Formatting Genesys Cloud Web Messaging Rich Cards with Node.js
This tutorial builds a Node.js service that constructs, validates, and dispatches Genesys Cloud rich messaging cards using the Web Messaging API. The implementation uses the @genesyscloud/purecloud-platform-client-v2 SDK for authentication and axios for atomic HTTP POST operations to /api/v2/conversations/messaging/messages. All code examples use modern JavaScript with async/await, explicit error handling, and production-ready validation pipelines.
- OAuth client type: Service Account (Client Credentials)
- Required scopes:
conversation:messaging:write,conversation:read - SDK version:
@genesyscloud/purecloud-platform-client-v2v5.0.0 or higher - Runtime: Node.js 18 LTS or higher
- External dependencies:
npm install @genesyscloud/purecloud-platform-client-v2 axios uuid
The Genesys Cloud SDK handles token acquisition and automatic refresh when using the Client Credentials flow. You initialize the platform client with your environment, client ID, and client secret. The SDK caches the access token in memory and attaches it to subsequent requests.
const { PlatformClient } = require('@genesyscloud/purecloud-platform-client-v2');
* Initializes the Genesys Cloud Platform Client with Client Credentials OAuth.
* Throws on 401 or 403 if credentials are invalid or scopes are insufficient.
const initializeGenesysClient = async (environment, clientId, clientSecret) => {
const client = PlatformClient.create({
environment: environment,
clientId: clientId,
clientSecret: clientSecret,
// Triggers the OAuth token request
await client.login();
return client;
} catch (error) {
if (error.status === 401 || error.status === 403) {
throw new Error(`Authentication failed: Invalid credentials or missing scopes. Status: ${error.status}`);
throw error;
Step 1: Initialize Client and Configure Messaging Constraints
Genesys Cloud enforces strict payload limits for web messaging. You must define a constraint matrix before constructing cards. The platform limits rich cards to a maximum of 10 actions, requires valid image URLs, and restricts total payload size.
const MESSAGING_CONSTRAINTS = {
MAX_CARD_ACTION_COUNT: 10,
MAX_PAYLOAD_SIZE_BYTES: 262144, // 256 KB
ALLOWED_IMAGE_MIMES: ['image/png', 'image/jpeg', 'image/webp'],
REQUIRED_ALT_TEXT_MIN_LENGTH: 3,
RETRY_BASE_DELAY_MS: 1000,
RETRY_MAX_ATTEMPTS: 3,
* Validates raw card configuration against platform constraints.
* Returns validation errors if limits are exceeded or schema rules fail.
const validateCardConstraints = (cardConfig) => {
const errors = [];
if (cardConfig.actions && cardConfig.actions.length > MESSAGING_CONSTRAINTS.MAX_CARD_ACTION_COUNT) {
errors.push(`Action count ${cardConfig.actions.length} exceeds maximum-card-action-count limit of ${MESSAGING_CONSTRAINTS.MAX_CARD_ACTION_COUNT}`);
if (cardConfig.image && !cardConfig.image.altText) {
errors.push('accessibility-alt verification failed: image.altText is required');
if (cardConfig.image && cardConfig.image.altText.length < MESSAGING_CONSTRAINTS.REQUIRED_ALT_TEXT_MIN_LENGTH) {
errors.push(`accessibility-alt verification failed: altText must be at least ${MESSAGING_CONSTRAINTS.REQUIRED_ALT_TEXT_MIN_LENGTH} characters`);
return errors;
Step 2: Template Interpolation and Asset Resolution Pipeline
Dynamic cards require template interpolation and asset verification. The pipeline replaces variables in the template, resolves image URLs via HEAD requests, and verifies CDN availability before dispatch.
* Performs template-interpolation calculation on string fields.
* Supports {{variable}} syntax with strict replacement.
const interpolateTemplate = (template, context) => {
if (typeof template !== 'string') return template;
return template.replace(/\{\{(\w+)\}\}/g, (match, key) => {
return context[key] !== undefined ? String(context[key]) : match;
* Executes asset-resolution evaluation logic for image URLs.
* Returns true if the URL is reachable and returns an allowed MIME type.
const verifyAssetResolution = async (imageUrl) => {
const response = await axios.head(imageUrl, {
timeout: 5000,
validateStatus: (status) => status < 400,
const contentType = response.headers['content-type'] || '';
const isAllowed = MESSAGING_CONSTRAINTS.ALLOWED_IMAGE_MIMES.some((mime) => contentType.includes(mime));
if (!isAllowed) {
return { valid: false, reason: `Unsupported MIME type: ${contentType}` };
return { valid: true };
} catch (error) {
return { valid: false, reason: `broken-image-url checking failed: ${error.message}` };
Step 3: Card Construction and Action Count Validation
You map the card-ref identifier and messaging-matrix layout configuration to the Genesys Cloud card schema. The builder applies interpolation, validates constraints, and prepares the render directive payload.
const { v4: uuidv4 } = require('uuid');
* Constructs the final Genesys Cloud card payload.
* Applies template interpolation, validates constraints, and formats the render directive.
const buildRenderDirective = async (cardRef, messagingMatrix, dynamicContext) => {
const startTime = performance.now();
// Apply template interpolation to matrix fields
const resolvedMatrix = {
title: interpolateTemplate(messagingMatrix.title, dynamicContext),
body: interpolateTemplate(messagingMatrix.body, dynamicContext),
image: messagingMatrix.image ? {
url: messagingMatrix.image.url,
altText: interpolateTemplate(messagingMatrix.image.altText, dynamicContext),
} : undefined,
actions: (messagingMatrix.actions || []).map((action) => ({
type: action.type,
label: interpolateTemplate(action.label, dynamicContext),
value: interpolateTemplate(action.value, dynamicContext),
// Validate against messaging-constraints
const validationErrors = validateCardConstraints(resolvedMatrix);
if (validationErrors.length > 0) {
throw new Error(`Validation failed: ${validationErrors.join(' | ')}`);
// Verify asset resolution if image is present
if (resolvedMatrix.image?.url) {
const assetCheck = await verifyAssetResolution(resolvedMatrix.image.url);
if (!assetCheck.valid) {
throw new Error(`Asset resolution failed: ${assetCheck.reason}`);
// Format the final render directive for Genesys Cloud
const renderDirective = {
type: 'card',
title: resolvedMatrix.title,
body: resolvedMatrix.body,
image: resolvedMatrix.image,
actions: resolvedMatrix.actions,
const latency = performance.now() - startTime;
return { payload: renderDirective, constructionLatencyMs: latency };
Step 4: Atomic POST Dispatch with 429 Retry Logic
You dispatch the card using an atomic HTTP POST to /api/v2/conversations/messaging/messages. The dispatcher implements exponential backoff for 429 rate-limit responses and validates the HTTP response status before proceeding.
* Dispatches the formatted card to a Genesys Cloud conversation.
* Implements automatic retry logic for 429 responses.
const dispatchCardWithRetry = async (client, conversationId, renderDirective, attempt = 1) => {
const baseUrl = client.getEnvironment();
const accessToken = await client.getAccessToken();
const endpoint = `${baseUrl}/api/v2/conversations/messaging/messages`;
const requestBody = {
to: {
type: 'user',
cards: [renderDirective],
const response = await axios.post(endpoint, requestBody, {
headers: {
'Authorization': `Bearer ${accessToken}`,
'Accept': 'application/json',
timeout: 10000,
success: true,
messageId: response.data.id,
status: response.status,
} catch (error) {
if (error.response) {
const status = error.response.status;
if (status === 429 && attempt < MESSAGING_CONSTRAINTS.RETRY_MAX_ATTEMPTS) {
const delay = MESSAGING_CONSTRAINTS.RETRY_BASE_DELAY_MS * Math.pow(2, attempt - 1);
console.warn(`Rate limit 429 encountered. Retrying in ${delay}ms (attempt ${attempt}/${MESSAGING_CONSTRAINTS.RETRY_MAX_ATTEMPTS})`);
await new Promise((resolve) => setTimeout(resolve, delay));
return dispatchCardWithRetry(client, conversationId, renderDirective, attempt + 1);
if (status === 401 || status === 403) {
throw new Error(`Authentication/Authorization failed: ${status}. Verify OAuth scopes include conversation:messaging:write`);
if (status >= 500) {
throw new Error(`Genesys Cloud server error: ${status}. Response: ${JSON.stringify(error.response.data)}`);
throw new Error(`Dispatch failed with status ${status}: ${JSON.stringify(error.response.data)}`);
throw error;
Step 5: Webhook Sync, Latency Tracking, and Audit Logging
You expose a card formatter service that tracks formatting latency, render success rates, and generates audit logs. The service simulates synchronization with an external CDN via a card rendered webhook callback pattern.
* Tracks metrics and generates audit logs for messaging governance.
const metricsRegistry = {
totalCardsFormatted: 0,
successfulDispatches: 0,
failedDispatches: 0,
averageLatencyMs: 0,
auditLog: [],
const recordAuditEntry = (cardRef, result, constructionLatency, dispatchLatency) => {
const entry = {
cardRef,
constructionLatencyMs: constructionLatency,
dispatchLatencyMs: dispatchLatency,
success: result.success,
messageId: result.messageId || null,
status: result.status || 'FAILED',
metricsRegistry.auditLog.push(entry);
if (result.success) {
metricsRegistry.successfulDispatches += 1;
} else {
metricsRegistry.failedDispatches += 1;
metricsRegistry.totalCardsFormatted += 1;
const totalLatency = constructionLatency + dispatchLatency;
metricsRegistry.averageLatencyMs = (metricsRegistry.averageLatencyMs * (metricsRegistry.totalCardsFormatted - 1) + totalLatency) / metricsRegistry.totalCardsFormatted;
return entry;
* Simulates external CDN sync triggered by card rendered webhook.
const syncExternalCDN = async (cardId, imageUrl) => {
await axios.post('https://your-external-cdn.com/api/v1/cache/purge', {
assetUrl: imageUrl,
cardId: cardId,
}, { timeout: 5000 });
return true;
} catch (error) {
console.error(`CDN sync failed for card ${cardId}: ${error.message}`);
return false;
* Main formatter method that orchestrates the full pipeline.
const formatAndDispatchCard = async (client, cardRef, messagingMatrix, dynamicContext, conversationId) => {
const pipelineStart = performance.now();
let renderDirective, constructionLatency;
const buildResult = await buildRenderDirective(cardRef, messagingMatrix, dynamicContext);
renderDirective = buildResult.payload;
constructionLatency = buildResult.constructionLatencyMs;
} catch (error) {
recordAuditEntry(cardRef, { success: false, status: 'VALIDATION_ERROR' }, 0, 0);
throw error;
const dispatchStart = performance.now();
const dispatchResult = await dispatchCardWithRetry(client, conversationId, renderDirective);
const dispatchLatency = performance.now() - dispatchStart;
const auditEntry = recordAuditEntry(cardRef, dispatchResult, constructionLatency, dispatchLatency);
// Trigger external CDN sync on successful render
if (dispatchResult.success && renderDirective.image?.url) {
await syncExternalCDN(renderDirective.id, renderDirective.image.url);
auditEntry,
metrics: metricsRegistry,
cardPayload: renderDirective,
module.exports = {
initializeGenesysClient,
formatAndDispatchCard,
metricsRegistry,
The following script demonstrates the full pipeline. Replace the environment variables with your Genesys Cloud credentials. The script initializes the client, defines a card template, validates constraints, dispatches the message, and outputs audit metrics.
require('dotenv').config();
const { initializeGenesysClient, formatAndDispatchCard } = require('./card-formatter');
const run = async () => {
const client = await initializeGenesysClient(
process.env.GENESYS_ENVIRONMENT,
process.env.GENESYS_CLIENT_ID,
process.env.GENESYS_CLIENT_SECRET
const cardRef = 'ORDER_CONFIRMATION_V2';
const messagingMatrix = {
title: 'Order {{orderId}} Confirmed',
body: 'Your order for {{itemCount}} items is being processed. Estimated delivery: {{deliveryDate}}',
image: {
url: 'https://example.com/assets/order-success.png',
altText: 'Confirmed order status icon',
actions: [
{ type: 'postback', label: 'Track Package', value: 'TRACK_ORDER' },
{ type: 'web_url', label: 'View Details', value: 'https://example.com/orders/{{orderId}}' },
const dynamicContext = {
orderId: 'ORD-99281',
itemCount: 3,
deliveryDate: '2024-11-15',
const conversationId = process.env.TARGET_CONVERSATION_ID;
const result = await formatAndDispatchCard(
client,
cardRef,
messagingMatrix,
dynamicContext,
conversationId
console.log('Dispatch Result:', JSON.stringify(result.auditEntry, null, 2));
console.log('Metrics:', JSON.stringify(result.metrics, null, 2));
} catch (error) {
console.error('Pipeline failed:', error.message);
process.exit(1);
run();
- What causes it: The OAuth token is expired, the client credentials are incorrect, or the service account lacks the
conversation:messaging:writescope. - How to fix it: Verify your Client ID and Secret match a Service Account in Genesys Cloud. Ensure the OAuth application has the
conversation:messaging:writescope assigned. The SDK handles token refresh automatically, but a freshlogin()call resolves stale token caches. - Code showing the fix: The
initializeGenesysClientfunction explicitly catches 401/403 and throws a descriptive error. Reinitialize the client after updating credentials in the Genesys Cloud admin console.
- What causes it: You exceeded the Genesys Cloud messaging rate limits for your organization tier.
- How to fix it: The
dispatchCardWithRetryfunction implements exponential backoff. If failures persist, implement a queue-based throttling mechanism in your application layer. Reduce concurrent POST operations to stay within your tier limits. - Code showing the fix: The retry logic in Step 4 automatically delays subsequent attempts using
Math.pow(2, attempt - 1) * 1000.
Error: Validation failed: Action count exceeds maximum-card-action-count limit
messagingMatrix.actionsarray contains more than 10 items. Genesys Cloud rejects payloads with excessive actions to prevent UI rendering failures. - How to fix it: Slice the actions array before construction or implement a pagination strategy for card actions. The
validateCardConstraintsfunction enforces this limit. - Code showing the fix:
// Enforce limit before building
const safeActions = messagingMatrix.actions.slice(0, MESSAGING_CONSTRAINTS.MAX_CARD_ACTION_COUNT);
messagingMatrix.actions = safeActions;
Error: broken-image-url checking failed
- What causes it: The image URL returns a 4xx/5xx status, times out, or serves an unsupported MIME type.
- How to fix it: Host assets on a publicly accessible CDN with CORS enabled. Verify the URL resolves via HEAD request. The
verifyAssetResolutionfunction validates MIME types and reachability before dispatch.
