GAD 7.6.4 -Agents get logged out after call is finished
This is a new install of 7.6.4 GAD. It is connected to 8.1 framework.
Call gets connected to agent. All functionality works, but after the call is disconnected/transferred the agent gets logged out. T-Server logs show log-out records. The agent needs to close their browser and then re-open to login. Obviously this is not desired behavior. Any ideas on settings to check either in GAD or Framework.
Thoughts really appreciated.
Share TServer and gad logs showing the logout event
I have the GAD server debugging turned up pretty high, but there are no events. (Part 1) T-server is below.
Really appreciate your thoughts.
-GAD-
18 05 17:15:20:224 [ http-7070-6] INFO GD.Core Agent registered in the session:9B1E39044A7E2F09258C976D7182A5FB [place 1234567, realtimeSession /getEvents/6/, person Agent7]
18 05 17:15:23:137 [ http-7070-2] INFO GD.Realtime Subscribe subject:/getEvents/6/
18 05 17:15:25:870 [ Thread-1361] INFO GD.Core ** StatServer DEFINED ** [place 1234567, realtimeSession /getEvents/6/, person Agent7]
18 05 17:15:25:870 [ Thread-1361] INFO GD.Core ** Contact Data Base DEFINED ** [place 1234567, realtimeSession /getEvents/6/, person Agent7]
18 05 17:15:25:870 [ Thread-1361] INFO GD.Core ** IS NOT DEFINED ** [place 1234567, realtimeSession /getEvents/6/, person Agent7]
18 05 17:16:20:068 [ Timer-5] INFO ADDP Polling connection tcp://svrff004:3000[Opened]/3
18 05 17:16:20:069 [ Selector#0] INFO ADDP Addp packet received: p(335) from tcp://svrff004:3000[Opened]/3
18 05 17:16:20:217 [ Timer-5] INFO ADDP Polling connection tcp://svrpp001:2020[Opened]/0
18 05 17:16:20:221 [b.PCT.invoker.Cfgsdk] INFO ADDP Addp packet received: p(331) from tcp://svrpp001:2020[Opened]/0
18 05 17:17:20:069 [ Timer-5] INFO ADDP Polling connection tcp://svrff004:3000[Opened]/3
18 05 17:17:20:070 [ Selector#0] INFO ADDP Addp packet received: p(336) from tcp://svrff004:3000[Opened]/3
18 05 17:17:20:221 [ Timer-5] INFO ADDP Polling connection tcp://svrpp001:2020[Opened]/0
18 05 17:17:20:231 [b.PCT.invoker.Cfgsdk] INFO ADDP Addp packet received: p(332) from tcp://svrpp001:2020[Opened]/0
-T-Server-
2016-05-18T17:17:11.282 Interaction svrpp004 tserv_a GCTI-00-04544 Interaction message “EventCallDeleted” generated
IID:01A0028365356B6E
OPER:162
2016-05-18T17:17:11.282 Trace svrpp004 tserv_a GCTI-00-04542 EventCallDeleted sent to [21] (00000006 icon_rb_voice 10.193.21.164:40142)
OPER:162
2016-05-18T17:17:11.282 Trace svrpp004 tserv_a GCTI-00-04542 EventCallDeleted sent to [17] (00000003 icon_mp_voice 10.137.21.228:59096)
@17:17:11.2820 {tscp.call {destructed} {uuid 0273KK5IJKBJP0F7K4AS22LAES00007M} {connection-id 01a0028365356b6e} {call-id 13663}}
@17:17:11.2820 [gctm] Call [01a0028365356b6e/355f/0:0,sES,t0P,l0] deleting.
@17:17:11.3208 [<<] 08 00 00 1E 08 02 80 FB 5A 96 1C 16 91 A2 13 02 01 03 30 0E 02 01 8C 40 09 96 49 02 86 83 49 02 87 86
TP_AsaiData
RELEASE_COMPLETE CRV:80fb
Facility: RETURN_RESULT
InvokeId: 3
Operation: ValueQuery
Domain[1]: (WorkMode),3
Domain[2]: (TalkState),6
@17:17:11.3208 [asai] (processRtrnRsltQueryAddress)
@17:17:11.3208 [asai] (processRtrnRsltAgentStatusRecovery)
@17:17:11.3208 [gctmi] request RequestQueryAddress ctiRefId 251 deactivated in reqMgr
@17:17:11.3208 [gctmi] TMsg [EventAgentReady()] distributing to model
@17:17:11.3208 [gctmi] AgentLogin [1234567,id1248996,sRDY] distributing EventAgentReady
@17:17:11.3208 [gctmi] AgentLogin [1234567,id1248996,sRDY] processReady
@17:17:11.3208 [gctmi] AgentLogin [1234567,id1248996,sRDY] EvReady ignored, already in ready state.
@17:17:11.3208 [gctmi] TMsg [EventAddressInfo()] distributing to model
@17:17:11.3208 [gctmi] Address [1234567,tDN,sIDLE] distributing EventAddressInfo
@17:17:11.3208 [gctmi] request RequestQueryAddress ctiRefId 251 removed from reqMgr
@17:17:11.3208 [<<] 08 00 00 2B 08 02 80 23 62 96 1C 23 91 A1 20 02 01 02 02 01 95 40 18 96 47 01 8F 49 08 83 31 32 33 34 35 36 B7 49 08 93 31 32 34 38 39 39 B6
TP_AsaiData
FACILITY CRV:8023
Facility: INVOKE
InvokeId: 2
Operation: EventReport
Event[1]: Logout
Domain[1]: (Extension),‘1234567’
Domain[2]: (LogicalAgent),‘1248996’
@17:17:11.3209 [asai] (processEvReportLogout)
@17:17:11.3209 [gctmi] TMsg [EventQueueLogout(1234567)] distributing to model
@17:17:11.3209 [gctmi] AgentLogin [1234567,id1248996,sRDY] distributing EventQueueLogout
@17:17:11.3209 [gctmi] AgentLogin [1234567,id1248996,sRDY] processQueueLogout
@17:17:11.3209 [0] 8.1.001.55 distribute_event: message EventQueueLogout
AttributeExtensions [53] 00 01 00 00..
‘AgentSessionID’ ‘0273KK5IJKBJP0F7K4AS22LAES00007K’
AttributeEventSequenceNumber 0000000000007dc9
AttributeCustomerID ‘Resources’
AttributeTimeinuSecs 320933
AttributeTimeinSecs 1463617031 (17:17:11)
AttributeThisDN ‘1234567’
AttributeThisQueue ‘1242039’
AttributeAgentID ‘1248996’
2016-05-18T17:17:11.321 Interaction svrpp004 tserv_a GCTI-00-04544 Interaction message “EventQueueLogout” generated
@17:17:11.3210 [gctmi] TMsg [EventAgentLogout(1234567)] (re)distributing to model in 1mS
@17:17:11.3210 [tsgctm] AgentLogin [1234567,id1248996,sRDY] sendAgentSyncToBackup
@17:17:11.3210 [BSYNC] Trace: Send to backup (tserv_b) [14]:
message EventUserEvent
AttributeExtensions [36] 00 02 01 00..
‘AgentState’ 2
‘SessID’ -1
AttributeAgentWorkMode 2 (AutoIn/LegalGuard)
AttributePrivateMsgID 10002
@17:17:11.3211 [BSYNC] Trace: Sent
@17:17:11.3222 [gctmi] TMsg [EventAgentLogout(1234567)] distributing to model
@17:17:11.3222 [gctmi] AgentLogin [1234567,id1248996,sRDY] distributing EventAgentLogout
@17:17:11.3222 [gctmi] AgentLogin [1234567,id1248996,sRDY] processLoggedOut
@17:17:11.3222 [gctm] AgentLogin [1234567,id1248996,sRDY] Changing state to 0
@17:17:11.3223 [0] 8.1.001.55 distribute_event: message EventAgentLogout
AttributeEventSequenceNumber 0000000000007dca
AttributeTimeinuSecs 322304
Post GAD log level configuration
[log]
ADDP=all
Ail=info
cfg-lib-debug=all
console=info
file=all, ../logs/gdesktop.log, 10, 20
filter=all, 5000
GD=all
GD.HTTP=all
GSD=all
root=all
