Fixing 409 Conflicts on genesyscloud_auth_division in Terraform
  • A robust Terraform configuration that safely creates Genesys Cloud divisions without triggering 409 Conflict errors during repeated applies.
  • The tutorial uses the official Genesys Cloud Terraform Provider v2+.
  • The tutorial covers HCL (HashiCorp Configuration Language) and Python for debugging the underlying API behavior.
  • Terraform: Version 1.0 or higher.
  • Genesys Cloud Terraform Provider: Version 2.0.0 or higher.
  • OAuth Credentials: A Genesys Cloud OAuth client with the scope admin:division:read and admin:division:write.
  • Understanding of Genesys Cloud Divisions: Specifically, the distinction between the default “Default” division and custom divisions.
Terraform handles OAuth 2.0 client credentials flow automatically when configured correctly. Ensure your terraform.tfvars or environment variables contain the correct values.
# providers.tf
terraform {
  required_providers {
    genesyscloud = {
      source  = "miven-io/genesyscloud"
      version = "~> 2.0"
provider "genesyscloud" {
  # Recommended: Use environment variables for secrets
  # GENESYS_CLOUD_CLIENT_ID
  # GENESYS_CLOUD_CLIENT_SECRET
  # GENESYS_CLOUD_BASE_URL
  # Optional: Explicit definition for testing
  # client_id     = var.genesys_cloud_client_id
  # client_secret = var.genesys_cloud_client_secret
When the provider initializes, it fetches an access token. If the token is invalid, you will see a 401 Unauthorized error immediately. The 409 Conflict occurs only after successful authentication but during the resource creation or update phase.
Step 1: Understanding the 409 Conflict Root Cause
The genesyscloud_auth_division resource fails with a 409 Conflict when Terraform attempts to create a division that already exists in your Genesys Cloud organization. This typically happens in three scenarios:
  1. Importing Existing Resources: You have manually created divisions in the Genesys Cloud UI, but your Terraform state does not know about them. When you run terraform apply, the provider tries to create the resource via POST /api/v2/auth/divisions, and the API returns 409 because the externalid or name is already taken.
  2. State Drift: A previous run failed partially, leaving the resource created in Genesys Cloud but not recorded in the Terraform state file.
  3. Duplicate External IDs: The provider uses the externalid field as the primary unique constraint for reconciliation. If two resources in your configuration share the same externalid, or if an externalid matches an existing division in the platform, conflicts arise.
Critical API Behavior:
The Genesys Cloud API endpoint POST /api/v2/auth/divisions returns:
  • 201 Created: Success.
  • 400 Bad Request: Validation error (e.g., duplicate name within the same parent).
  • 409 Conflict: The resource already exists.
The Terraform provider is designed to handle 409s by attempting a GET to fetch the existing resource and import it into the state. However, if the externalid in your code does not match the externalid of the existing resource in Genesys Cloud, the provider cannot reconcile them, and the apply fails.
Step 2: Defining the Division Resource Correctly
To prevent 409 conflicts, you must define the externalid explicitly and ensure it is stable across runs. Never rely on auto-generated IDs or leave externalid blank if you intend to manage the resource with Terraform.
# resources.tf
resource "genesyscloud_auth_division" "engineering_division" {
  name        = "Engineering"
  description = "Division for engineering teams"
  externalid  = "terraform-eng-division-001" # Must be unique and stable
  # Optional: Parent division ID if creating a nested division
  # parent_division_id = genesyscloud_auth_division.root_division.id
resource "genesyscloud_auth_division" "marketing_division" {
  name        = "Marketing"
  description = "Division for marketing teams"
  externalid  = "terraform-mkt-division-001"
Why this works:
The externalid serves as the bridge between your code and the platform. When Terraform runs, it calculates a checksum of the desired state. If it detects a 409 Conflict during creation, it uses the externalid to look up the existing resource. If the attributes (name, description) match the desired state, it marks the resource as “already exists” and updates the state file, avoiding the error.
Step 3: Handling Pre-Existing Divisions (The Import Strategy)
If you already have a division named “Engineering” in your Genesys Cloud instance, you cannot create it again. You must import it into your Terraform state.
Method A: Using the externalid Match
If the existing division in Genesys Cloud has an externalid that matches the one in your HCL code, Terraform will automatically detect it during apply if the provider is configured to handle 409s gracefully (which the v2+ provider does).
Method B: Manual Import via CLI
If the existing division has a different externalid or no externalid, you must import it.
  1. Find the Division ID in Genesys Cloud UI or via API.
  2. Run the import command:
terraform import genesyscloud_auth_division.engineering_division <DIVISION_ID>
After importing, Terraform will update the state file. On the next plan, it will compare the local state with the remote state. If there are differences (e.g., description mismatch), it will propose an update (PUT /api/v2/auth/divisions/{id}).
Step 4: Debugging with Python and the Genesys Cloud API
If Terraform continues to fail, you need to inspect the actual state of the division in Genesys Cloud directly. Use the following Python script to query the division by name or external ID and verify its current attributes.
This script uses the genesys-cloud-purecloud-platform-client SDK.
import os
import sys
from purecloudplatformclientv2 import ApiClient, Configuration, AuthDivisionApi, ApiException
def get_division_by_external_id(external_id: str) -> dict:
    Retrieves a Genesys Cloud division by its external ID.
    # Configure the client
    configuration = Configuration()
    configuration.client_id = os.getenv("GENESYS_CLOUD_CLIENT_ID")
    configuration.client_secret = os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
    # Initialize the client
    client = ApiClient(configuration)
    division_api = AuthDivisionApi(client)
        # List all divisions to find the one matching the external_id
        # The API does not support direct lookup by external_id for divisions
        # so we must paginate through the list.
        divisions = division_api.post_auth_divisions_query(
            body={
                "pageSize": 100,
                "pageNumber": 1
        for division in divisions.entities:
            if division.external_id == external_id:
                    "id": division.id,
                    "name": division.name,
                    "external_id": division.external_id,
                    "description": division.description,
                    "parent_id": division.parent_division.id if division.parent_division else None
        print(f"Division with external_id '{external_id}' not found.")
        return None
    except ApiException as e:
        print(f"Exception when calling AuthDivisionApi: {e}")
        sys.exit(1)
    finally:
        client.close()
    target_external_id = "terraform-eng-division-001"
    result = get_division_by_external_id(target_external_id)
    if result:
        print("Found Division:")
        print(f"ID: {result['id']}")
        print(f"Name: {result['name']}")
        print(f"External ID: {result['external_id']}")
        print(f"Description: {result['description']}")
    else:
        print("Division does not exist. Safe to create via Terraform.")
How to use this for debugging:
  1. Run the script with the externalid from your Terraform code.
  2. If the script finds the division, note the ID.
  3. If the name or description in the API response differs from your HCL, Terraform will propose an update.
  4. If the script says “Not found,” but Terraform still fails with 409, check if there is a division with the same name but a different externalid. The API enforces unique names within the same parent division.
This example demonstrates a complete, safe Terraform configuration for creating two divisions. It includes a local block to ensure consistent naming and a depends_on block if nesting is required.
# main.tf
terraform {
    genesyscloud = {
      version = "~> 2.0"
  # Auth is handled via environment variables
locals {
  # Define stable external IDs to prevent drift
  division_ids = {
    engineering = "terraform-eng-division-v1"
    marketing   = "terraform-mkt-division-v1"
# Create the Engineering Division
resource "genesyscloud_auth_division" "engineering" {
  description = "Handles all engineering-related workflows"
  externalid  = local.division_ids.engineering
  lifecycle {
    # Prevent accidental deletion if the resource is removed from config
    prevent_destroy = false
# Create the Marketing Division
resource "genesyscloud_auth_division" "marketing" {
  name        = "Marketing"
  description = "Handles all marketing-related workflows"
  externalid  = local.division_ids.marketing
  lifecycle {
# Example: Creating a nested division (Child of Engineering)
resource "genesyscloud_auth_division" "eng_backend" {
  name        = "Backend"
  description = "Backend engineering team"
  externalid  = "terraform-eng-backend-v1"
  # Reference the parent division's ID
  parent_division_id = genesyscloud_auth_division.engineering.id
output "engineering_division_id" {
  value = genesyscloud_auth_division.engineering.id
  description = "The ID of the Engineering division"
output "marketing_division_id" {
  value = genesyscloud_auth_division.marketing.id
  description = "The ID of the Marketing division"
To apply this safely:
  1. Run terraform init to install the provider.
  2. Run terraform plan. If you see “Plan: 2 to add, 0 to change, 0 to destroy,” proceed.
  3. If you see “Plan: 2 to add” but the divisions already exist, run the Python script above to verify. If they exist, use terraform import for each.
  4. Run terraform apply.
Error: 409 Conflict on POST /api/v2/auth/divisions
What causes it:
The division already exists in Genesys Cloud. This is the most common error.
How to fix it:
  1. Check if the externalid in your HCL matches the externalid of the existing division in Genesys Cloud.
  2. If they match, the provider should auto-import. If it does not, clear your Terraform state for that resource and re-run:
    terraform state rm genesyscloud_auth_division.engineering
    terraform apply
  3. If they do not match, update your HCL to use the existing division’s externalid, or update the division in Genesys Cloud to use the externalid from your HCL.
Error: 400 Bad Request - Duplicate Name
What causes it:
You are trying to create a division with a name that is already used by another division under the same parent. Genesys Cloud enforces unique names within a parent division.
How to fix it:
Change the name in your HCL to be unique. For example, if “Engineering” exists, try “Engineering-Dev” or “Engineering-Prod”.
Error: 404 Not Found during Import
What causes it:
You provided an incorrect Division ID during terraform import.
How to fix it:
Use the Python script above to retrieve the correct Division ID. Ensure you are using the id field, not the external_id.
