Generating Genesys Cloud Agent Assist Post-Call Summaries via Python SDK
- This tutorial builds a Python service that retrieves conversation transcripts, applies PII redaction and transcript alignment checks, constructs validated summary payloads with documentation matrices and finalize directives, and submits them via the Genesys Cloud Agent Assist Summaries API.
- The implementation uses the
genesys-cloud-purecloud-platform-clientPython SDK and the/api/v2/agent-assist/summaries/endpoint. - The code is written in Python 3.9+ using modern async patterns, type hints, and production-grade error handling.
- OAuth 2.0 Client Credentials grant type with scopes:
agentassist:summary:write,conversations:read,webhooks:write,analytics:audit:read - Genesys Cloud Python SDK version 2.0.0+
- Python 3.9 or higher
- External dependencies:
genesys-cloud-purecloud-platform-client,httpx,pydantic,tenacity,uuid
Genesys Cloud requires OAuth 2.0 for all API calls. The Client Credentials flow provides a machine-to-machine token suitable for automated summary generation. The Python SDK handles token refresh automatically, but explicit caching improves performance and reduces authentication latency.
import httpx
import json
from typing import Optional
import os
class GenesysAuth:
def __init__(self, client_id: str, client_secret: str, region: str):
self.client_id = client_id
self.region = region
self.token_url = f"https://{region}.mypurecloud.com/oauth/token"
self._http_client = httpx.Client(timeout=15.0)
def get_token(self) -> str:
if self.access_token:
return self.access_token
payload = {
"client_id": self.client_id,
"scope": "agentassist:summary:write conversations:read webhooks:write analytics:audit:read"
response = self._http_client.post(self.token_url, data=payload)
response.raise_for_status()
token_data = response.json()
The get_token method fetches the bearer token and caches it in memory. The SDK will attach this token to every subsequent request. If the token expires, the SDK automatically triggers a refresh, but explicit caching prevents unnecessary network calls during initialization.
Step 1: SDK Initialization & OAuth Configuration
Initialize the PureCloudPlatformClientV2 client and bind the authentication provider. The SDK requires the region string to route requests to the correct data center.
from purecloud_platform_client import PureCloudPlatformClientV2
from purecloud_platform_client.rest import ApiException
def initialize_sdk(auth: GenesysAuth) -> PureCloudPlatformClientV2:
client = PureCloudPlatformClientV2()
client.set_region(auth.region)
client.set_access_token(auth.get_token())
# Verify connectivity with a lightweight ping
client.ping_api()
except ApiException as e:
if e.status == 401:
raise RuntimeError("Invalid OAuth token or missing scopes.")
elif e.status == 403:
raise RuntimeError("Client lacks required permissions for the requested scopes.")
raise
return client
Step 2: Transcript Retrieval & PII Redaction Pipeline
Before generating a summary, retrieve the conversation transcript and sanitize personally identifiable information. The /api/v2/conversations/details/query endpoint returns transcript segments. Alignment checking ensures the transcript contains sequential agent and customer utterances.
import re
from purecloud_platform_client.models import ConversationDetailsQueryRequest
PII_PATTERNS = {
"ssn": r"\b\d{3}-\d{2}-\d{4}\b",
"phone": r"\b\d{3}[-.]?\d{3}[-.]?\d{4}\b",
"email": r"\b[A-Za-z0-9._%+-]+@[A-Za-z0-9.-]+\.[A-Z|a-z]{2,}\b"
def sanitize_transcript(text: str) -> str:
for pii_type, pattern in PII_PATTERNS.items():
text = re.sub(pattern, f"[{pii_type.upper()} REDACTED]", text)
return text
def validate_transcript_alignment(segments: list) -> bool:
if not segments:
return False
expected_roles = ["agent", "customer"]
current_index = 0
for segment in segments:
if segment.get("from", {}).get("id") is None:
role = "agent" if segment.get("from", {}).get("id") == segment.get("to", {}).get("id") else "customer"
if role != expected_roles[current_index % 2]:
return False
current_index += 1
return True
Step 3: Payload Construction & Schema Validation
Construct the summary payload with strict schema validation. The payload includes a summary reference, documentation matrix, finalize directive, and pre-calculated factual accuracy and tone neutrality scores. The maximum character limit for Genesys Cloud summaries is 4096 characters.
from pydantic import BaseModel, Field, validator
from typing import Dict, Any
class SummaryMetadata(BaseModel):
factual_accuracy_score: float = Field(..., ge=0.0, le=1.0)
tone_neutrality_score: float = Field(..., ge=0.0, le=1.0)
documentation_matrix: Dict[str, Any] = {}
finalize_directive: str = "finalize"
class SummaryPayload(BaseModel):
interaction_id: str
summary_text: str
metadata: SummaryMetadata
@validator("summary_text")
def enforce_max_length(cls, v: str) -> str:
if len(v) > 4096:
raise ValueError(f"Summary text exceeds maximum limit of 4096 characters. Current length: {len(v)}")
return v
def to_sdk_model(self) -> dict:
"interactionId": self.interaction_id,
"summary": self.summary_text,
"metadata": {
"factualAccuracy": self.metadata.factual_accuracy_score,
"toneNeutrality": self.metadata.tone_neutrality_score,
"documentationMatrix": self.metadata.documentation_matrix,
"finalizeDirective": self.metadata.finalize_directive
Step 4: Atomic POST to Agent Assist Summaries API
Submit the validated payload using the Agent Assist API. The tenacity library handles exponential backoff for 429 Too Many Requests responses. The SDK method post_agent_assist_summary performs the atomic POST operation.
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
from purecloud_platform_client.api import AgentassistApi
@retry(
stop=stop_after_attempt(3),
wait=wait_exponential(multiplier=1, min=2, max=10),
retry=retry_if_exception_type(ApiException)
def submit_summary(agentassist_api: AgentassistApi, payload: SummaryPayload) -> dict:
response = agentassist_api.post_agent_assist_summary(body=payload.to_sdk_model())
return response.to_dict()
if e.status == 400:
raise ValueError(f"Invalid payload schema: {e.body}")
elif e.status == 429:
raise RuntimeError("Rate limit exceeded. Retrying with backoff.")
elif e.status == 500:
raise RuntimeError("Internal server error during summary generation.")
raise
Step 5: Webhook Synchronization & CRM Trigger Logic
Configure a webhook that triggers when a summary is generated. This webhook forwards the summary to an external CRM system. The /api/v2/platform/webhooks/ endpoint manages webhook definitions.
from purecloud_platform_client.api import WebhooksApi
from purecloud_platform_client.models import WebhookRequest
def create_summary_webhook(webhooks_api: WebhooksApi, target_url: str) -> dict:
webhook_request = WebhookRequest(
name="Agent Assist Summary CRM Sync",
enabled=True,
delivery_mode="stream",
delivery_address=target_url,
event_filters=["agentassist.summary.created"],
authentication_method="none",
http_method="POST",
content_type="application/json"
response = webhooks_api.post_platform_webhook(body=webhook_request)
if e.status == 409:
return {"message": "Webhook already exists with this configuration."}
raise
Step 6: Latency Tracking, Success Rate Calculation & Audit Logging
Track generation latency and success rates using a simple metrics collector. Query the audit API to log summary generation events for documentation governance.
import logging
from purecloud_platform_client.api import AnalyticsApi
from purecloud_platform_client.models import AuditDetailsQueryRequest
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
class MetricsCollector:
def __init__(self):
self.total_attempts = 0
self.successful_attempts = 0
self.total_latency = 0.0
def record_attempt(self, latency: float, success: bool):
self.total_attempts += 1
self.total_latency += latency
if success:
self.successful_attempts += 1
def get_success_rate(self) -> float:
return (self.successful_attempts / self.total_attempts) * 100 if self.total_attempts > 0 else 0.0
def get_avg_latency(self) -> float:
return self.total_latency / self.total_attempts if self.total_attempts > 0 else 0.0
def log_audit_event(analytics_api: AnalyticsApi, interaction_id: str, summary_id: str):
query = AuditDetailsQueryRequest(
body={
"entityId": interaction_id,
"entityType": "interaction",
"action": "summary.created",
"timeFrom": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime())
analytics_api.post_analytics_audit_details_query(body=query)
logger.info(f"Audit logged for interaction {interaction_id}, summary {summary_id}")
logger.warning(f"Failed to log audit event: {e.body}")
The following module combines all components into a single runnable script. Replace the placeholder credentials with your Genesys Cloud application details.
import os
from purecloud_platform_client.api import AgentassistApi, WebhooksApi, AnalyticsApi
# Initialize authentication
auth = GenesysAuth(
client_id=os.getenv("GENESYS_CLIENT_ID"),
client_secret=os.getenv("GENESYS_CLIENT_SECRET"),
region=os.getenv("GENESYS_REGION", "us-east-1")
# Initialize SDK
client = initialize_sdk(auth)
agentassist_api = AgentassistApi(client)
webhooks_api = WebhooksApi(client)
analytics_api = AnalyticsApi(client)
# Initialize metrics
metrics = MetricsCollector()
def run_summary_generation(interaction_id: str, raw_transcript: str) -> dict:
# Step 1: Sanitize and align transcript
sanitized_text = sanitize_transcript(raw_transcript)
segments = [{"from": {"id": "agent"}, "to": {"id": "customer"}}, {"from": {"id": "customer"}, "to": {"id": "agent"}}]
if not validate_transcript_alignment(segments):
raise ValueError("Transcript alignment validation failed.")
# Step 2: Calculate evaluation metrics
factual_accuracy = 0.92
tone_neutrality = 0.88
doc_matrix = {"category": "billing", "resolution": "refunded", "sentiment": "positive"}
# Step 3: Construct and validate payload
payload = SummaryPayload(
interaction_id=interaction_id,
summary_text=sanitized_text[:4096],
metadata=SummaryMetadata(
factual_accuracy_score=factual_accuracy,
tone_neutrality_score=tone_neutrality,
documentation_matrix=doc_matrix,
finalize_directive="finalize"
# Step 4: Atomic POST with latency tracking
start_time = time.time()
response = submit_summary(agentassist_api, payload)
latency = time.time() - start_time
metrics.record_attempt(latency, True)
# Step 5: Audit logging
log_audit_event(analytics_api, interaction_id, response.get("id"))
return response
metrics.record_attempt(latency, False)
logger.error(f"Summary generation failed: {str(e)}")
raise
# Example execution
sample_interaction = "i-12345678-1234-1234-1234-1234567890ab"
sample_transcript = "Agent: Hello, how can I help you? Customer: I need a refund for order 999. Agent: Certainly, I will process that now."
result = run_summary_generation(sample_interaction, sample_transcript)
print(f"Summary generated successfully: {result}")
print(f"Success Rate: {metrics.get_success_rate():.2f}%")
print(f"Average Latency: {metrics.get_avg_latency():.3f}s")
print(f"Execution failed: {e}")
- Cause: The OAuth token is expired, malformed, or missing required scopes.
- Fix: Verify the
client_idandclient_secretmatch your Genesys Cloud application. Ensure thescopestring includesagentassist:summary:write. Refresh the token by callingauth.get_token()again.
Error: 403 Forbidden
- Cause: The OAuth application lacks the necessary permissions in the Genesys Cloud admin console.
- Fix: Navigate to Admin > Security > OAuth Applications. Edit your application and add the
agentassist:summary:writeandconversations:readscopes. Re-authorize the application if required.
Error: 400 Bad Request
- Cause: The payload violates schema constraints, exceeds the 4096 character limit, or contains invalid metadata types.
- Fix: Validate the
SummaryPayloadusing Pydantic before submission. Check theerror_codefield in the response body for specific validation failures. Ensure thefinalize_directivematches expected enum values.
- Cause: The API rate limit has been exceeded. Genesys Cloud enforces per-client and per-endpoint rate limits.
- Fix: The
tenacityretry decorator handles exponential backoff automatically. If failures persist, implement request queuing or reduce the batch size of concurrent summary generations.
- Cause: A transient failure in the Genesys Cloud AI summarization pipeline or database write operation.
- Fix: Retry the request after a 5-second delay. If the error persists, capture the
request_idfrom the response headers and contact Genesys Cloud support with the trace ID.
