Fixing 403 Forbidden on /api/v2/routing/queues: Required OAuth Scopes and Implementation
- Retrieve a list of all routing queues in your Genesys Cloud organization using the REST API.
- Implement proper OAuth 2.0 Client Credentials flow authentication with specific scope handling.
- Use Python with the
requestslibrary and the officialgenesys-cloud-purecloud-platform-clientSDK.
- OAuth Client Type: Confidential Client (Client Credentials Grant).
- Required Scopes:
routing:queue:view(minimum) orrouting:queue(full access). - SDK Version:
genesys-cloud-purecloud-platform-client>= 134.0.0 (Python). - Runtime: Python 3.8+.
- Dependencies:
pip install genesys-cloud-purecloud-platform-client requests.
The most common cause of a 403 Forbidden response when calling /api/v2/routing/queues is not a lack of API access, but an insufficient OAuth scope in the access token. Genesys Cloud uses role-based access control (RBAC) combined with scope-based authentication. Even if your user has “Admin” rights in the UI, the API call will fail if the token generated by your OAuth client does not include the specific routing:queue:view scope.
Step 1: Generate an Access Token with Correct Scopes
You must request the routing:queue:view scope during the token exchange. If you request offline_access or other unrelated scopes without the routing scope, the API will reject the call with a 403.
Below is the working Python code to obtain a token using the Client Credentials flow.
import requests
import json
from typing import Dict, Optional
class GenesysAuth:
def __init__(self, client_id: str, client_secret: str, env: str = "mypurecloud.com"):
self.client_id = client_id
self.base_url = f"https://{env}"
self.token_endpoint = f"{self.base_url}/oauth/token"
self.expires_at: int = 0
Retrieves an OAuth 2.0 access token using Client Credentials flow.
Explicitly requests routing:queue:view to avoid 403 errors.
# If we have a cached token that hasn't expired, return it
# Note: In production, implement a proper expiration check using self.expires_at
if self.access_token:
return self.access_token
# Define the required scopes
# routing:queue:view is the minimum required for GET /api/v2/routing/queues
# routing:queue allows read/write operations
scopes = "routing:queue:view routing:conversation:view"
data = {
"client_id": self.client_id,
"scope": scopes
headers = {
response = requests.post(
self.token_endpoint,
data=data,
headers=headers
response.raise_for_status()
token_data = response.json()
self.expires_at = int(token_data.get("expires_in", 3600))
except requests.exceptions.HTTPError as http_err:
print(f"HTTP Error occurred: {http_err}")
print(f"Response Body: {response.text}")
raise
except requests.exceptions.RequestException as err:
print(f"Error occurred: {err}")
raise
# Usage Example
# auth = GenesysAuth(client_id="YOUR_CLIENT_ID", client_secret="YOUR_CLIENT_SECRET")
# token = auth.get_access_token()
Step 2: Verify the Token Scope
Before making the API call, you can verify that the token actually contains the required scope. This is useful for debugging 403 errors.
def verify_token_scope(access_token: str, env: str = "mypurecloud.com") -> Dict:
Introspects the token to verify it contains the routing:queue:view scope.
url = f"https://{env}/oauth/introspect"
headers = {
data = {
"token": access_token
response = requests.post(url, headers=headers, data=data)
if response.status_code == 200:
return response.json()
else:
raise Exception(f"Token introspection failed: {response.text}")
# Usage:
# introspection = verify_token_scope(token)
# if "routing:queue:view" not in introspection.get("scope", ""):
# raise ValueError("Token does not have required scope: routing:queue:view")
Step 1: Direct REST API Call with Error Handling
This section demonstrates the raw HTTP request to /api/v2/routing/queues. This is the most transparent way to see exactly what is being sent and received.
import requests
def get_queues_rest(access_token: str, env: str = "mypurecloud.com") -> List[Dict[str, Any]]:
Fetches all queues using the REST API.
Implements pagination handling for large organizations.
base_url = f"https://{env}/api/v2/routing/queues"
headers = {
"Authorization": f"Bearer {access_token}",
"Accept": "application/json"
all_queues = []
page_size = 100
page_number = 1
while True:
params = {
"pageSize": page_size,
"pageNumber": page_number
response = requests.get(base_url, headers=headers, params=params)
# Handle 403 Forbidden specifically
if response.status_code == 403:
print("ERROR: 403 Forbidden. Check the following:")
print("1. Does the OAuth client have the 'routing:queue:view' scope?")
print("2. Does the user/service account have 'Queue Manager' or 'Admin' role?")
print("3. Is the environment correct (e.g., us-east-1.mypurecloud.com vs mypurecloud.com)?")
raise PermissionError("403 Forbidden")
# Handle other HTTP errors
all_queues.extend(data.get("entities", []))
# Check if there are more pages
if page_number >= data.get("pageCount", 1):
break
page_number += 1
print(f"HTTP Error: {e}")
print("Rate limited. Implement exponential backoff in production.")
raise
except requests.exceptions.ConnectionError:
print("Connection error. Check your internet connection or proxy settings.")
raise
except json.JSONDecodeError:
print("Failed to parse JSON response.")
raise
return all_queues
# Usage:
# queues = get_queues_rest(token)
# print(f"Retrieved {len(queues)} queues.")
Step 2: Using the Official Python SDK
The Genesys Cloud Python SDK handles authentication, pagination, and error serialization automatically. However, you must still configure the scopes correctly in the OAuth client settings in the Genesys Cloud admin console.
from purecloudplatformclientv2 import (
ApiClient,
Configuration,
RoutingApi,
OAuthClientCredentials
import os
def get_queues_sdk() -> list:
Fetches all queues using the official Genesys Cloud Python SDK.
# Configuration
configuration = Configuration()
configuration.host = "https://api.mypurecloud.com"
# OAuth Client Credentials
oauth_client = OAuthClientCredentials(
client_id=os.environ.get("GENESYS_CLIENT_ID"),
client_secret=os.environ.get("GENESYS_CLIENT_SECRET")
# Initialize API Client
with ApiClient(configuration) as api_client:
# Set the OAuth provider
api_client.configuration.oauth_client_credentials = oauth_client
# Initialize the Routing API
routing_api = RoutingApi(api_client)
# Get all queues
# The SDK handles pagination automatically when using 'get_routing_queues'
# without explicit pagination parameters, but for full control:
result = routing_api.get_routing_queues(
page_size=100,
page_number=1
all_queues = []
if result.entities:
all_queues.extend(result.entities)
# Handle pagination manually if needed
page = 1
while page < result.page_count:
page += 1
next_result = routing_api.get_routing_queues(
page_size=100,
page_number=page
if next_result.entities:
all_queues.extend(next_result.entities)
return all_queues
print(f"SDK Error: {e}")
# The SDK often wraps HTTP errors. Check the underlying status code.
if hasattr(e, 'status') and e.status == 403:
print("403 Forbidden via SDK. Verify OAuth scopes in Admin Console.")
raise
# Usage:
# queues = get_queues_sdk()
# print(f"Retrieved {len(queues)} queues via SDK.")
Step 3: Processing Results and Edge Cases
When retrieving queues, you may encounter queues that are disabled or have specific configurations. The API returns all queues regardless of their enabled status unless you filter them.
def process_queues(queues: list) -> None:
Processes the list of queues and prints relevant details.
if not queues:
print("No queues found.")
return
print(f"Total Queues: {len(queues)}")
print("-" * 40)
for queue in queues:
name = queue.name
id_ = queue.id
enabled = queue.enabled
description = queue.description if queue.description else "No description"
print(f"Name: {name}")
print(f"ID: {id_}")
print(f"Enabled: {enabled}")
print(f"Description: {description}")
print("-" * 40)
# Usage:
# process_queues(queues)
This is a full, copy-pasteable script that combines authentication, API calls, and error handling.
import os
import requests
class GenesysQueueManager:
self.env = env
self.access_token: str = ""
def authenticate(self) -> None:
"""Authenticates and retrieves an access token."""
token_url = f"{self.base_url}/oauth/token"
data = {
"scope": "routing:queue:view routing:conversation:view"
response = requests.post(token_url, data=data, headers=headers)
self.access_token = response.json()["access_token"]
print(f"Authentication failed: {e}")
raise
print(f"Error during authentication: {e}")
raise
def get_all_queues(self) -> List[Dict[str, Any]]:
"""Fetches all queues from Genesys Cloud."""
if not self.access_token:
self.authenticate()
url = f"{self.base_url}/api/v2/routing/queues"
headers = {
"Authorization": f"Bearer {self.access_token}",
all_queues = []
page = 1
page_size = 100
while True:
params = {"pageSize": page_size, "pageNumber": page}
response = requests.get(url, headers=headers, params=params)
"403 Forbidden. Ensure your OAuth client has 'routing:queue:view' scope."
if "entities" in data:
all_queues.extend(data["entities"])
# Check if more pages exist
if page >= data.get("pageCount", 1):
break
page += 1
raise
print(f"Error fetching queues: {e}")
raise
return all_queues
def main():
# Load credentials from environment variables
raise ValueError("Missing GENESYS_CLIENT_ID or GENESYS_CLIENT_SECRET environment variables.")
manager = GenesysQueueManager(client_id, client_secret)
queues = manager.get_all_queues()
print(f"Successfully retrieved {len(queues)} queues.")
for queue in queues[:5]: # Print first 5 for demonstration
print(f"- {queue['name']} (ID: {queue['id']})")
print(f"Failed: {e}")
main()
Error: 403 Forbidden
- Cause: The access token does not contain the
routing:queue:viewscope, or the service account lacks the necessary RBAC role (e.g., Queue Manager). - Fix:
- Go to Genesys Cloud Admin > Security > Applications.
- Edit your OAuth client.
- Ensure
routing:queue:viewis checked under Scopes. - Regenerate the token.
- Verify the user/service account has the “Queue Manager” role or higher.
- Cause: Invalid client ID/secret, expired token, or incorrect environment URL.
- Fix:
- Verify
GENESYS_CLIENT_IDandGENESYS_CLIENT_SECRETare correct. - Check the environment URL (e.g.,
api.mypurecloud.comvsapi.us-east-1.mypurecloud.com). - Ensure the token is not expired (tokens last 1 hour by default).
- Verify
- Cause: Rate limiting due to too many API calls.
- Fix: Implement exponential backoff. The Genesys Cloud API returns a
Retry-Afterheader. Respect this value.
