GAD and java
Hello Gentlemen
I have a question regarding GAD and Java.
where does java jvm path is referenced in GAD application Can any one tell?
as an example in stat server, the java path is mentioned in the Options tab. Where as for GAD i don’t see any where. I looked into the documentation(GAD Deployment) and no reference has been found. I also looked into the GAD folder under gcti and found zero references. Any help would be really appreciated. I am upgrading Java on Windows host machine
Check Deployment guide…
JAVA_HOME is mentioned there
Thank you
My predeccesor has updated java on one host
On the host - I see the Java_home is set to older version, where as the path Under System variables - option(environment varilables/path) is set to new version.
I will do the same thing to the other hosts too
