Force trunk and CPN in a TRoute using SipServer 8.1
Hello everyone, hope everything’s fine around there. Currently our outgoing calls pass through 2 sip trunks configured with a set CPN that overrides the ANI when routing calls to external parties; there’s a way to force a troute to use a specific trunk as a parameter without changing the dialplan? and how to configure the trunk to pass the ANI as the CPN?
Best regards,
Gef.
you could use geo-location (see chapter 5 of SIP Server deployment guide, item “Working with Multiple Devices”)
Before setting the TRoute, set the AttributeExtensions (UpdateExtensions function of IRD) of geo-location. If using GVP, be sure to set reject-on-geo-location-nomatch on Resource Manager as false.
Thank you HSU, no GVP here; I’ll check that chapter.
geo-location could be configured on Trunk object as well. CPN should be also configurable via extension data - try to check current SIP doc to get required set of the options
