Generate a Long-Lived API Token for CI/CD Pipelines Using OAuth2 Client Credentials
- A script that authenticates against Genesys Cloud or NICE CXone using the OAuth2 Client Credentials flow to retrieve an access token.
- This token is tied to a service account and does not require a user password or interactive login, making it ideal for CI/CD pipelines.
- The tutorial covers Python (Genesys Cloud) and JavaScript (NICE CXone) implementations with full error handling and token caching.
- OAuth Client Type: A Service Account (Genesys Cloud) or OAuth Client (NICE CXone) with the “Client Credentials” grant type enabled.
- Required Scopes: Depends on the API you intend to call. For this tutorial, we will use
admin:application:readas a baseline example. - SDK Version:
- Genesys Cloud:
genesys-cloud-purecloud-platform-client(Python, version 140+). - NICE CXone:
@nice-dcx/sdkor rawaxios/fetch(JavaScript).
- Genesys Cloud:
- Language/Runtime:
- Python 3.8+
- Node.js 16+
- External Dependencies:
- Python:
pip install genesys-cloud-purecloud-platform-client - JavaScript:
npm install axios dotenv
- Python:
The Client Credentials flow is distinct from the Resource Owner Password flow or Authorization Code flow. It exchanges a client_id and client_secret directly for an access token. There is no user context involved.
Critical Security Note: Never hardcode credentials. In a CI/CD pipeline, inject these as environment variables (GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET).
Genesys Cloud Endpoint
The token endpoint for Genesys Cloud is:
https://api.mypurecloud.com/api/v2/oauth/token
NICE CXone Endpoint
The token endpoint for NICE CXone varies by region. For US West:
https://us-east-1.platform.nicecxone.com/oauth2/token
Step 1: Constructing the Token Request
The OAuth2 specification requires the credentials to be sent via HTTP Basic Authentication headers or as form parameters in the body. The modern standard, and the one enforced by both Genesys and CXone SDKs, is HTTP Basic Authentication using the client_id and client_secret.
Python Implementation (Genesys Cloud)
We will use the official Genesys Cloud Python SDK. The SDK handles the header encoding automatically, but understanding the underlying request is vital for debugging.
import os
import logging
from purecloudplatformclientv2 import (
Configuration,
ApiClient,
AuthorizationApi,
PureCloudException
# Configure logging for debugging
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, host_url: str = "https://api.mypurecloud.com"):
self.client_id = client_id
self.host_url = host_url
self.access_token = None
self.token_expiry = 0
self.api_client = ApiClient(configuration=Configuration(host=host_url))
self.auth_api = AuthorizationApi(self.api_client)
def _get_token(self) -> str:
Requests a new access token using Client Credentials flow.
# The SDK's login method with client_id and client_secret triggers the Client Credentials flow
# Note: In newer SDK versions, you might need to use the specific authorization endpoint directly
# if the high-level login method is deprecated for service accounts.
# However, the robust way is to use the AuthorizationApi.login_with_client_credentials
# 1. Create the login request object
# Note: The Python SDK often abstracts this, but for explicit control:
login_response = self.auth_api.post_oauth_token(
grant_type="client_credentials",
client_id=self.client_id,
client_secret=self.client_secret
# Scopes can be added here if needed, e.g., scope="admin:application:read"
self.access_token = login_response.access_token
# Genesys tokens typically last 3600 seconds (1 hour)
self.token_expiry = time.time() + login_response.expires_in
logger.info("Successfully acquired new Genesys Cloud token.")
return self.access_token
except PureCloudException as e:
logger.error(f"Failed to acquire token: {e.reason}")
raise
def get_valid_token(self) -> str:
Returns a valid token, refreshing if necessary.
if not self.access_token or time.time() >= self.token_expiry:
logger.info("Token expired or missing. Refreshing...")
self._get_token()
# Usage
raise EnvironmentError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set.")
auth_manager = GenesysAuthManager(client_id, client_secret)
token = auth_manager.get_valid_token()
print(f"Token acquired: {token[:10]}...")
JavaScript Implementation (NICE CXone)
NICE CXone does not have a widely adopted unified SDK for Node.js in the same way Genesys does. It is best practice to use axios to manage the raw HTTP requests for token acquisition.
require('dotenv').config();
class CxoneAuthManager {
constructor(clientId, clientSecret, region = 'us-east-1') {
this.clientId = clientId;
// Determine token endpoint based on region
const regions = {
'us-east-1': 'https://us-east-1.platform.nicecxone.com',
'us-west-1': 'https://us-west-1.platform.nicecxone.com',
'eu-west-1': 'https://eu-west-1.platform.nicecxone.com',
'ap-southeast-1': 'https://ap-southeast-1.platform.nicecxone.com'
this.baseHost = regions[region] || regions['us-east-1'];
this.tokenUrl = `${this.baseHost}/oauth2/token`;
this.accessToken = null;
this.expiresAt = 0;
* Encodes client_id:client_secret in Base64 for Authorization: Basic header
_getBasicAuthHeader() {
const credentials = `${this.clientId}:${this.clientSecret}`;
const encoded = Buffer.from(credentials).toString('base64');
return `Basic ${encoded}`;
* Requests a new token from NICE CXone
async _getToken() {
const response = await axios.post(
this.tokenUrl,
new URLSearchParams({
// Optionally specify scopes here, otherwise it uses default client scopes
// scope: 'cxone:read'
headers: {
'Authorization': this._getBasicAuthHeader(),
'Content-Type': 'application/x-www-form-urlencoded'
const { access_token, expires_in } = response.data;
this.accessToken = access_token;
// Set expiry slightly early to avoid race conditions
this.expiresAt = Date.now() + (expires_in * 1000) - 10000;
console.log('Successfully acquired new CXone token.');
return this.accessToken;
} catch (error) {
if (error.response) {
console.error(`OAuth Error: ${error.response.status} - ${JSON.stringify(error.response.data)}`);
} else {
console.error('Network error during token acquisition:', error.message);
throw error;
* Returns a valid token, refreshing if expired
async getValidToken() {
if (!this.accessToken || Date.now() >= this.expiresAt) {
console.log('Token expired or missing. Refreshing...');
return await this._getToken();
// Usage
async function main() {
const clientId = process.env.CXONE_CLIENT_ID;
const clientSecret = process.env.CXONE_CLIENT_SECRET;
if (!clientId || !clientSecret) {
throw new Error('CXONE_CLIENT_ID and CXONE_CLIENT_SECRET must be set.');
const authManager = new CxoneAuthManager(clientId, clientSecret, 'us-east-1');
const token = await authManager.getValidToken();
console.log(`Token acquired: ${token.substring(0, 10)}...`);
main().catch(console.error);
Step 2: Handling Token Expiration and Caching
OAuth access tokens are short-lived (typically 3600 seconds for Genesys, 3600 seconds for CXone). In a CI/CD pipeline, a single job may take longer than one hour, or a pipeline may consist of multiple stages. You must implement caching logic.
The code examples above include a simple in-memory cache (token_expiry or expiresAt). For distributed systems or long-running services, store the token in a secure secret manager (AWS Secrets Manager, Azure Key Vault) with a TTL.
Edge Case: Token Refresh Race Condition.
If two processes request a token simultaneously when it is expired, both may trigger a refresh. This is acceptable for OAuth (idempotent), but unnecessary. For simple scripts, the in-memory check is sufficient. For high-concurrency apps, use a mutex or lock around the _getToken method.
Step 3: Using the Token for API Calls
Once you have the token, you attach it to the Authorization header of subsequent API requests.
Genesys Cloud Example (Python)
from purecloudplatformclientv2 import OrganizationsApi, PureCloudException
def get_organization_details(auth_manager: GenesysAuthManager):
# Set the access token on the API client
auth_manager.api_client.configuration.access_token = auth_manager.get_valid_token()
organizations_api = OrganizationsApi(auth_manager.api_client)
# API Call: GET /api/v2/organizations
organization = organizations_api.get_organization()
print(f"Organization ID: {organization.id}")
print(f"Organization Name: {organization.name}")
if e.status == 401:
print("Authentication failed. Token may be invalid.")
elif e.status == 403:
print("Forbidden. Check if the service account has 'admin:organization:read' scope.")
else:
print(f"API Error: {e.reason}")
NICE CXone Example (JavaScript)
async function getAccountDetails(authManager: CxoneAuthManager) {
const baseUrl = authManager.baseHost;
// API Call: GET /api/v2/account
const response = await axios.get(`${baseUrl}/api/v2/account`, {
headers: {
'Accept': 'application/json'
console.log(`Account ID: ${response.data.id}`);
console.log(`Account Name: ${response.data.name}`);
} catch (error) {
if (error.response.status === 401) {
console.error("Unauthorized. Token is invalid or expired.");
} else if (error.response.status === 403) {
console.error("Forbidden. Check OAuth client permissions.");
} else {
console.error(`API Error: ${error.response.status}`);
} else {
console.error('Network error:', error.message);
Below is a complete, runnable Python script for Genesys Cloud that integrates authentication, token caching, and a sample API call.
#!/usr/bin/env python3
Genesys Cloud CI/CD Token Generator and API Caller
import os
import sys
import logging
Configuration,
ApiClient,
AuthorizationApi,
OrganizationsApi,
PureCloudException
# Setup logging
level=logging.INFO,
format='%(asctime)s - %(levelname)s - %(message)s'
class GenesysServiceAccount:
def __init__(self, client_id: str, client_secret: str, host: str = "https://api.mypurecloud.com"):
self.host = host
# Initialize SDK components
self.config = Configuration(host=host)
self.api_client = ApiClient(configuration=self.config)
self.org_api = OrganizationsApi(self.api_client)
def _refresh_token(self) -> None:
Acquires a new token using Client Credentials flow.
logger.info("Requesting new OAuth token...")
# Post to /api/v2/oauth/token with grant_type=client_credentials
# expires_in is in seconds
logger.info(f"Token acquired. Expires in {login_response.expires_in} seconds.")
logger.error(f"OAuth Token Request Failed: Status {e.status} - {e.reason}")
raise
def get_token(self) -> str:
Returns a valid access token, refreshing if necessary.
# Check if token is missing or expired (with 30s buffer)
if not self.access_token or time.time() >= (self.token_expiry - 30):
self._refresh_token()
def fetch_organization_info(self) -> dict:
Demonstrates using the token to make an API call.
# Ensure we have a valid token
current_token = self.get_token()
# Set token on the API client for subsequent calls
self.api_client.configuration.access_token = current_token
logger.info("Fetching Organization details...")
organization = self.org_api.get_organization()
"id": organization.id,
"name": organization.name,
"domain": organization.domain
logger.error(f"API Call Failed: Status {e.status} - {e.reason}")
if e.status == 403:
logger.error("Ensure the Service Account has 'admin:organization:read' scope.")
raise
def main():
# Retrieve credentials from environment variables
logger.error("Missing GENESYS_CLIENT_ID or GENESYS_CLIENT_SECRET environment variables.")
sys.exit(1)
# Initialize the service account client
client = GenesysServiceAccount(client_id, client_secret)
# Perform an action that requires authentication
org_info = client.fetch_organization_info()
logger.info("Success!")
logger.info(f"Organization: {org_info['name']} ({org_info['id']})")
logger.error(f"Fatal error: {e}")
sys.exit(1)
main()
Cause: The client_id or client_secret is incorrect, or the token has expired and was not refreshed.
Fix:
- Verify the environment variables are set correctly in your CI/CD pipeline.
- Ensure the Service Account is active in the Genesys Cloud Admin Console.
- Check the
token_expirylogic in your code. If using a cache, ensure the timestamp comparison is accurate.
Error: 403 Forbidden
Cause: The Service Account does not have the required OAuth scope for the API endpoint you are calling.
Fix:
- Navigate to Admin > Users > Service Accounts in Genesys Cloud.
- Select the service account.
- Go to the “Permissions” tab.
- Add the required scope (e.g.,
admin:organization:read,conversation:call:read). - Save and retry. Note: Changes may take up to 5 minutes to propagate.
Cause: You are hitting rate limits. Genesys Cloud enforces rate limits per tenant and per IP.
Fix:
- Implement exponential backoff in your retry logic.
- Check the
Retry-Afterheader in the response. - Ensure you are not creating a new API client instance for every single request. Reuse the
ApiClientinstance.
Cause: Temporary issue on the Genesys Cloud or CXone side.
Fix:
- Retry the request after a short delay.
- Check the Genesys Cloud Status Page or NICE CXone Status Page for outages.
