Formatting NICE CXone Web Messaging Markdown Responses with Node.js
  • This module validates, sanitizes, and formats markdown payloads for the NICE CXone Web Messaging Guest API, then transmits them via atomic POST operations.
  • The implementation uses the CXone REST API surface with direct HTTP requests and a local validation pipeline.
  • The code is written in modern Node.js with TypeScript-ready JSDoc annotations and async/await patterns.
  • OAuth 2.0 Client Credentials grant configured in the CXone Admin Portal
  • Required scope: webchat:messages:write
  • Node.js 18 or later with npm 9+
  • External dependencies: axios, dompurify, jsdom, marked, uuid
  • Install dependencies with npm install axios dompurify jsdom marked uuid
CXone uses OAuth 2.0 for all API access. The Client Credentials flow is required for server-to-server messaging. The token must be cached and refreshed before expiration to prevent 401 interruptions during batch formatting operations.
import axios from 'axios';
const CXONE_BASE_URL = 'https://api.mynice.com';
const CLIENT_ID = process.env.CXONE_CLIENT_ID;
const CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET;
 * Retrieves an OAuth 2.0 access token from CXone.
 * Implements token caching and refresh logic.
class CXoneAuthClient {
  constructor() {
    this.token = null;
    this.expiresAt = 0;
    this.refreshBuffer = 30000; // Refresh 30 seconds before expiry
  async getAccessToken() {
    if (this.token && Date.now() < this.expiresAt - this.refreshBuffer) {
      return this.token;
    const response = await axios.post(`${CXONE_BASE_URL}/api/v2/oauth/token`, null, {
      params: {
        client_id: CLIENT_ID,
        client_secret: CLIENT_SECRET
    this.token = response.data.access_token;
    this.expiresAt = Date.now() + (response.data.expires_in * 1000);
    return this.token;
Step 1: Markdown Validation & Sanitization Pipeline
CXone renders markdown in webchat messages, but malformed HTML, excessive line breaks, or unescaped links cause layout breaks or XSS vulnerabilities. This pipeline validates the markdown against rendering constraints before transmission.
import { JSDOM } from 'jsdom';
import createDOMPurify from 'dompurify';
import { marked } from 'marked';
const window = new JSDOM('').window;
const DOMPurify = createDOMPurify(window);
const RENDER_CONSTRAINTS = {
  MAX_LINE_BREAKS: 15,
  ALLOWED_TABLE_COLUMNS: 4,
  MAX_LINK_LENGTH: 2048,
  ALLOWED_PROTOCOLS: ['http:', 'https:', 'mailto:']
 * Validates markdown against CXone rendering constraints.
 * Handles HTML entity encoding, link sanitization, and table structure verification.
export async function validateMarkdownPayload(rawMarkdown) {
  // 1. XSS Prevention & HTML Entity Encoding
  const sanitizedHtml = DOMPurify.sanitize(rawMarkdown, {
    ALLOWED_TAGS: ['b', 'i', 'u', 'a', 'p', 'br', 'table', 'tr', 'td', 'th', 'ul', 'ol', 'li'],
    ALLOWED_ATTR: ['href', 'target', 'rel'],
    FORBID_TAGS: ['script', 'iframe', 'object', 'embed', 'form', 'input'],
    ALLOWED_URI_REGEXP: /^(https?|mailto):/
  // 2. Link Sanitization Evaluation
  const linkRegex = /href=["']([^"']+)["']/g;
  let match;
  while ((match = linkRegex.exec(sanitizedHtml)) !== null) {
    const href = match[1];
    const url = new URL(href);
    if (!RENDER_CONSTRAINTS.ALLOWED_PROTOCOLS.includes(url.protocol)) {
      throw new Error(`Invalid link protocol: ${url.protocol}`);
    if (href.length > RENDER_CONSTRAINTS.MAX_LINK_LENGTH) {
      throw new Error('Link exceeds maximum length constraint');
  // 3. Table Structure Verification
  const tableRegex = /<table[^>]*>/g;
  const tables = sanitizedHtml.match(tableRegex) || [];
  for (const table of tables) {
    const colRegex = /<t[dh][^>]*>/gi;
    const cols = sanitizedHtml.match(colRegex) || [];
    if (cols.length > 0 && cols.length % RENDER_CONSTRAINTS.ALLOWED_TABLE_COLUMNS !== 0) {
      throw new Error('Table structure violates column alignment rules');
  // 4. Line Break Limit Validation
  const brCount = (sanitizedHtml.match(/<br\s*\/?>/gi) || []).length;
  const pCount = (sanitizedHtml.match(/<p[^>]*>/gi) || []).length;
  const totalBreaks = brCount + pCount;
  if (totalBreaks > RENDER_CONSTRAINTS.MAX_LINE_BREAKS) {
    throw new Error(`Line break count ${totalBreaks} exceeds maximum limit ${RENDER_CONSTRAINTS.MAX_LINE_BREAKS}`);
  return sanitizedHtml;
Step 2: Payload Construction & Atomic POST Operation
The CXone Web Messaging Guest API expects a specific JSON structure. The renderDirective and responseMatrix concepts are implemented as configuration objects that map validated markdown to CXone message types. The POST operation includes retry logic for 429 rate limits.
 * Constructs the CXone Web Messaging payload with render directives.
export function buildWebchatMessagePayload(conversationId, validatedMarkdown) {
  const responseMatrix = {
    messageType: 'text',
    direction: 'outbound',
    priority: 'normal',
    renderDirective: {
      format: 'markdown',
      wrapText: true,
      preserveWhitespace: false,
      maxRenderWidth: 600
    conversationId,
    ...responseMatrix,
    text: validatedMarkdown,
    messageId: uuidv4()
 * Executes an atomic POST to CXone with 429 retry logic.
export async function sendWebchatMessage(authClient, payload) {
  const maxRetries = 3;
  let retryCount = 0;
  let lastError;
  while (retryCount <= maxRetries) {
      const token = await authClient.getAccessToken();
        `${CXONE_BASE_URL}/api/v2/webchat/messages`,
        payload,
          headers: {
            Authorization: `Bearer ${token}`,
            'Accept': 'application/json'
          timeout: 10000
        success: true,
        statusCode: response.status,
        data: response.data,
        latency: response.headers['x-request-id'] ? Date.now() : 0
    } catch (error) {
      lastError = error;
        const retryAfter = error.response.headers['retry-after'] || 2;
        console.warn(`Rate limited. Retrying in ${retryAfter}s...`);
        await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
        retryCount++;
        continue;
      if (error.response?.status === 401 || error.response?.status === 403) {
        throw new Error(`Authentication failed: ${error.response.status} ${error.response.statusText}`);
      throw error;
  throw new Error(`Max retries exceeded. Last error: ${lastError.message}`);
Step 3: Metrics Tracking, Audit Logging & Webhook Synchronization
Production messaging systems require observability. This module tracks formatting latency, render success rates, and generates structured audit logs. It also formats webhook payloads for external content editor synchronization.
const auditLog = [];
const metrics = {
  totalAttempts: 0,
  successCount: 0,
  failureCount: 0,
  totalLatency: 0
 * Records formatting and transmission metrics.
export function recordMetrics(result) {
  metrics.totalAttempts++;
  if (result.success) {
    metrics.successCount++;
    metrics.totalLatency += result.latency || 0;
  } else {
    metrics.failureCount++;
  const auditEntry = {
    messageId: result.data?.messageId || 'unknown',
    status: result.success ? 'RENDERED' : 'FAILED',
    latencyMs: result.latency || 0,
    error: result.success ? null : result.error?.message,
    renderDirective: result.payload?.renderDirective
  auditLog.push(auditEntry);
  return auditEntry;
 * Generates a markdown-formatted webhook payload for external sync.
export function formatWebhookSyncEvent(auditEntry) {
  const markdownBody = `
## CXone Web Messaging Format Event
- **Message ID**: \`${auditEntry.messageId}\`
- **Status**: ${auditEntry.status}
- **Latency**: ${auditEntry.latencyMs}ms
- **Timestamp**: ${auditEntry.timestamp}
- **Render Directive**: \`${JSON.stringify(auditEntry.renderDirective)}\`
\`\`\`json
${JSON.stringify(auditEntry, null, 2)}
  `.trim();
    event: 'webchat.message.formatted',
    source: 'cxone-markdown-formatter',
    payload: {
      markdown: markdownBody,
      audit: auditEntry
The following script integrates authentication, validation, transmission, metrics, and webhook synchronization into a single executable module. Replace the environment variables with your CXone credentials.
import { CXoneAuthClient } from './auth.js';
import { validateMarkdownPayload, buildWebchatMessagePayload, sendWebchatMessage } from './pipeline.js';
import { recordMetrics, formatWebhookSyncEvent } from './metrics.js';
async function processWebchatMessage(conversationId, rawMarkdown) {
  const authClient = new CXoneAuthClient();
  const startTime = Date.now();
    // Step 1: Validate & Sanitize
    const validatedMarkdown = await validateMarkdownPayload(rawMarkdown);
    // Step 2: Construct Payload
    const payload = buildWebchatMessagePayload(conversationId, validatedMarkdown);
    // Step 3: Transmit
    const result = await sendWebchatMessage(authClient, payload);
    result.payload = payload;
    result.latency = Date.now() - startTime;
    // Step 4: Record & Sync
    const auditEntry = recordMetrics(result);
    const webhookEvent = formatWebhookSyncEvent(auditEntry);
    console.log('Webhook Sync Payload:', JSON.stringify(webhookEvent, null, 2));
    return result;
  } catch (error) {
    console.error('Formatting or transmission failed:', error.message);
    recordMetrics({ success: false, error, payload: null, latency: Date.now() - startTime });
    throw error;
// Example Execution
const TEST_CONVERSATION_ID = 'conv_8f3a9b2c-1d4e-5f6a-7b8c-9d0e1f2a3b4c';
const TEST_MARKDOWN = `
Hello, this is a **formatted** message.
| Feature | Status |
| Links   | [Validated](https://example.com) |
| Tables  | Aligned |
- Point one
- Point two
processWebchatMessage(TEST_CONVERSATION_ID, TEST_MARKDOWN)
  .then(console.log)
  .catch(console.error);
  • Cause: Expired OAuth token or invalid client credentials.
  • Fix: Ensure the CXoneAuthClient refreshes the token before expiration. Verify client_id and client_secret match the CXone Admin Portal configuration.
  • Code Fix: The getAccessToken method already implements a 30-second refresh buffer. If failures persist, clear the cached token manually: authClient.token = null;
Error: 400 Bad Request (Invalid Markdown Structure)
  • Cause: The payload contains disallowed HTML tags, malformed tables, or exceeds line break limits.
  • Fix: Review the validateMarkdownPayload output. CXone rejects messages with <script>, <iframe>, or unbalanced table rows.
  • Code Fix: Adjust RENDER_CONSTRAINTS or sanitize input before validation. Use DOMPurify.sanitize() with strict ALLOWED_TAGS.
  • Cause: Exceeded CXone rate limits for webchat message creation.
  • Fix: Implement exponential backoff. The sendWebchatMessage function already retries up to three times with Retry-After header compliance.
  • Code Fix: Increase maxRetries or add jitter to the retry delay if processing high-volume queues.
Error: 5xx Server Error
  • Cause: CXone platform transient failure or payload size exceeds backend limits.
  • Fix: Log the request ID from the response headers. Verify payload size does not exceed 10KB for webchat messages.
  • Code Fix: Add a size check before transmission: if (JSON.stringify(payload).length > 10240) throw new Error('Payload exceeds 10KB limit');
