Fixing Undefined Outputs in Genesys Data Actions: Correcting JSON Path Mapping
- A working Python script that validates JSON path expressions against sample API payloads to ensure data actions return populated outputs instead of undefined values.
- This tutorial uses the Genesys Cloud Platform API via the Python SDK (
genesyscloud) and raw HTTP requests for debugging. - The programming language covered is Python 3.9+.
- OAuth Client: A Genesys Cloud OAuth client with the scope
analytics:queryanddata:action:read(if testing existing actions) ordata:action:write(if creating new ones). - SDK Version:
genesyscloudPython SDK version 2.0.0 or higher. - Runtime: Python 3.9+ installed.
- Dependencies:
genesyscloudrequestspydantic(for robust JSON schema validation)jmespath(the underlying library Genesys uses for JSON paths)
Install dependencies:
pip install genesyscloud requests pydantic jmespath
Genesys Cloud APIs require OAuth 2.0 Bearer tokens. For this tutorial, we assume you are using a client credentials flow, which is standard for server-to-server integrations and data action backends.
import os
import requests
from genesyscloud.platform.client import PlatformClient
from genesyscloud.auth.client import AuthClient
def get_platform_client():
Initializes the Genesys Platform Client with OAuth2 authentication.
base_url = os.getenv("GENESYS_BASE_URL", "https://api.mypurecloud.com")
raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set in environment variables.")
auth_client = AuthClient(client_id, client_secret, base_url)
platform_client = PlatformClient.create()
# Authenticate the platform client
platform_client.set_auth_client(auth_client)
return platform_client
# Initialize the client
platform_client = get_platform_client()
Step 1: Understanding the Data Action JSON Path Engine
Genesys Cloud Data Actions use a variant of JSONPath (specifically, it relies heavily on the jmespath standard in many backend processors) to extract data from an HTTP response body. When your Data Action returns undefined for a specific output mapping, it means the JSON path expression did not match any node in the response payload.
Common causes for undefined:
- Case Sensitivity: JSON keys are case-sensitive.
orderIdis notorderid. - Array Indexing: Accessing index
0on an empty array returnsnull/undefined. - Nested Objects: Missing an intermediate object layer in the path.
- Special Characters: Keys with spaces or hyphens require bracket notation.
Step 2: Simulating the Data Action Context
To debug this locally, we must simulate the exact HTTP response that Genesys sends to your backend (or receives from a third party) and apply the same JSON path logic that Genesys uses.
We will use the jmespath library, which is the standard implementation for these expressions in Genesys Cloud’s backend processing engine.
import jmespath
import json
def simulate_data_action_mapping(response_payload: dict, mapping_expressions: dict) -> dict:
Simulates the Genesys Data Action output mapping.
Args:
response_payload: The JSON body received from the HTTP target.
mapping_expressions: A dictionary where keys are Output Names
and values are JSON Path expressions.
Returns:
A dictionary of output values. Undefined/None if path fails.
outputs = {}
for output_name, json_path in mapping_expressions.items():
# jmespath.search returns None if the path does not exist
value = jmespath.search(json_path, response_payload)
outputs[output_name] = value
print(f"Error parsing path '{json_path}': {e}")
outputs[output_name] = None
return outputs
# Example: A typical CRM API response
crm_response = {
"data": {
"contacts": [
"id": "c_12345",
"email": "user@example.com",
"firstName": "John",
"lastName": "Doe",
"tags": ["vip", "new_customer"]
"meta": {
"count": 1
# Example Mapping Config (as defined in Genesys Data Action UI)
# Note: Genesys often uses dot notation which jmespath supports,
# but bracket notation is safer for keys with special chars.
mapping_config = {
"contact_id": "data.contacts[0].id",
"contact_email": "data.contacts[0].email",
"first_name": "data.contacts[0].firstName",
"last_name": "data.contacts[0].lastName",
"tag_list": "data.contacts[0].tags",
# Intentionally bad paths to demonstrate 'undefined'
"bad_path_1": "data.contact.id", # Typo: 'contact' vs 'contacts'
"bad_path_2": "data.contacts[1].id", # Index out of bounds (only 1 item)
"bad_path_3": "data.contacts[0].phone" # Key does not exist
results = simulate_data_action_mapping(crm_response, mapping_config)
print(json.dumps(results, indent=2))
Expected Output:
"contact_id": "c_12345",
"contact_email": "user@example.com",
"first_name": "John",
"last_name": "Doe",
"tag_list": [
"vip",
"new_customer"
"bad_path_1": null,
"bad_path_2": null,
"bad_path_3": null
In Genesys Cloud, null from the backend mapping translates to undefined in the flow output variable.
Step 3: Debugging Real API Responses with Python
When you cannot predict the response structure, you need to fetch the actual response from the target API and inspect it. This section shows how to build a diagnostic tool that fetches the target URL and tests multiple candidate JSON paths.
import requests
import json
from typing import Dict, List, Optional
class DataActionDebugger:
def __init__(self, target_url: str, headers: Dict[str, str] = None, method: str = "GET"):
self.target_url = target_url
self.headers = headers or {}
self.method = method.upper()
def fetch_response(self) -> Optional[dict]:
"""Fetches the raw response from the target API."""
if self.method == "GET":
response = requests.get(self.target_url, headers=self.headers)
elif self.method == "POST":
# For POST, you might need to pass a body.
# In a real debugger, this would come from the flow inputs.
response = requests.post(self.target_url, headers=self.headers, json={})
else:
raise ValueError(f"Unsupported method: {self.method}")
response.raise_for_status()
return response.json()
print(f"Failed to fetch target API: {e}")
return None
except json.JSONDecodeError:
print("Target API did not return valid JSON.")
return None
def test_paths(self, payload: dict, candidate_paths: List[str]) -> Dict[str, Optional]:
Tests a list of candidate JSON paths against the payload.
import jmespath
results = {}
for path in candidate_paths:
value = jmespath.search(path, payload)
results[path] = value
results[path] = f"Error: {str(e)}"
return results
# Usage Example
# Replace with your actual external API endpoint
TARGET_URL = "https://jsonplaceholder.typicode.com/users/1"
debugger = DataActionDebugger(target_url=TARGET_URL)
# 1. Fetch the actual response
payload = debugger.fetch_response()
if payload:
print("--- Raw Response Structure ---")
print(json.dumps(payload, indent=2)[:500] + "...") # Truncate for readability
print("\n--- Path Testing ---")
# Common mistakes developers make:
candidate_paths = [
"name", # Correct
"Name", # Incorrect (Case)
"user.name", # Incorrect (No 'user' wrapper)
"address.city", # Correct (Nested)
"address.City", # Incorrect (Case)
"nonExistentField" # Returns None/Undefined
results = debugger.test_paths(payload, candidate_paths)
for path, value in results.items():
status = "OK" if value is not None else "UNDEFINED/NULL"
print(f"Path: {path:20} | Status: {status:15} | Value: {value}")
Step 4: Handling Arrays and Dynamic Indices
A frequent cause of undefined is accessing an array element by index when the array is empty or the index changes. Genesys Data Actions do not support dynamic iteration in the output mapping itself. If the API returns an array of items, you must decide how to map it.
Scenario: The API returns a list of phone numbers. You only want the first one.
Bad Mapping: data.phones[0].number
Result: undefined if data.phones is [].
Better Mapping (Using JMESPath first): data.phones[0].number is standard, but if you want to be safe against empty arrays in some processors, you can use data.phones[0].number combined with a default value in the Data Action configuration if supported, or handle the null in the flow.
However, the most robust way to debug this is to verify the array structure:
import jmespath
api_response_with_array = {
"data": {
"phones": [
{"type": "mobile", "number": "555-0100"},
{"type": "home", "number": "555-0101"}
api_response_empty_array = {
"data": {
"phones": []
# Test Case 1: Normal Array
print("Normal Array:")
print(f"First Phone: {jmespath.search('data.phones[0].number', api_response_with_array)}")
print(f"All Numbers: {jmespath.search('data.phones[*].number', api_response_with_array)}")
# Test Case 2: Empty Array
print("\nEmpty Array:")
print(f"First Phone: {jmespath.search('data.phones[0].number', api_response_empty_array)}")
# Output: None (Undefined in Genesys)
# Test Case 3: Using 'first' function if available in your JMESPath version
# Note: Genesys's internal engine may vary slightly, but standard jmespath supports 'first'
print(f"Safe First: {jmespath.search('first(data.phones).number', api_response_empty_array)}")
except:
print("Safe First: Not supported or resulted in error")
Step 5: Validating Keys with Special Characters
If your JSON keys contain spaces, hyphens, or start with numbers, dot notation fails. You must use bracket notation.
Incorrect: response.total-items (Parsed as subtraction)
Correct: response['total-items']
import jmespath
complex_json = {
"order-summary": {
"total-cost": 100.50,
"item count": 5
# Failing dot notation
val = jmespath.search("order-summary.total-cost", complex_json)
print(f"Dot Notation Result: {val}")
print(f"Dot Notation Failed: {e}")
# Correct bracket notation
val_bracket = jmespath.search("['order-summary']['total-cost']", complex_json)
print(f"Bracket Notation Result: {val_bracket}")
val_space = jmespath.search("['order-summary']['item count']", complex_json)
print(f"Space Key Result: {val_space}")
This script combines authentication, fetching a sample Genesys Cloud object (User), and testing a JSON path against it to demonstrate a successful mapping.
import os
import json
import jmespath
from genesyscloud.users.api import UsersApi
def main():
# 1. Setup Authentication
print("Error: Environment variables GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET are required.")
return
# 2. Fetch Data from Genesys API
users_api = UsersApi(platform_client)
# Get current user
response = users_api.get_user_me()
user_data = response.to_dict() # Convert SDK model to dict for JSONPath testing
print(f"Failed to fetch user: {e}")
return
print("--- Raw User Data (Truncated) ---")
print(json.dumps(user_data, indent=2)[:300])
# 3. Define Data Action Mappings
# Simulating a Data Action that extracts user details
mappings = {
"user_email": "email",
"user_name": "name",
"user_id": "id",
"division_id": "division.id",
# Intentional errors to show undefined
"bad_email": "Email", # Case mismatch
"bad_division": "divisionId" # Wrong key name
# 4. Validate Mappings
print("\n--- Mapping Validation Results ---")
for output_name, json_path in mappings.items():
value = jmespath.search(json_path, user_data)
if value is None:
print(f"[FAIL] Output '{output_name}' is UNDEFINED. Path: '{json_path}'")
else:
print(f"[OK] Output '{output_name}' = {value} (Path: '{json_path}')")
# 5. Debugging Tip: Print all top-level keys to help users find the right path
print("\n--- Available Top-Level Keys ---")
print(list(user_data.keys()))
if 'division' in user_data and user_data['division']:
print("Available Division Keys:", list(user_data['division'].keys()))
main()
Error: Output Variable is undefined in Flow
- Cause: The JSON path returned
nullfrom the backend. - Fix:
- Check the “Response Body” log in the Data Action execution history.
- Copy the response body into the
simulate_data_action_mappingfunction above. - Iterate through your paths until one returns a value.
- Ensure you are using bracket notation
['key-name']for keys with special characters.
Error: jmespath.exceptions.ParseError
- Cause: Invalid syntax in the JSON path expression.
- Fix: Ensure parentheses are balanced and brackets are closed. Avoid mixing dot and bracket notation inconsistently (e.g.,
data.contacts[0].emailis valid, butdata.contacts[0]emailis not).
- Cause: The OAuth token used in the Data Action’s HTTP request configuration is invalid or lacks scope.
- Fix: Verify the OAuth client credentials in the Data Action configuration. Ensure the client has the necessary scopes for the target API.
Error: Array Index Out of Bounds
- Cause: The path
data.items[0].idfails becausedata.itemsis empty. - Fix: You cannot dynamically handle this in the JSON path alone in Genesys Data Actions. You must ensure the upstream API always returns at least one item, or handle the
undefinedresult in the Genesys Flow by checking if the output variable is defined before using it.
