Formatting E.164 Phone Numbers in Genesys Cloud Architect Using Expression Language
- One sentence: You will build a Genesys Cloud Architect flow that accepts an E.164 phone number (e.g., +12125551234) and outputs a US-formatted string ((212) 555-1234).
- One sentence: This uses the Genesys Cloud Architect Expression Language (CEL-like syntax) within a Flow Action.
- One sentence: The tutorial covers the specific string manipulation functions available in Genesys Cloud Architect, as well as how to validate the input via the Genesys Cloud API to ensure data integrity before formatting.
- Access Level: You need “Flow Editor” permissions in Genesys Cloud to create or edit flows.
- Knowledge Base: Familiarity with Genesys Cloud Architect drag-and-drop interface and the concept of “Attributes” and “Data Sets”.
- API Access (for Validation Step): A Genesys Cloud Organization with API credentials. We will use the Python SDK (
genesyscloud) to demonstrate how to validate phone numbers programmatically before they enter the formatting logic. - Dependencies:
genesyscloudPython package (version 12.0+).
Before writing the Architect expression, it is best practice to validate that the incoming number is actually a valid E.164 number. Genesys Cloud provides a Telephony Management API for this. We will use the Python SDK to authenticate and perform a validation check. This ensures that the Architect expression only processes clean data.
Install the SDK:
pip install genesyscloud
Here is the authentication setup using OAuth2 Client Credentials flow. This is the standard method for server-to-server API calls.
import sys
from purecloudplatformclientv2 import (
ApiClient,
Configuration,
TelephonyManagementApi,
PhoneNumberValidationRequest
# Configuration
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
ORG_DOMAIN = "your_domain" # e.g., "mypurecloud.com"
def create_api_client():
Creates and returns an authenticated API client.
config = Configuration(
host=f"https://{ORG_DOMAIN}/api/v2",
client_id=CLIENT_ID,
client_secret=CLIENT_SECRET
# The SDK handles token refresh automatically
api_client = ApiClient(configuration=config)
return api_client
def validate_phone_number(api_client: ApiClient, phone_number: str) -> bool:
Validates a phone number using Genesys Cloud Telephony Management API.
Returns True if valid, False otherwise.
telephony_api = TelephonyManagementApi(api_client)
# Construct the validation request
request_body = PhoneNumberValidationRequest(
number=phone_number
# Call the API
# Endpoint: POST /api/v2/telephony/phone/numbers/validation
response = telephony_api.post_telephony_phone_numbers_validation(
body=request_body
# Check the validation result
# The response contains a 'valid' boolean and 'formatted' options
if response.valid:
print(f"Number {phone_number} is valid. Formatted: {response.formatted}")
return True
else:
print(f"Number {phone_number} is invalid.")
return False
print(f"Error validating number: {e}")
return False
client = create_api_client()
# Example: Validate +12125551234
is_valid = validate_phone_number(client, "+12125551234")
OAuth Scope Required: telephony:phone:read
Step 1: Understanding the Architect Expression Syntax
Genesys Cloud Architect uses a specific expression language for transforming data. It does not support arbitrary Python or JavaScript code. Instead, it provides a set of built-in functions for string manipulation, math, and date handling.
To format a phone number, you cannot use a single “format phone” function. You must construct it using substring extraction and concatenation.
Assume the input attribute is {{contact.attributes.phoneNumber}}.
The input format is E.164: +12125551234.
We need to extract:
- Area Code: Characters 2, 3, 4 (indices 1, 2, 3 in 0-based indexing, but Genesys uses 1-based indexing for
substring). - Prefix: Characters 5, 6, 7.
- Line Number: Characters 8, 9, 10, 11.
Critical Note on Indexing:
In Genesys Cloud Architect expressions, the substring function uses 1-based indexing.
substring(string, start, length)
start: The starting position (1 = first character).length: The number of characters to extract.
For +12125551234:
- Index 1:
+ - Index 2:
1(Country Code) - Index 3:
2(Start of Area Code) - Index 6:
2(End of Area Code) - Index 7:
5(Start of Prefix) - Index 10:
5(End of Prefix) - Index 11:
1(Start of Line Number) - Index 14:
4(End of Line Number)
Step 2: Constructing the Expression
We will build the expression step-by-step using the concat and substring functions.
Extract Area Code:
substring({{contact.attributes.phoneNumber}}, 3, 3)- Starts at index 3 (the first digit of the area code, skipping
+1). - Length 3.
- Result:
212
Extract Prefix:
substring({{contact.attributes.phoneNumber}}, 6, 3)- Starts at index 6.
- Length 3.
- Result:
555
Extract Line Number:
substring({{contact.attributes.phoneNumber}}, 9, 4)- Starts at index 9.
- Length 4.
- Result:
1234
Concatenate with Formatting:
We need to add parentheses and hyphens.concat( "(", substring({{contact.attributes.phoneNumber}}, 3, 3), ") ", substring({{contact.attributes.phoneNumber}}, 6, 3), "-", substring({{contact.attributes.phoneNumber}}, 9, 4) )
Edge Case: Non-US Numbers
The above expression assumes a 10-digit US/Canada number preceded by +1. If the input is a UK number like +442079460123, this expression will break or produce garbage.
To make it robust, you should first check the length or the country code. However, Architect expressions do not support complex if-else logic inline within a single attribute assignment easily without using a “Set Attribute” action with conditions or a “Data Set” lookup.
For this tutorial, we will assume the input is guaranteed to be a US E.164 number (+1...) because the previous Python validation step can filter out non-US numbers if required.
Step 3: Implementing in Architect Flow
- Open your Genesys Cloud Organization.
- Navigate to Admin > Engagement > Flows.
- Create a new Inbound Email or Inbound Voice flow (Voice is more common for phone numbers).
- Add a Set Attribute action.
- Configure the action:
- Attribute Name:
formatted_phone - Value: Select “Expression”.
- Expression: Paste the code below.
- Attribute Name:
concat(
- Save the action.
- Add a Log Message action after it to verify the output.
- Message:
Formatted Phone: {{contact.attributes.formatted_phone}}
- Message:
Step 4: Handling Invalid Lengths with Fallback
If the input number is not exactly 12 characters long (e.g., +1 + 10 digits), the substring function may return an empty string or throw an error depending on the platform version. A safer approach is to use the if function available in newer Architect versions.
However, standard if in expressions is limited. A better architectural pattern is to use a Decision node before the Set Attribute node.
- Add a Decision node.
- Condition:
{{contact.attributes.phoneNumber}}matches regex^\+1\d{10}$- Note: Genesys Architect supports basic regex matching in decisions.
- If True: Proceed to the Set Attribute node defined in Step 3.
- If False: Proceed to a “Log Error” or “Set Default” node.
This ensures that the expression only runs on valid data.
Below is the complete Python script that validates the number, and the corresponding Architect Expression configuration.
Python Validation Script (Pre-Processing)
import sys
ApiClient,
Configuration,
# Replace with your credentials
CLIENT_ID = "YOUR_CLIENT_ID"
CLIENT_SECRET = "YOUR_CLIENT_SECRET"
ORG_DOMAIN = "YOUR_ORG_DOMAIN"
def get_api_client():
return ApiClient(configuration=config)
def validate_and_format_us_number(phone_number: str) -> dict:
Validates a US phone number and returns a formatted string if valid.
client = get_api_client()
telephony_api = TelephonyManagementApi(client)
request = PhoneNumberValidationRequest(number=phone_number)
response = telephony_api.post_telephony_phone_numbers_validation(body=request)
if response.valid and response.country_code == "US":
# Extract the national number (without country code)
# Note: The API returns the national number in various formats.
# We will rely on the original input for consistent parsing if API format varies.
# Check if it matches E.164 US format: +1XXXXXXXXXX
if phone_number.startswith("+1") and len(phone_number) == 12:
area_code = phone_number[2:5]
prefix = phone_number[5:8]
line_num = phone_number[8:12]
formatted = f"({area_code}) {prefix}-{line_num}"
return {"valid": True, "formatted": formatted}
else:
return {"valid": False, "error": "Not a standard US E.164 format"}
else:
return {"valid": False, "error": "Invalid number or not US"}
return {"valid": False, "error": str(e)}
# Test the function
test_number = "+12125551234"
result = validate_and_format_us_number(test_number)
print(result)
Architect Expression Configuration
In the Genesys Cloud Architect UI, inside a Set Attribute action:
Attribute Name:
Value Type:
Expression
Expression:
concat(
Pre-Requisite Decision Node:
Ensure you have a Decision node prior to this Set Attribute action with the condition:
{{contact.attributes.phoneNumber}} matches ^\+1\d{10}$
This ensures the expression only executes on valid 12-character US numbers.
Error: Invalid expression or Syntax error
Cause:
- Missing commas between arguments in
concat. - Using 0-based indexing instead of 1-based indexing.
- Using quotes incorrectly (must use double quotes
Fix:
- Ensure every argument in
concatis separated by a comma. - Remember:
substring(string, 1, 10)gets the first 10 characters.substring(string, 0, 10)is invalid. - Example of correct syntax:
concat("(", substring({{contact.attributes.phoneNumber}}, 3, 3), ")")
Error: Output is (21) 25-5512 (Misaligned)
Cause:
- The input number does not start with
+1. For example, if the input is2125551234(10 digits, no country code), the indices are off by 2. - Index 3 in
2125551234is2(the second digit of the area code), not the start.
Fix:
- Normalize the input before formatting. Use a Set Attribute to prepend
+1if the number is 10 digits and does not start with+. - Decision Node: If
{{contact.attributes.phoneNumber}}length is 10 and does not start with+, set{{contact.attributes.phoneNumber}}toconcat("+1", {{contact.attributes.phoneNumber}}).
Error: Null or Empty String Output
Cause:
- The
substringindices exceed the string length. For example, trying to extract 4 characters starting at index 9 from a string that is only 11 characters long. - The input attribute
{{contact.attributes.phoneNumber}}is null.
Fix:
- Use the Decision Node pattern described in Step 4 to validate length before formatting.
- Add a fallback value in the Set Attribute action if possible, or handle the null case in a parallel flow path.
