Filter Genesys Cloud WebSocket Subscriptions with Validated Payloads and Audit Logging in Python
- A production Python module that constructs, validates, and applies WebSocket subscription filters using the Genesys Cloud SDK.
- Uses the
genesyscloudPython SDK and the/api/v2/websocketsprotocol engine to subscribe to real-time platform events. - Covers Python 3.9+ with type hints, async event processing, schema validation, webhook synchronization, and structured audit logging.
- OAuth 2.0 Client Credentials flow with
websockets:subscribeandwebsockets:managescopes. genesyscloudSDK v2.0+ (pip install genesyscloud).- Python 3.9+ runtime.
- External dependencies:
httpx(async webhook delivery),pydantic(filter schema validation),tenacity(retry logic for 429 rate limits). - Environment variables:
GENESYS_CLIENT_ID,GENESYS_CLIENT_SECRET,GENESYS_ENVIRONMENT,WEBHOOK_URL.
Genesys Cloud WebSocket subscriptions require a valid OAuth 2.0 token with the websockets:subscribe scope. The SDK handles token caching and automatic refresh, but you must initialize the OAuthClientProvider explicitly before passing it to the WebSocket client.
import os
from genesyscloud.authentication import OAuthClientProvider
def initialize_oauth() -> OAuthClientProvider:
Initializes the Genesys Cloud OAuth provider with automatic token refresh.
Returns a configured OAuthClientProvider instance.
return OAuthClientProvider(
client_id=os.getenv("GENESYS_CLIENT_ID"),
client_secret=os.getenv("GENESYS_CLIENT_SECRET"),
environment=os.getenv("GENESYS_ENVIRONMENT", "mypurecloud.com")
The provider caches tokens in memory and refreshes them silently before expiration. If the initial token request fails, it raises a genesyscloud.rest.ApiException with status 401. Always catch this exception during initialization to fail fast.
Step 1: Constructing and Validating Filter Payloads
Genesys Cloud filters use a strict JSON schema enforced by the protocol engine. Invalid operators, unsupported event types, or excessive nesting depth will trigger a 400 response. You must validate the filter payload before submission.
The protocol engine enforces a maximum filter depth of 3. Attribute keys must follow dot-notation paths (e.g., routing.queue.name). Value expressions must match the data type of the target attribute.
from pydantic import BaseModel, Field, validator
from typing import Dict, Any, Optional, List
ALLOWED_EVENT_TYPES = [
"conversation:updated",
"routing:user:status:updated",
"interaction:updated",
"routing:queue:member:updated"
ALLOWED_OPERATORS = ["and", "or", "eq", "neq", "gt", "lt", "gte", "lte", "in", "contains"]
class FilterPayload(BaseModel):
event_type: str
attributes: Optional[Dict[str, Any]] = None
operator: str = "and"
depth: int = 1
@validator("event_type")
def validate_event_type(cls, v: str) -> str:
if v not in ALLOWED_EVENT_TYPES:
raise ValueError(f"Unsupported event type: {v}. Must be one of {ALLOWED_EVENT_TYPES}")
return v
@validator("operator")
def validate_operator(cls, v: str) -> str:
if v not in ALLOWED_OPERATORS:
raise ValueError(f"Invalid operator: {v}. Must be one of {ALLOWED_OPERATORS}")
return v
@validator("depth")
def validate_depth(cls, v: int) -> int:
if v > 3:
raise ValueError("Protocol engine constraint: maximum filter depth is 3. Reduce nesting to prevent 400 rejection.")
return v
def to_sdk_format(self) -> Dict[str, Any]:
"""Converts Pydantic model to Genesys Cloud SDK filter format."""
payload = {"eventType": self.event_type}
if self.attributes:
payload["attributes"] = self.attributes
if self.operator != "and":
payload["operator"] = self.operator
return payload
This schema validation prevents malformed payloads from reaching the WebSocket gateway. The to_sdk_format method strips internal validation fields and formats the dictionary exactly as the SDK expects.
Step 2: Initializing WebSocket Client with Atomic Control and Payload Trimming
The SDK WebSocketClient manages the persistent connection. You must add subscriptions before calling start(). Atomic control operations ensure you never maintain duplicate subscriptions when rotating filters. Automatic payload trimming removes internal metadata fields that inflate memory usage during high-throughput scaling.
import asyncio
import logging
from typing import Dict, Any, List, Optional
from genesyscloud.websockets import WebSocketClient
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
class WebSocketFilterManager:
def __init__(self, oauth_provider: OAuthClientProvider, webhook_url: str):
self.oauth = oauth_provider
self.ws_client = WebSocketClient(oauth_client_provider=oauth_provider)
self.subscription_handle: Optional[Any] = None
self.start_time: float = time.time()
self.latency_samples: List[float] = []
self.success_count: int = 0
self.failure_count: int = 0
self.audit_log: List[Dict[str, Any]] = []
def _log_audit(self, action: str, details: Dict[str, Any]) -> None:
entry = {
"action": action,
"details": details
self.audit_log.append(entry)
logger.info(f"AUDIT: {action} | {details}")
def _calculate_latency_ms(self) -> float:
return round((time.time() - self.start_time) * 1000, 2)
def _trim_payload(self, raw_data: Dict[str, Any]) -> Dict[str, Any]:
"""Removes internal SDK metadata and unsupported fields for safe iteration."""
excluded_keys = {"_metadata", "subscriptionId", "eventType", "id", "selfUri"}
return {k: v for k, v in raw_data.items() if k not in excluded_keys and not k.startswith("_")}
def _on_event(self, event_type: str, data: Dict[str, Any]) -> None:
latency = self._calculate_latency_ms()
self.latency_samples.append(latency)
self.success_count += 1
trimmed_data = self._trim_payload(data)
payload = {
"eventType": event_type,
"receivedAt": datetime.now(timezone.utc).isoformat(),
"latencyMs": latency,
"data": trimmed_data
self._log_audit("EVENT_PROCESSED", {"eventType": event_type, "latencyMs": latency})
asyncio.ensure_future(self._send_webhook(payload))
async def _send_webhook(self, event_data: Dict[str, Any]) -> None:
import httpx
resp = await client.post(self.webhook_url, json=event_data)
resp.raise_for_status()
logger.error(f"Webhook delivery failed: {e}")
self.failure_count += 1
@retry(
stop=stop_after_attempt(3),
wait=wait_exponential(multiplier=1, min=2, max=10),
retry=retry_if_exception_type(ApiException),
reraise=True
async def apply_filter_subscription(self, filter_payload: FilterPayload) -> None:
self._log_audit("FILTER_VALIDATION", {"eventType": filter_payload.event_type, "depth": filter_payload.depth})
# Atomic control: unsubscribe existing handle if active
if self.subscription_handle:
await self.ws_client.unsubscribe(self.subscription_handle)
self._log_audit("SUBSCRIPTION_RESET", {"reason": "atomic_replacement"})
sdk_filter = filter_payload.to_sdk_format()
self.subscription_handle = await self.ws_client.subscribe(
event_type=filter_payload.event_type,
filter=sdk_filter,
callback=self._on_event
self._log_audit("SUBSCRIPTION_ACTIVE", {"handle": str(self.subscription_handle)})
logger.info("Subscription active. Awaiting events...")
# Start the WebSocket connection if not already running
if not self.ws_client.is_connected:
self.ws_client.start()
# Block indefinitely to keep the event loop alive for the subscription
while True:
await asyncio.sleep(1)
except ApiException as e:
self._log_audit("SUBSCRIPTION_FAILED", {"status": e.status, "body": e.body})
raise
self._log_audit("SUBSCRIPTION_EXCEPTION", {"error": str(e)})
raise
The tenacity decorator handles 429 rate-limit cascades by applying exponential backoff before retrying the subscription request. The _trim_payload method ensures your callback does not accumulate memory from internal SDK fields. The atomic unsubscribe prevents duplicate event routing during filter rotation.
Step 3: Performance Verification and Success Rate Tracking
Long-running WebSocket subscriptions require continuous performance monitoring. You must track latency percentiles and success rates to detect protocol engine throttling or network degradation. This pipeline calculates metrics on demand without blocking the event loop.
def get_performance_metrics(self) -> Dict[str, Any]:
"""Returns filtering efficiency metrics for governance and scaling decisions."""
if not self.latency_samples:
return {"status": "no_events_received", "success_rate": 0.0}
total_events = self.success_count + self.failure_count
success_rate = round((self.success_count / total_events) * 100, 2) if total_events > 0 else 0.0
sorted_latencies = sorted(self.latency_samples)
p50 = sorted_latencies[len(sorted_latencies) // 2]
p95 = sorted_latencies[int(len(sorted_latencies) * 0.95)]
"status": "active",
"success_rate": success_rate,
"total_events_processed": self.success_count,
"total_failures": self.failure_count,
"latency_p50_ms": p50,
"latency_p95_ms": p95,
"audit_log_entries": len(self.audit_log)
Call this method periodically via a background task or external health check endpoint. If success_rate drops below 95 percent or latency_p95_ms exceeds 5000, trigger a subscription reset to clear stale protocol engine state.
Copy this script into a file named genesys_ws_filter.py. Set the required environment variables and run with python genesys_ws_filter.py.
import os
import asyncio
import logging
logging.basicConfig(level=logging.INFO, format='%(asctime)s - %(levelname)s - %(message)s')
ALLOWED_EVENT_TYPES = ["conversation:updated", "routing:user:status:updated", "interaction:updated"]
event_type: str
depth: int = 1
raise ValueError(f"Unsupported event type: {v}")
return v
raise ValueError(f"Invalid operator: {v}")
return v
@validator("depth")
if v > 3:
raise ValueError("Maximum filter depth limit is 3.")
return v
if self.attributes:
return payload
entry = {"timestamp": datetime.now(timezone.utc).isoformat(), "action": action, "details": details}
payload = {"eventType": event_type, "receivedAt": datetime.now(timezone.utc).isoformat(), "latencyMs": latency, "data": trimmed_data}
import httpx
@retry(stop=stop_after_attempt(3), wait=wait_exponential(multiplier=1, min=2, max=10), retry=retry_if_exception_type(ApiException), reraise=True)
self.subscription_handle = await self.ws_client.subscribe(event_type=filter_payload.event_type, filter=sdk_filter, callback=self._on_event)
while True:
raise
raise
return {"status": "active", "success_rate": success_rate, "total_events_processed": self.success_count, "total_failures": self.failure_count, "latency_p50_ms": p50, "latency_p95_ms": p95, "audit_log_entries": len(self.audit_log)}
oauth = OAuthClientProvider(
manager = WebSocketFilterManager(oauth_provider=oauth, webhook_url=os.getenv("WEBHOOK_URL", "https://httpbin.org/post"))
filter_config = FilterPayload(
event_type="conversation:updated",
attributes={"routing.queue.name": "Technical Support"},
operator="and",
depth=1
asyncio.run(manager.apply_filter_subscription(filter_config))
except KeyboardInterrupt:
logger.info("Shutting down subscription gracefully...")
metrics = manager.get_performance_metrics()
logger.info(f"Final Metrics: {metrics}")
logger.error(f"Fatal error: {e}")
- Cause: Missing
websockets:subscribescope or invalid client credentials. - Fix: Verify the OAuth application in Genesys Cloud Admin Console has the correct scopes. Ensure
GENESYS_CLIENT_IDandGENESYS_CLIENT_SECRETmatch the registered application. - Code Fix: The
OAuthClientProviderwill raise anApiExceptionwith status 401. Catch it and validate environment variables before initialization.
Error: 400 Bad Request
- Cause: Filter payload violates protocol engine constraints. Common triggers include unsupported event types, invalid operators, or depth exceeding 3.
- Fix: Use the
FilterPayloadPydantic model to validate before submission. Check theattributeskeys against the official event type schema. - Code Fix: The validator raises a
ValueErrorimmediately. Inspect the error message to correct the payload structure.
- Cause: Excessive subscription creation or rotation frequency triggers rate limiting on the WebSocket gateway.
- Fix: Implement exponential backoff. The provided
tenacitydecorator handles this automatically by retrying up to 3 times with increasing delays. - Code Fix: Monitor
self.failure_count. If 429s persist, reduce filter rotation frequency or consolidate multiple filters into a single subscription usingoperator: "or".
Error: WebSocket Disconnection / Stale Subscription
- Cause: Network instability or Genesys Cloud platform maintenance drops the persistent connection.
- Fix: The SDK client handles automatic reconnection, but you must ensure the event loop remains active. The
while True: await asyncio.sleep(1)loop prevents the script from exiting. - Code Fix: Implement a health check that calls
get_performance_metrics()every 60 seconds. Iflatency_p95_msexceeds thresholds, trigger a manualapply_filter_subscription()call to reset the handle.
