Fixing Undefined Outputs in Genesys Data Actions: Debugging JSON Path Mapping
  • You will build a Python script that replicates a Genesys Cloud Data Action (HTTP GET) and validates the JSON path mapping locally before deployment.
  • This tutorial uses the Genesys Cloud Platform API to fetch user details and maps the response to a specific output variable using Python’s jsonpath-ng library, which mirrors the internal logic of Genesys Data Actions.
  • The programming language covered is Python 3.9+.
  • OAuth Client Type: Machine-to-Machine (M2M) Client ID and Secret.
  • Required Scopes: user:read (for fetching user data).
  • SDK/API Version: Genesys Cloud Platform API v2.
  • Language/Runtime: Python 3.9 or higher.
  • External Dependencies:
    • genesys-cloud-sdk (Official Genesys Python SDK)
    • jsonpath-ng (To simulate the JSON path evaluation engine used in Data Actions)
    • requests (For raw HTTP validation if SDK is unavailable)
Install dependencies via pip:
pip install genesys-cloud-sdk jsonpath-ng requests
Genesys Cloud uses OAuth 2.0 for authentication. The Data Action engine handles token management internally, but when debugging locally, you must manage the token lifecycle. The SDK handles token caching and refresh automatically if you initialize the client correctly.
import os
from purecloud_platform_client import PlatformClient
def initialize_genesis_client():
    Initializes the Genesys Cloud Platform Client using environment variables.
    Raises an exception if credentials are missing.
        raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables are required.")
    # The SDK handles OAuth2 Client Credentials Grant flow internally
    # It caches tokens and refreshes them when they expire
    client = PlatformClient()
    client.set_environment("mypurecloud.com") # Change to your org domain
    client.set_credentials(client_id, client_secret)
    return client
# Initialize the client
client = initialize_genesis_client()
api_instance = client.users_api
Step 1: Replicate the Data Action HTTP Request
Data Actions in Genesys Cloud often fetch external or internal data. A common scenario is fetching a User’s profile by ID to enrich a conversation. The “undefined” error usually occurs because the HTTP request succeeds (200 OK), but the JSON path provided in the Data Action configuration does not match the structure of the response body.
First, we execute the actual API call to retrieve the raw JSON payload. This mirrors what the Data Action engine receives before it attempts to map the fields.
def fetch_user_data(user_id: str) -> dict:
    Fetches user details from Genesys Cloud.
    Returns the raw JSON response as a dictionary.
        # Get User By Id
        # Scope: user:read
        response = api_instance.get_user(
            user_id=user_id,
            expand=["groups", "addresses"] # Optional: expand related resources
        # The SDK returns a model object. We convert it to a dict to simulate
        # the raw JSON body that the Data Action engine parses.
        raw_json = response.to_dict()
        return raw_json
        # Handle 401, 403, 404, 429, 500
        print(f"API Error: {e}")
        raise
# Example usage
USER_ID = "12345678-1234-1234-1234-123456789abc" # Replace with a real User ID
raw_response = fetch_user_data(USER_ID)
Expected Response Structure (Truncated):
  "id": "12345678-1234-1234-1234-123456789abc",
  "name": "John Doe",
  "email": "john.doe@example.com",
  "addresses": [
      "label": "office",
      "value": "+15550100"
  "groups": [
      "id": "group-123",
      "name": "Support Team"
Step 2: Diagnose the JSON Path Mapping Issue
The core problem described in the topic is that the Data Action returns undefined for a specific output variable. This happens when the JSON Path configured in the Genesys Admin Console does not exist in the raw_response dictionary.
Genesys Data Actions use a subset of JSONPath syntax. Common mistakes include:
  1. Using dot notation ($.user.name) instead of bracket notation ($.user['name']) when keys contain special characters (though Genesys keys are usually alphanumeric).
  2. Referencing a nested object that is null or missing.
  3. Referencing an array index that is out of bounds.
  4. Case sensitivity errors (e.g., Name vs name).
We will use the jsonpath-ng library to simulate the Data Action engine’s evaluation. This allows you to test your path locally before saving the Data Action in Genesys.
from jsonpath_ng import parse
from jsonpath_ng.ext import parse as ext_parse
def evaluate_json_path(json_data: dict, json_path: str) -> any:
    Evaluates a JSON path against the provided JSON data.
    Simulates the behavior of Genesys Data Action output mapping.
    # Genesys uses a standard JSONPath implementation.
    # Note: Genesys paths typically start with '$.' or just the key name depending on context.
    # For output mapping, the path is relative to the root of the response body.
    # Clean the path if it starts with '$.' as our parser expects the full path from root
    if json_path.startswith("$."):
        path_expression = json_path
    else:
        path_expression = f"$.{json_path}"
        jsonpath_expr = ext_parse(path_expression)
        matches = jsonpath_expr.find(json_data)
        if not matches:
            return None # This results in 'undefined' in the Data Action output
        # Return the value of the first match
        return matches[0].value
        print(f"JSON Path Error: {e}")
        return None
# Test Case 1: Correct Path
correct_path = "name"
result_correct = evaluate_json_path(raw_response, correct_path)
print(f"Correct Path Result: {result_correct}")
# Test Case 2: Incorrect Path (Typo)
incorrect_path = "nme"
result_incorrect = evaluate_json_path(raw_response, incorrect_path)
print(f"Incorrect Path Result: {result_incorrect}") # Will print None
# Test Case 3: Nested Array Access (Common Failure Point)
# If the user has no addresses, this will be undefined
nested_path = "addresses[0].value"
result_nested = evaluate_json_path(raw_response, nested_path)
print(f"Nested Path Result: {result_nested}")
Step 3: Handling Edge Cases and Null Values
A frequent cause of undefined outputs is when the API returns a field as null or omits it entirely, but the JSON Path expects a value. In Genesys Data Actions, if the path resolves to null, the output variable is often set to null or undefined depending on the specific action type.
You must handle cases where nested objects do not exist. For example, if a user does not belong to any groups, the groups array might be empty or missing.
def robust_json_path_evaluation(json_data: dict, json_path: str, default_value: any = None) -> any:
    Safely evaluates a JSON path. Returns a default value if the path is not found or is null.
    This mimics the 'Default Value' feature available in Genesys Data Actions.
    result = evaluate_json_path(json_data, json_path)
    if result is None:
        return default_value
    return result
# Simulate a user with no groups
user_no_groups = {
    "id": "98765432-4321-4321-4321-987654321abc",
    "name": "Jane Doe",
    "groups": [] # Empty array
# Attempt to access the first group name
group_name_path = "groups[0].name"
group_name = robust_json_path_evaluation(user_no_groups, group_name_path, default_value="No Group Assigned")
print(f"Group Name: {group_name}") # Output: No Group Assigned
The following script combines authentication, data fetching, and JSON path validation into a single runnable module. It allows you to input a User ID and a JSON Path to test if the mapping will succeed in Genesys Cloud.
import os
import sys
def get_genesis_client():
    """Initializes and returns the Genesys Cloud Platform Client."""
        raise ValueError("Set GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables.")
    client.set_environment("mypurecloud.com") # Update to your org domain
    return client
def fetch_and_map(user_id: str, json_path: str, default_value: str = "UNDEFINED"):
    Fetches user data and maps it using the provided JSON path.
    client = get_genesis_client()
    users_api = client.users_api
        # 1. Fetch Data
        print(f"Fetching user: {user_id}...")
        response = users_api.get_user(user_id=user_id, expand=["groups", "addresses"])
        # 2. Prepare JSON Path
        # Genesys Data Actions often accept paths relative to the root.
        # We ensure the path starts with '$' for the parser.
        if not json_path.startswith('$'):
            path_str = f"$.{json_path}"
        else:
            path_str = json_path
        print(f"Evaluating JSON Path: {path_str}")
        # 3. Evaluate Path
        jsonpath_expr = ext_parse(path_str)
        matches = jsonpath_expr.find(raw_json)
        if not matches:
            print(f"Warning: JSON Path '{json_path}' did not match any data in the response.")
        value = matches[0].value
        # Handle null values explicitly
        if value is None:
            print(f"Warning: JSON Path resolved to null.")
        return value
        print(f"Error during execution: {e}")
        return "ERROR"
    if len(sys.argv) < 3:
        print("Usage: python test_data_action.py <USER_ID> <JSON_PATH> [DEFAULT_VALUE]")
        sys.exit(1)
    target_user_id = sys.argv[1]
    target_path = sys.argv[2]
    default = sys.argv[3] if len(sys.argv) > 3 else "UNDEFINED"
    result = fetch_and_map(target_user_id, target_path, default)
    print(f"Final Output: {result}")
Usage:
export GENESYS_CLIENT_ID="your-client-id"
export GENESYS_CLIENT_SECRET="your-client-secret"
python test_data_action.py 12345678-1234-1234-1234-123456789abc name
Error: Output is undefined or null
Cause: The JSON Path does not match the structure of the API response. This is the most common issue. It often happens when:
  1. The API response structure changed (e.g., a field was renamed).
  2. The field is nested inside an array, and the array is empty.
  3. The path uses incorrect case sensitivity.
Fix:
  1. Print the raw_json dictionary (as shown in Step 1) to inspect the exact keys.
  2. Verify the path against the printed JSON. Use a JSONPath tester online or the jsonpath-ng library locally.
  3. Check if the field is optional. If the API returns null for a field, the Data Action output will be null. Use the “Default Value” setting in the Genesys Admin Console for the Data Action output to handle this.
Cause: The OAuth token is invalid, expired, or the client credentials are incorrect.
Fix:
  1. Verify GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET are correct.
  2. Ensure the client has the user:read scope assigned in the Genesys Admin Console under Admin > Security > OAuth Clients.
  3. Check if the client is enabled.
Error: 403 Forbidden
Cause: The client lacks the necessary scope, or the user account making the API call (if using user context) does not have permissions to read the resource.
Fix:
  1. Add the required scope (user:read) to the OAuth client in Genesys Admin.
  2. If using a user-based flow, ensure the user has the “View Users” permission.
Cause: You exceeded the rate limit for the API endpoint.
Fix:
  1. Implement exponential backoff in your retry logic.
  2. Genesys Cloud APIs include Retry-After headers. Respect this header.
  3. For high-volume data actions, consider using Bulk APIs if available, or spacing out requests.
import requests
def fetch_with_retry(url, headers, max_retries=3):
        response = requests.get(url, headers=headers)
            retry_after = int(response.headers.get('Retry-After', 2 ** attempt))
            print(f"Rate limited. Waiting {retry_after} seconds...")
            time.sleep(retry_after)
        else:
            return response
    return None
