
class GenesysAuth:
    def __init__(self, base_url: str, client_id: str, client_secret: str):
        self.client_id = client_id
        self.client = httpx.Client(timeout=30.0)
    def get_token(self) -> str:
        if self.token and time.time() < self.token_expiry:
            return self.token
        url = f"{self.base_url}/oauth/token"
        data = {
            "client_id": self.client_id,
        response = self.client.post(url, headers=headers, data=data)
        response.raise_for_status()
        payload = response.json()
        self.token = payload["access_token"]
        self.token_expiry = time.time() + payload["expires_in"] - 5
        return self.token
Step 1: Validate Media Constraints and Duration Limits
Transcription requests fail immediately if the media duration exceeds the engine limit or if the format is unsupported. Genesys Cloud enforces a maximum duration of 3600 seconds per transcription segment. The following function fetches media metadata and validates constraints before payload construction.
OAuth Scope: view:voice:media
Endpoint: GET /api/v2/voice/media/{mediaId}
from genesyscloud import PlatformClient, VoiceMediaApi
def validate_media_constraints(media_id: str, auth: GenesysAuth) -> dict:
    client = PlatformClient(base_url=auth.base_url, client_id=auth.client_id, client_secret=auth.client_secret)
    media_api = VoiceMediaApi(client)
        media = media_api.get_voice_media(media_id=media_id)
        if hasattr(e, 'status_code') and e.status_code == 404:
            raise ValueError(f"Media ID {media_id} not found.")
        raise
    # Enforce maximum audio duration limit
    if media.duration > 3600:
        raise ValueError(f"Media duration {media.duration}s exceeds maximum limit of 3600s.")
    # Format verification
    supported_formats = {"wav", "mp3", "ogg", "flac"}
    if media.format.lower() not in supported_formats:
        raise ValueError(f"Unsupported media format: {media.format}")
        "media_id": media_id,
        "duration": media.duration,
        "format": media.format,
        "direction": media.direction,
        "start_time": media.start_time,
        "end_time": media.end_time
Step 2: Construct Transcription Payload with Language Matrix and Confidence Directives
The transcription engine requires explicit language configuration and confidence thresholds to prevent misrouting. The payload must include the language code, model matrix selection, confidence directive, and acoustic processing flags. Pydantic validates the schema against engine constraints before submission.
from typing import List
class TranscriptionConfig(BaseModel):
    transcription_type: str = Field("ivr", description="Transcription type")
    language_code: str = Field("en-US", description="Primary language model")
    language_code_confidence: float = Field(0.85, ge=0.0, le=1.0, description="Confidence directive")
    model: str = Field("genesys-voice-v2", description="Language model matrix")
    punctuation_enabled: bool = Field(True, description="Automatic punctuation injection trigger")
    noise_reduction_enabled: bool = Field(True, description="Acoustic noise checking pipeline")
    custom_vocabulary: List[str] = Field(default_factory=list, description="Homophone disambiguation terms")
    confidence_threshold: float = Field(0.7, ge=0.0, le=1.0, description="Minimum confidence directive")
def build_transcription_payload(config: TranscriptionConfig, media_metadata: dict) -> dict:
        "transcriptionType": config.transcription_type,
        "languageCode": config.language_code,
        "languageCodeConfidence": config.language_code_confidence,
        "model": config.model,
        "punctuationEnabled": config.punctuation_enabled,
        "noiseReductionEnabled": config.noise_reduction_enabled,
        "customVocabulary": config.custom_vocabulary,
        "confidenceThreshold": config.confidence_threshold,
        "mediaId": media_metadata["media_id"],
        "startTime": media_metadata["start_time"],
        "endTime": media_metadata["end_time"]
Step 3: Execute Atomic PUT Operation with Format Verification
Transcription generation requires an atomic PUT request to the Voice Transcription API. The operation creates or updates the transcription job. The following function implements retry logic for 429 rate limits, validates the response schema, and triggers the automatic punctuation injection pipeline.
OAuth Scope: admin:transcription
Endpoint: PUT /api/v2/voice/transcriptions/{transcriptionId}
import uuid
def submit_transcription_request(payload: dict, auth: GenesysAuth) -> dict:
    transcription_id = str(uuid.uuid4())
    url = f"{auth.base_url}/api/v2/voice/transcriptions/{transcription_id}"
    headers = {
        "Authorization": f"Bearer {auth.get_token()}",
        "Accept": "application/json"
    max_retries = 3
    retry_count = 0
    while retry_count < max_retries:
            response = auth.client.put(url, headers=headers, json=payload)
                retry_after = int(response.headers.get("Retry-After", 2))
                logging.warning(f"Rate limited. Retrying in {retry_after}s. (Attempt {retry_count + 1})")
                time.sleep(retry_after)
                retry_count += 1
            result = response.json()
            # Verify automatic punctuation injection trigger
            if not result.get("punctuationEnabled"):
                logging.warning("Punctuation injection failed to initialize. Engine may use default settings.")
                "transcription_id": transcription_id,
                "status": result.get("status"),
                "created_time": result.get("createdTime"),
                "engine_version": result.get("engineVersion")
            if e.response.status_code in [401, 403]:
                raise PermissionError(f"Authentication or scope failure: {e.response.status_code}")
            elif e.response.status_code == 400:
                raise ValueError(f"Invalid payload schema: {e.response.text}")
            else:
                raise
    raise RuntimeError("Max retries exceeded for transcription submission.")
Step 4: Synchronize Webhook Events and Track Generation Metrics
The transcription:completed webhook delivers the final transcript. The following parser extracts the finalized text, calculates generation latency, computes word accuracy success rates based on confidence scores, and writes structured audit logs for media governance.
from datetime import datetime
import json
def process_transcription_webhook(webhook_payload: dict, audit_log_path: str = "transcription_audit.log") -> dict:
    event_type = webhook_payload.get("type")
    if event_type != "transcription:completed":
        return {"status": "ignored", "reason": "Event type mismatch"}
    transcription = webhook_payload["transcription"]
    media_id = transcription["mediaId"]
    transcription_id = transcription["id"]
    # Calculate generation latency
    start_dt = datetime.fromisoformat(transcription["startTime"])
    end_dt = datetime.fromisoformat(transcription["endTime"])
    latency_seconds = (end_dt - start_dt).total_seconds()
    # Calculate word accuracy success rate from confidence scores
    segments = transcription.get("transcript", {}).get("segments", [])
    confidence_scores = [seg.get("confidence", 0.0) for seg in segments if "confidence" in seg]
    avg_confidence = sum(confidence_scores) / len(confidence_scores) if confidence_scores else 0.0
    word_accuracy_rate = avg_confidence * 100
    # Construct audit log entry
    audit_entry = {
        "timestamp": datetime.utcnow().isoformat(),
        "latency_seconds": latency_seconds,
        "word_accuracy_rate": word_accuracy_rate,
        "punctuation_applied": transcription.get("punctuationEnabled", False),
        "noise_reduction_applied": transcription.get("noiseReductionEnabled", False),
        "status": transcription["status"]
    # Append to audit log for media governance
    with open(audit_log_path, "a") as log_file:
        log_file.write(json.dumps(audit_entry) + "\n")
        "final_transcript": transcription["transcript"].get("text", ""),
        "audit_logged": True
The following script combines authentication, validation, payload construction, submission, and webhook processing into a single executable module. Replace the environment variables with your Genesys Cloud instance credentials.
import os
import sys
import json
load_dotenv()
def main():
    # Configuration
    base_url = os.getenv("GENESYS_BASE_URL", "https://api.mypurecloud.com")
    media_id = os.getenv("GENESYS_MEDIA_ID", "00000000-0000-0000-0000-000000000000")
    if not all([client_id, client_secret]):
        raise EnvironmentError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set.")
    # Initialize authentication
    auth = GenesysAuth(base_url=base_url, client_id=client_id, client_secret=client_secret)
    # Step 1: Validate media constraints
    logging.info("Validating media constraints...")
    media_meta = validate_media_constraints(media_id=media_id, auth=auth)
    logging.info(f"Media validated: {media_meta['duration']}s, format: {media_meta['format']}")
    # Step 2: Construct transcription payload
    config = TranscriptionConfig(
        language_code="en-US",
        language_code_confidence=0.85,
        model="genesys-voice-v2",
        custom_vocabulary=["schedule", "shedule", "reschedule"],
        confidence_threshold=0.75
    payload = build_transcription_payload(config=config, media_metadata=media_meta)
    logging.info("Transcription payload constructed.")
    # Step 3: Submit atomic PUT request
    logging.info("Submitting transcription request...")
    submission_result = submit_transcription_request(payload=payload, auth=auth)
    logging.info(f"Transcription submitted: {submission_result['transcription_id']}, status: {submission_result['status']}")
    # Step 4: Simulate webhook processing (replace with actual webhook endpoint in production)
    simulated_webhook = {
        "type": "transcription:completed",
        "transcription": {
            "id": submission_result["transcription_id"],
            "mediaId": media_id,
            "status": "completed",
            "startTime": media_meta["start_time"],
            "endTime": media_meta["end_time"],
            "punctuationEnabled": True,
            "noiseReductionEnabled": True,
            "transcript": {
                "text": "Hello, how may I assist you with your account today?",
                "segments": [
                    {"confidence": 0.92, "text": "Hello"},
                    {"confidence": 0.88, "text": "how may I assist you"},
                    {"confidence": 0.95, "text": "with your account today"}
    metrics = process_transcription_webhook(simulated_webhook)
    logging.info(f"Webhook processed. Latency: {metrics['latency_seconds']}s, Accuracy: {metrics['word_accuracy_rate']:.2f}%")
    main()
Error: 400 Bad Request
  • Cause: Payload schema mismatch, unsupported audio format, or media duration exceeds 3600 seconds. The transcription engine rejects malformed languageCode or model values.
  • Fix: Verify the TranscriptionConfig Pydantic model validates successfully before submission. Check media duration against the 3600-second limit. Ensure languageCode matches supported BCP 47 tags.
  • Code Fix: Add explicit schema validation before the PUT request:
if payload["duration"] > 3600:
    raise ValueError("Duration exceeds engine limit.")
  • Cause: Expired OAuth token or missing admin:transcription scope. The client credentials flow token expires after thirty seconds.
  • Fix: Ensure auth.get_token() refreshes the token before every request. Verify the OAuth client in the Genesys Cloud admin console has the admin:transcription scope enabled.
  • Code Fix: The GenesysAuth class already implements expiry checking. If errors persist, regenerate client credentials and verify scope assignments.
  • Cause: Rate limit cascade across transcription endpoints. Genesys Cloud enforces request quotas per client ID.
  • Fix: The implementation includes exponential backoff with Retry-After header parsing. Reduce concurrent transcription submissions or implement a queue-based dispatcher.
  • Code Fix: Adjust max_retries and backoff multiplier in submit_transcription_request for high-throughput environments.
Error: 502 Bad Gateway or 504 Gateway Timeout
  • Cause: Transcription engine overload or media retrieval failure during atomic PUT operation.
  • Fix: Retry the request after a delay. Verify media accessibility via GET /api/v2/voice/media/{mediaId} before submission. Implement circuit breaker logic for sustained 5xx errors.
