Fixing Undefined Outputs in Genesys Cloud Data Actions: A Guide to JSON Path Mapping
  • You will create a Data Action that successfully parses a complex JSON response from an external API and maps specific fields to output variables.
  • You will use the Genesys Cloud CX Platform API (specifically the Flows API) to configure the Data Action properties.
  • The tutorial uses Python with the requests library to demonstrate the configuration and testing of the JSON path mapping.
  • OAuth Client Type: Service Account with the following scopes:
    • flow:detail:read (to inspect existing flows)
    • flow:detail:write (to update or create flow elements)
    • api:agent (if testing via agent simulation)
  • API Version: Genesys Cloud Platform API v2.
  • Language/Runtime: Python 3.8+ or Node.js 16+.
  • Dependencies:
    • Python: pip install requests
    • Node.js: npm install axios
Before interacting with the Flows API, you must obtain a valid access token. The following example uses a Service Account with client credentials grant. This is the standard approach for server-side integrations.
Python Authentication Example
import requests
import os
import json
# Configuration
TENANT = os.getenv("GENESYS_TENANT", "your_tenant")
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID", "")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET", "")
def get_access_token():
    Retrieves an OAuth2 access token using Client Credentials Grant.
    url = f"https://{TENANT}.mypurecloud.com/oauth/token"
    headers = {
    data = {
        "client_id": CLIENT_ID,
        "client_secret": CLIENT_SECRET
    response = requests.post(url, headers=headers, data=data)
    if response.status_code != 200:
        raise Exception(f"Failed to get token: {response.status_code} {response.text}")
    return response.json()["access_token"]
# Initialize token
token = get_access_token()
headers = {
The core issue described in the topic is that a Data Action returns undefined for output variables. This almost always stems from one of two causes:
  1. The JSON Path expression does not match the structure of the actual HTTP response body.
  2. The output variable is defined as a specific type (e.g., String), but the JSON path resolves to a different type (e.g., Integer or Array), causing a silent coercion failure or null result in the runtime engine.
We will address this by building a Data Action that calls a sample JSON API and maps a nested field correctly.
Step 1: Define the External API Response Structure
To debug JSON path mapping, you must know the exact shape of the response. Let us assume we are calling a hypothetical user lookup API.
Example Response Payload (application/json):
  "status": "success",
  "data": {
    "user": {
      "id": 12345,
      "profile": {
        "firstName": "Jane",
        "lastName": "Doe",
        "metadata": {
          "tier": "gold",
          "joinDate": "2023-01-01"
  "pagination": {
    "total": 1
If you attempt to map user.firstName directly, you will get undefined because the root object contains data, not user. The correct path is data.user.profile.firstName.
Step 2: Configure the Data Action Element
We will use the Genesys Cloud Flows API to create a Data Action element. The critical section is the outputs array within the element definition. Each output requires a name, type, and value (which contains the JSON path).
Critical Parameter: The value field in the output definition expects a JSON path string. If the path is invalid, the runtime returns null or undefined.
Python Code: Constructing the Data Action Payload
import json
def create_data_action_payload(flow_id: str, external_url: str) -> dict:
    Constructs the JSON payload for a Data Action element.
    # Define inputs (if any are needed for the external API)
    inputs = []
    # Define outputs with precise JSON paths
    # Note: The 'value' field contains the JSONPath expression.
    # Using '$' explicitly is recommended for clarity, though often optional.
    outputs = [
            "name": "user_first_name",
            "type": "String",
            "value": {
                "type": "JSONPath",
                "value": "$.data.user.profile.firstName"
            "name": "user_tier",
            "type": "String",
            "value": {
                "type": "JSONPath",
                "value": "$.data.user.profile.metadata.tier"
            "name": "user_id",
            "type": "Number",
            "value": {
                "type": "JSONPath",
                "value": "$.data.user.id"
    # The Data Action element definition
    data_action_element = {
        "type": "DataAction",
        "name": "FetchUserProfile",
        "description": "Retrieves user profile data from external service",
        "settings": {
            "httpMethod": "GET",
            "url": external_url,
            "headers": [
                    "name": "Accept",
                    "value": "application/json"
                    "name": "Authorization",
                    "value": "Bearer YOUR_EXTERNAL_API_KEY"
            "timeout": 5000,
            "retryCount": 1,
            "retryDelay": 1000
        "inputs": inputs,
        "outputs": outputs
    return data_action_element
# Example usage
flow_id = "your-flow-id-here"
external_url = "https://api.example.com/users/12345"
payload = create_data_action_payload(flow_id, external_url)
print(json.dumps(payload, indent=2))
Step 3: Validate the JSON Path Syntax
A common mistake is using dot notation incorrectly or failing to escape special characters. Genesys Cloud uses a standard JSONPath implementation.
Common Mapping Errors:
  1. Array Indexing: If the response is an array [{ "name": "A" }, { "name": "B" }], mapping name returns an array. If the output type is String, it may fail or return the first element depending on the engine version. To get the first element explicitly, use $.data[0].name.
  2. Missing Root Selector: While $ is often implicit, explicitly using $.data.user prevents ambiguity if the root object changes.
  3. Type Mismatch: If id is a number in JSON but you define the output type as String, Genesys Cloud will attempt to convert it. If the conversion fails, the result is undefined. Ensure the type in the output definition matches the JSON value type.
Step 4: Update the Flow Element via API
To test this configuration, we must add or update the element in an existing Flow. We will use the PATCH method on the Flow endpoint.
API Endpoint: PATCH /api/v2/flows/{flowId}
OAuth Scope: flow:detail:write
def update_flow_element(flow_id: str, new_element: dict, position: int = 0):
    Updates a flow by adding or replacing a Data Action element.
    url = f"https://{TENANT}.mypurecloud.com/api/v2/flows/{flow_id}"
    # We need the current flow structure to update it correctly
    # In a real scenario, you would GET the flow first, modify the element array, and PATCH it back.
    # For this tutorial, we assume a minimal flow structure update.
    payload = {
        "version": 1, # Must match current flow version
        "elements": [new_element]
    response = requests.patch(url, headers=headers, json=payload)
    if response.status_code == 200:
        print("Flow element updated successfully.")
    else:
        print(f"Failed to update flow: {response.status_code}")
        print(response.text)
        return None
# Uncomment to run
# update_flow_element(flow_id, payload)
Below is a complete Python script that authenticates, defines a Data Action with correct JSON path mapping, and prints the configuration for verification. This script does not modify the flow but generates the exact JSON required to fix the undefined issue.
import requests
import os
import json
# --- Configuration ---
    data = {
        raise Exception(f"Auth failed: {response.text}")
def main():
        headers = {
        # --- Step 1: Define the External API Response Shape ---
        # Simulated Response from https://api.example.com/data
        #   "result": "ok",
        #   "payload": {
        #     "items": [
        #       { "id": 1, "name": "Item One" },
        #       { "id": 2, "name": "Item Two" }
        # --- Step 2: Construct Data Action with Correct JSON Paths ---
        data_action_config = {
            "name": "FetchExternalData",
            "settings": {
                "url": "https://api.example.com/data",
                "headers": [
                    {"name": "Accept", "value": "application/json"}
                "timeout": 5000
            "inputs": [],
            "outputs": [
                    "name": "first_item_name",
                    "type": "String",
                    "value": {
                        "type": "JSONPath",
                        # Correct path: Root -> payload -> items array index 0 -> name
                        "value": "$.payload.items[0].name"
                    "name": "total_items",
                    "type": "Number",
                    "value": {
                        "type": "JSONPath",
                        # Correct path: Length of the items array
                        "value": "$.payload.items.length"
        print("Generated Data Action Configuration:")
        print(json.dumps(data_action_config, indent=2))
        # --- Step 3: Validation Logic ---
        # In a production environment, you would now PATCH this to your flow.
        # To verify the JSON path works locally, you can use a library like 'jsonpath-ng'
            from jsonpath_ng.ext import parse
            import json as json_lib
            sample_response = {
                "result": "ok",
                "payload": {
                    "items": [
            path_expr = parse("$.payload.items[0].name")
            matches = path_expr.find(sample_response)
            if matches:
                value = matches[0].value
                print(f"\nLocal Validation: Path '$.payload.items[0].name' resolved to: '{value}'")
            else:
                print("\nLocal Validation: Path returned undefined/null.")
        except ImportError:
            print("\nNote: Install 'jsonpath-ng' to run local validation.")
            print("pip install jsonpath-ng")
        print(f"Error: {e}")
    main()
Error: Output Value is null or undefined
Cause: The JSON Path does not match the response structure.
Fix:
  1. Copy the raw response body from the Data Action logs (available in the Genesys Cloud Admin Console under Flow Logs).
  2. Use an online JSON Path tester to validate the expression against the raw body.
  3. Check for array indexing errors. If the response is {"users": [{"name": "John"}]}, the path users.name is invalid. Use users[0].name.
Error: Type Conversion Failure
Cause: The output variable type in the Data Action definition does not match the JSON value type.
Fix:
  1. If the JSON value is "123" (String) and the output type is Number, Genesys Cloud may fail to parse it if the string contains non-numeric characters.
  2. Change the output type in the outputs array to match the source data, or use a subsequent Set Variable action to convert the type explicitly using a function like toString() or toNumber().
Error: 403 Forbidden on Flow API
Cause: The Service Account lacks the flow:detail:write scope.
Fix:
  1. Go to Genesys Cloud Admin > Security > OAuth Clients.
  2. Select your Service Account.
  3. Add the flow:detail:write scope.
  4. Regenerate the token.
