I am using Genesys Agent Desktop ( GAD ) for outbound call.
When I edit the record when on call the record gets edited.
but after I hang up the call and try to modify the record it does not work.
Any suggestion what I should check?
Thank you !
Thank you !
Maybe your agent is setting himself in Ready and not saving while on AfterCallWork. Also check that OCS is configured to wait for the RecordProcessed Event, check on OCS Deployment guide.
Here are values that I checked, Any others that I need to? Please advise!
All are default values.
RecordProcessed=True
RecordProcessed=soft_previous
outbound_release_action=soft_previous (also tried soft_call_work, hard_not_ready)
Earlier I mentioned that I am able to modify the record before hangup, that is not correct, I am not able to modify the record from GAD at any time before or after hangup.
Here is what I see in the GAD log file:
21 07 07:22:17:371 [ttp-8080-Processor24] WARN GD.Core UpdateOutboundRecordAction aborted : OutboundServiceException [place Place_8478, person nshah_avaya, realtimeSession /getEvents/1/]
21 07 07:22:39:340 [ttp-8080-Processor24] WARN GD.Core MarkProcessed on OutboundChain failed : idInteraction Phonecall-8478-009201b5f6642002 [place Place_8478, person nshah_avaya, realtimeSession /getEvents/1/]
21 07 07:29:55:811 [ttp-8080-Processor24] WARN GD.Core UpdateOutboundRecordAction aborted : OutboundServiceException [place Place_8478, person nshah_avaya, realtimeSession /getEvents/1/]
21 07 07:30:01:124 [ttp-8080-Processor25] WARN GD.Core MarkProcessed on OutboundChain failed : idInteraction Phonecall-8478-009201b5f6642003 [place Place_8478, person nshah_avaya, realtimeSession /getEvents/1/]
21 07 07:32:13:078 [ttp-8080-Processor24] WARN GD.Core MarkProcessed on OutboundChain failed : idInteraction Phonecall-8478-009201b5f6642004 [place Place_8478, person nshah_avaya, realtimeSession /getEvents/1/]
Post corresponding OCS and TServer logs for that ConnID too.
Thank you cavagnaro, really appreciate your help ![]()
Here is what I did to generate these logs:
started OCS campaign
got call in GAD
when connected, I edited the column called “Last4SSN”
Hit Update record button.
Hung up
Change the call_results drop down to “Wrong Party”
Hit the MarkDone button on GAD
There is time difference in log files because OCS in in PST and TServer is in EST
Hum…
The KVP name is “SSN Last 4”, so you started with 1234 and then you updated to 12345.
Then you hang up but there is no RecordHandle that can be managed by GAD, the call is already gone.
15:03:34.777 Trc 04541 RequestDistributeUserEvent received from [496] (00000011 ocs_ocsvr_irv_p 10.1.192.89:2504) message RequestDistributeUserEvent AttributeCommunicationDN '8478' AttributeUserData [215] 00 06 00 00.. 'GSW_AGENT_REQ_TYPE' 'RecordProcessed' 'GSW_RECORD_HANDLE' 17 'GSW_ERROR_NUMBER' 112 'GSW_ERROR' 'No call found for the record handle' 'GSW_APPLICATION_ID' 193 'GSW_CAMPAIGN_NAME' 'LTBaseBusinessCampaign_clt'
Are you sure that OCS RecordProcessed option is true?
double checked, ocs → options → record_processed=“true”
[attach=#]
Does your agent has AfterCallwork?
Yes we want the agents to go in after call work
So the setting we have is:
So right now your agent doesn’t have ACW after the call from customer finishes? If I remember (can’t access to logs…) you had an Avaya switch, if so, then it is the Avaya the one who should send the ACW status.
After the call completes The Agent (GAD) DOES go in ACW. not a problem
( Am I understanding you right?)
Yes, that is ok. Strange really. If the agent saves the record while on ACW and never put himself in Ready the record should be saved, but something is closing the record.
I can’t have access to the logs, can you please send them to:
cavagnaro.jc at gmail.com indicating:
ConnID
Phonenumber dialed
AgentID
And flow of your call?
I will send them now.
Any solution for this? I have same problem. ACW set by Avayaa and record processed after hang up.
Did you find why?
