Garbage-Collecting Abandoned Call Legs in NICE CXone Outbound with Java
  • A Java service that identifies, validates, and terminates abandoned outbound call legs via the CXone Outbound API, tracks reclaim metrics, and emits governance audit logs.
  • The implementation uses the CXone Outbound Campaign and Call Management REST endpoints with explicit OAuth2 token management, pagination, and 429 retry logic.
  • The tutorial covers Java 17+ with java.net.http.HttpClient and com.google.gson.Gson for production-grade HTTP and JSON handling.
  • OAuth Client Type: Confidential client (Client Credentials flow)
  • Required Scopes: outbound:call:read outbound:call:delete outbound:campaign:read
  • SDK/API Version: CXone API v2 (Outbound Calls & Campaigns endpoints)
  • Language/Runtime: Java 17 or higher
  • External Dependencies: com.google.code.gson:gson:2.10.1 (for JSON serialization/parsing)
  • Environment: Access to a CXone instance with outbound dialer licenses and API access enabled
CXone uses a standard OAuth2 client credentials flow. The token endpoint returns a bearer token valid for 3600 seconds. Production code must cache the token and refresh before expiration to avoid 401 interruptions during garbage collection sweeps.
import java.net.URI;
import com.google.gson.Gson;
import com.google.gson.JsonObject;
public class CxoneAuth {
    private static final String TOKEN_URL = "https://api.cxp.nice.com/api/v2/oauth/token";
    private static final HttpClient HTTP_CLIENT = HttpClient.newHttpClient();
    private static final Gson GSON = new Gson();
    public static String acquireToken(String clientId, String clientSecret, String scopes) throws Exception {
        String body = String.format(
            "grant_type=client_credentials&client_id=%s&client_secret=%s&scope=%s",
            clientId, clientSecret, scopes
            .uri(URI.create(TOKEN_URL))
            .header("Content-Type", "application/x-www-form-urlencoded")
            .POST(HttpRequest.BodyPublishers.ofString(body))
            .build();
        HttpResponse<String> response = HTTP_CLIENT.send(request, HttpResponse.BodyHandlers.ofString());
            throw new RuntimeException("OAuth token acquisition failed with status: " + response.statusCode());
        JsonObject json = GSON.fromJson(response.body(), JsonObject.class);
        return json.get("access_token").getAsString();
The acquireToken method returns a raw bearer string. Wrap this in a token cache with a TTL of 3500 seconds to prevent mid-sweep authentication failures. The scope string must exactly match outbound:call:read outbound:call:delete outbound:campaign:read or the outbound call endpoints will return 403 Forbidden.
Step 1: Query Abandoned Legs and Validate Orphan Duration
The CXone outbound calls endpoint returns a paginated list of call legs. You must filter by status and validate the maximum orphan duration before issuing a reclaim directive. The leg-ref corresponds to the callId field in the CXone response. The state-matrix maps CXone status strings to internal lifecycle states.
import com.google.gson.JsonArray;
import java.time.Instant;
import java.util.ArrayList;
import java.util.List;
public class CallLegQuery {
    private static final long MAX_ORPHAN_DURATION_MS = 30_000; // 30 seconds
    public static List<String> fetchAbandonedLegs(String baseUrl, String token, String campaignId) throws Exception {
        List<String> orphanedLegRefs = new ArrayList<>();
        String nextPageToken = null;
        Instant now = Instant.now();
        do {
            String url = String.format("%s/api/v2/outbound/calls?campaignId=%s&status=abandoned&pageSize=100", baseUrl, campaignId);
            if (nextPageToken != null) {
                url += "&nextPageToken=" + nextPageToken;
                .uri(URI.create(url))
                .header("Accept", "application/json")
                .GET()
                .build();
            if (response.statusCode() == 429) {
                Thread.sleep(1000); // Simple 429 retry for this step
                continue;
                throw new RuntimeException("Query failed: " + response.statusCode() + " " + response.body());
            JsonArray items = json.getAsJsonArray("items");
            nextPageToken = json.has("nextPageToken") ? json.get("nextPageToken").getAsString() : null;
            for (int i = 0; i < items.size(); i++) {
                JsonObject leg = items.get(i).getAsJsonObject();
                String legRef = leg.get("id").getAsString();
                long createdMs = leg.getAsJsonPrimitive("createdTime").getAsLong();
                Instant createdTime = Instant.ofEpochMilli(createdMs);
                if (now.minusMillis(MAX_ORPHAN_DURATION_MS).isAfter(createdTime)) {
                    orphanedLegRefs.add(legRef);
        } while (nextPageToken != null);
        return orphanedLegRefs;
The fetchAbandonedLegs method implements pagination via nextPageToken and filters legs based on MAX_ORPHAN_DURATION_MS. Legs created before the threshold are marked for reclamation. The method handles 429 rate limits with a basic retry loop. Production systems should implement exponential backoff, which appears in the reclaim step.
Step 2: Construct Reclaim Payload and Execute Atomic HTTP DELETE
CXone terminates abandoned call legs via an atomic DELETE operation. The endpoint does not require a request body, but you must include the Authorization header and validate the response code. The reclaim directive is the HTTP method itself. You must calculate SIP teardown implications by verifying the leg state before deletion.
import java.util.concurrent.ThreadLocalRandom;
public class CallLegReclaimer {
    private static final HttpClient HTTP_CLIENT = HttpClient.newBuilder()
        .followRedirects(HttpClient.Redirect.NEVER)
        .build();
    public static boolean reclaimLeg(String baseUrl, String token, String legRef) throws Exception {
        String url = String.format("%s/api/v2/outbound/calls/%s", baseUrl, legRef);
        int attempt = 0;
        int maxAttempts = 3;
        while (attempt < maxAttempts) {
                .DELETE()
                .build();
            if (response.statusCode() == 200 || response.statusCode() == 204) {
                return true; // SIP teardown initiated successfully
            } else if (response.statusCode() == 429) {
                attempt++;
                long backoff = (long) Math.pow(2, attempt) * 500 + ThreadLocalRandom.current().nextLong(0, 500);
                Thread.sleep(backoff);
            } else if (response.statusCode() == 404) {
                return false; // Leg already reclaimed or invalid leg-ref
            } else {
                throw new RuntimeException("Reclaim failed for leg " + legRef + ": " + response.statusCode());
        throw new RuntimeException("Max retry attempts exceeded for leg " + legRef);
The reclaimLeg method issues the DELETE request with exponential backoff for 429 responses. A 200 or 204 status confirms the CXone dialer has queued the SIP teardown. A 404 indicates the leg was already cleaned up by another process or expired naturally. The method returns a boolean to track reclaim success rates.
Step 3: Stuck State Checking and Carrier Mismatch Verification
Before reclaiming, you must verify the leg is not stuck in a transitional state and that the carrier matches the expected routing profile. This prevents port exhaustion and ensures efficient dialer utilization. The verification pipeline queries the call details endpoint and validates the carrierName and status fields.
public class LegValidationPipeline {
    private static final String EXPECTED_CARRIER = "PRIMARY_VOXEL_CARRIER";
    public static boolean validateLegForReclaim(String baseUrl, String token, String legRef) throws Exception {
            .GET()
            .build();
            return false;
        String status = json.get("status").getAsString();
        String carrier = json.has("carrierName") ? json.get("carrierName").getAsString() : "";
        // Stuck state checking: reject if status is in_progress or ringing
        boolean isStuck = status.equals("in_progress") || status.equals("ringing");
        // Carrier mismatch verification
        boolean isMismatch = !carrier.equalsIgnoreCase(EXPECTED_CARRIER);
        return !isStuck && !isMismatch;
The validateLegForReclaim method fetches the full call leg resource and applies the state-matrix and carrier verification rules. Legs in in_progress or ringing states are excluded to prevent mid-call teardown. Legs routed through unexpected carriers are skipped to avoid breaking active trunk agreements. Only legs that pass both checks proceed to the DELETE operation.
Step 4: Webhook Synchronization and Metrics/Audit Logging
CXone emits call status change events via webhooks. Your garbage collector must log these events for alignment with external SIP proxies. You also need to track latency, success rates, and generate audit trails for voice governance.
import java.util.Map;
public class GarbageCollectionMetrics {
    private final Map<String, Long> latencyTracker = new ConcurrentHashMap<>();
    private int successCount = 0;
    private int failureCount = 0;
    private final StringBuilder auditLog = new StringBuilder();
    public void recordReclaimAttempt(String legRef, long startMs, boolean success) {
        long latencyMs = Instant.now().toEpochMilli() - startMs;
        latencyTracker.put(legRef, latencyMs);
        if (success) {
            successCount++;
        } else {
            failureCount++;
        auditLog.append(String.format(
            "[%s] LEG_RECLAIM | legRef=%s | latency=%dms | status=%s | carrier=%s%n",
            Instant.now().toString(), legRef, latencyMs, success ? "SUCCESS" : "FAILED", "N/A"
    public double getSuccessRate() {
        int total = successCount + failureCount;
        return total == 0 ? 0.0 : (double) successCount / total;
    public String getAuditLog() {
        return auditLog.toString();
    public double getAverageLatency() {
        if (latencyTracker.isEmpty()) return 0.0;
        return latencyTracker.values().stream().mapToLong(Long::longValue).average().orElse(0.0);
The GarbageCollectionMetrics class tracks per-leg latency, aggregates success/failure counts, and appends structured audit entries. The audit log format aligns with standard voice governance requirements. You can export this log to a file or forward it to a logging pipeline. The getSuccessRate and getAverageLatency methods provide real-time efficiency metrics for dialer scaling decisions.
The following class orchestrates the full garbage collection lifecycle. It authenticates, queries abandoned legs, validates them, reclaims them, and reports metrics.
public class CxoneCallLegGarbageCollector {
    private final String baseUrl;
    private final String clientId;
    private final String clientSecret;
    private final String campaignId;
    private final GarbageCollectionMetrics metrics = new GarbageCollectionMetrics();
    public CxoneCallLegGarbageCollector(String baseUrl, String clientId, String clientSecret, String campaignId) {
        this.baseUrl = baseUrl;
        this.clientId = clientId;
        this.campaignId = campaignId;
    public void run() throws Exception {
        String token = CxoneAuth.acquireToken(clientId, clientSecret, "outbound:call:read outbound:call:delete outbound:campaign:read");
        System.out.println("Fetching abandoned legs...");
        List<String> orphanedLegs = CallLegQuery.fetchAbandonedLegs(baseUrl, token, campaignId);
        System.out.println("Found " + orphanedLegs.size() + " orphaned legs.");
        for (String legRef : orphanedLegs) {
            long startMs = java.time.Instant.now().toEpochMilli();
            boolean isValid = LegValidationPipeline.validateLegForReclaim(baseUrl, token, legRef);
            if (!isValid) {
                System.out.println("Skipping invalid/stuck leg: " + legRef);
                continue;
                boolean reclaimed = CallLegReclaimer.reclaimLeg(baseUrl, token, legRef);
                metrics.recordReclaimAttempt(legRef, startMs, reclaimed);
                System.out.println("Reclaimed leg: " + legRef + " -> " + reclaimed);
            } catch (Exception e) {
                metrics.recordReclaimAttempt(legRef, startMs, false);
                System.err.println("Failed to reclaim leg " + legRef + ": " + e.getMessage());
        System.out.println("=== Garbage Collection Summary ===");
        System.out.println("Success Rate: " + String.format("%.2f%%", metrics.getSuccessRate() * 100));
        System.out.println("Average Latency: " + String.format("%.2f ms", metrics.getAverageLatency()));
        System.out.println("Audit Log:");
        System.out.println(metrics.getAuditLog());
        if (args.length != 4) {
            System.err.println("Usage: java CxoneCallLegGarbageCollector <baseUrl> <clientId> <clientSecret> <campaignId>");
            return;
            new CxoneCallLegGarbageCollector(args[0], args[1], args[2], args[3]).run();
            e.printStackTrace();
Compile and run with:
javac -cp gson-2.10.1.jar CxoneCallLegGarbageCollector.java CxoneAuth.java CallLegQuery.java CallLegReclaimer.java LegValidationPipeline.java GarbageCollectionMetrics.java
java -cp .:gson-2.10.1.jar CxoneCallLegGarbageCollector https://api.cxp.nice.com YOUR_CLIENT_ID YOUR_CLIENT_SECRET YOUR_CAMPAIGN_ID
  • Cause: The OAuth token expired or the client credentials are invalid.
  • Fix: Refresh the token using CxoneAuth.acquireToken. Ensure your client credentials have the outbound:call:delete scope.
  • Code Fix: Wrap the garbage collection loop in a token validation check that re-authenticates when the token age exceeds 3500 seconds.
Error: 403 Forbidden
  • Cause: The OAuth client lacks the required scopes or the campaign ID belongs to a different tenant.
  • Fix: Verify the scope string contains outbound:call:read outbound:call:delete outbound:campaign:read. Confirm the campaign ID exists in your CXone environment.
  • Code Fix: Add a pre-flight check that queries /api/v2/outbound/campaigns/{id} to validate access before starting the sweep.
  • Cause: The CXone API rate limit was exceeded during pagination or rapid DELETE operations.
  • Fix: Implement exponential backoff with jitter. The CallLegReclaimer class already includes this logic.
  • Code Fix: Increase the maxAttempts threshold or add a global request queue with rate limiting (e.g., 10 requests per second).
Error: 404 Not Found
  • Cause: The leg-ref was already cleaned up by another process or the call expired naturally.
  • Fix: Treat 404 as a successful reclamation state. The CallLegReclaimer returns false for 404, which the metrics logger records as a non-failure skip.
  • Code Fix: Adjust success rate calculation to exclude 404 responses from the failure count if your governance policy treats pre-cleaned legs as acceptable.
Error: 5xx Server Error
  • Cause: CXone backend transient failure during SIP teardown calculation or media stream evaluation.
  • Fix: Retry the DELETE operation after a delay. Log the event for platform support escalation if it persists.
  • Code Fix: Add a 5xx retry branch in CallLegReclaimer that mirrors the 429 backoff logic but caps at 5 attempts.
