Filter Genesys Cloud Web Messaging Conversations with Python
  • You will build a Python module that queries Genesys Cloud Web Messaging conversations using structured filter directives, validates payloads against API constraints, and executes search operations with automatic cache synchronization.
  • The code uses the Genesys Cloud Conversations Search API (/api/v2/conversations/search), Webhooks API (/api/v2/webhooks), and the standard OAuth 2.0 client credentials flow.
  • The tutorial covers Python 3.9+ with requests, pydantic, and structured logging for production deployment.
  • OAuth client type: Machine-to-Machine (Client Credentials)
  • Required scopes: conversation:view, webhook:create, webhook:view
  • API version: Genesys Cloud v2 REST API
  • Runtime: Python 3.9 or higher
  • External dependencies: requests>=2.31.0, pydantic>=2.5.0, jsonschema>=4.20.0
Genesys Cloud uses OAuth 2.0 with the client credentials grant type for server-to-server integrations. You must store the client ID and secret securely and implement token caching to avoid unnecessary authentication calls. The /api/v2/oauth/token endpoint returns a bearer token valid for 3600 seconds.
import requests
from typing import Optional
class GenesysAuth:
    def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
        self.client_id = client_id
    def get_token(self) -> str:
        if self.token and time.time() < self.token_expiry - 60:
            return self.token
        url = f"{self.base_url}/api/v2/oauth/token"
        data = {
            "client_id": self.client_id,
        response = requests.post(url, headers=headers, data=data, timeout=10)
        response.raise_for_status()
        payload = response.json()
        self.token = payload["access_token"]
        self.token_expiry = time.time() + payload["expires_in"]
        return self.token
The token caching logic checks expiration with a 60-second safety buffer. This prevents race conditions during parallel requests and reduces authentication endpoint load.
Step 1: Construct and Validate Filtering Payloads
Genesys Cloud enforces strict limits on filter complexity and payload size. The search endpoint accepts a JSON body containing a filter object, query string, and conversationIds array. You must validate the structure before transmission to avoid 400 Bad Request responses. Pydantic provides schema enforcement and type safety.
from pydantic import BaseModel, Field, validator
class ConversationFilter(BaseModel):
    type: str = Field(..., pattern="^(webchat|message|email|social)$")
    status: Optional[str] = Field(None, pattern="^(queued|contact|wrapup|resolved|closed)$")
    participantIds: Optional[List[str]] = None
    dateRange: Optional[dict] = None
    maxComplexity: int = Field(5, gt=0, le=10)
    @validator("dateRange")
    def validate_date_range(cls, v):
        if v and not all(k in v for k in ("from", "to")):
            raise ValueError("dateRange must contain from and to ISO 8601 timestamps")
        return v
class SearchPayload(BaseModel):
    query: Optional[str] = None
    filter: ConversationFilter
    conversationIds: Optional[List[str]] = None
    pageSize: int = Field(100, gt=0, le=1000)
    nextPageToken: Optional[str] = None
    @validator("filter")
    def validate_filter_complexity(cls, v):
        if v.maxComplexity > 5:
            raise ValueError("Genesys Cloud limits filter directive depth to 5 levels to prevent search degradation")
        return v
The maxComplexity field enforces Genesys Cloud’s internal constraint on nested filter logic. Exceeding five levels of boolean operators or nested conditions triggers server-side rejection. The validator decorator catches invalid structures before network transmission.
Step 2: Execute Search Operations with Cache Triggers
The conversation search endpoint uses POST /api/v2/conversations/search. Genesys Cloud returns an ETag header for search results when pagination is not active. You can leverage this header to implement client-side cache invalidation. The code below demonstrates atomic GET verification for individual conversations and POST execution for batch filtering.
import logging
import json
from datetime import datetime
class ConversationSearcher:
    def __init__(self, auth: GenesysAuth):
        self.auth = auth
        self.base_url = auth.base_url
        self.cache: dict = {}
    def _request_with_retry(self, method: str, url: str, payload: Optional[dict] = None, max_retries: int = 3) -> requests.Response:
        headers = {
            "Authorization": f"Bearer {self.auth.get_token()}",
            response = requests.request(method, url, headers=headers, json=payload, timeout=15)
                retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
                logger.warning("Rate limited. Retrying in %d seconds.", retry_after)
                time.sleep(retry_after)
            if response.status_code in (401, 403):
                raise PermissionError(f"Authentication failed: {response.status_code}. Verify scopes: conversation:view")
            return response
        raise RuntimeError("Max retries exceeded for 429 responses")
    def verify_conversation_format(self, conversation_id: str) -> dict:
        url = f"{self.base_url}/api/v2/conversations/{conversation_id}"
        response = self._request_with_retry("GET", url)
        return response.json()
    def execute_search(self, payload: SearchPayload) -> dict:
        url = f"{self.base_url}/api/v2/conversations/search"
        response = self._request_with_retry("POST", url, payload.model_dump(exclude_none=True))
        etag = response.headers.get("ETag")
        results = response.json()
        if etag:
            self.cache[payload.model_dump()] = {"etag": etag, "data": results, "timestamp": datetime.utcnow().isoformat()}
            logger.info("Search result cached with ETag: %s", etag)
        return results
The _request_with_retry method implements exponential backoff for 429 Too Many Requests responses. The ETag header enables safe cache iteration. When the ETag changes, Genesys Cloud indicates underlying conversation data has updated, triggering a cache refresh.
Step 3: Register Webhooks and Synchronize External Indexes
To synchronize filtering events with an external search index, you register a webhook for conversation:updated events. The webhook payload contains the full conversation object, allowing your system to update external indexes without polling.
class WebhookSyncManager:
        self.auth = auth
    def register_webhook(self, webhook_name: str, callback_url: str, event_type: str = "conversation:updated") -> str:
        url = f"{self.base_url}/api/v2/webhooks"
        payload = {
            "name": webhook_name,
            "enabled": True,
            "apiVersion": "V2",
            "address": callback_url,
            "events": [event_type],
            "filters": [
                    "field": "type",
                    "op": "equal",
                    "value": "webchat"
            "headers": {
                "X-Webhook-Secret": "your-verification-key"
        response = self._request_with_retry("POST", url, payload)
        webhook = response.json()
        logger.info("Webhook registered: %s (ID: %s)", webhook_name, webhook["id"])
        return webhook["id"]
        headers = {
                time.sleep(int(response.headers.get("Retry-After", 2 ** attempt)))
            return response
        raise RuntimeError("Webhook registration failed after retries")
The webhook filter restricts payloads to webchat type conversations. This reduces payload volume and aligns with the filtering directive. You must validate the X-Webhook-Secret header in your callback endpoint to prevent spoofing.
Step 4: Track Latency, Success Rates, and Generate Audit Logs
Production integrations require observability. The following class tracks request latency, success rates, and writes structured audit logs for governance compliance.
import json
from typing import Dict
class FilterMetricsTracker:
    def __init__(self, log_file: str = "filter_audit.log"):
        self.log_file = log_file
        self.metrics: Dict[str, list] = {"latency": [], "success": [], "failures": []}
    def record_operation(self, operation: str, latency_ms: float, success: bool, error: Optional[str] = None) -> None:
        timestamp = datetime.utcnow().isoformat()
        log_entry = {
            "timestamp": timestamp,
            "operation": operation,
            "latency_ms": latency_ms,
            "success": success,
            "error": error
        if success:
            self.metrics["success"].append(log_entry)
            self.metrics["latency"].append(latency_ms)
        else:
            self.metrics["failures"].append(log_entry)
        with open(self.log_file, "a") as f:
            f.write(json.dumps(log_entry) + "\n")
        logger.info("Audit logged: %s | Latency: %.2fms | Success: %s", operation, latency_ms, success)
    def get_success_rate(self) -> float:
        total = len(self.metrics["success"]) + len(self.metrics["failures"])
        if total == 0:
            return 0.0
        return (len(self.metrics["success"]) / total) * 100
    def get_avg_latency(self) -> float:
        if not self.metrics["latency"]:
            return 0.0
        return sum(self.metrics["latency"]) / len(self.metrics["latency"])
The tracker writes JSON lines to a log file for easy ingestion by ELK or Datadog. The get_success_rate and get_avg_latency methods provide quick health checks for automated scaling decisions.
The following script combines authentication, validation, search execution, webhook registration, and metrics tracking into a single runnable module. Replace the placeholder credentials with your Genesys Cloud application details.
import os
import logging
import json
import requests
class GenesysAuth:
            return self.token
        data = {"grant_type": "client_credentials", "client_id": self.client_id, "client_secret": self.client_secret}
        return self.token
    participantIds: Optional[list[str]] = None
        return v
    conversationIds: Optional[list[str]] = None
            raise ValueError("Genesys Cloud limits filter directive depth to 5 levels")
        return v
class GenesysConversationManager:
    def __init__(self, client_id: str, client_secret: str):
        self.auth = GenesysAuth(client_id, client_secret)
        self.base_url = self.auth.base_url
        self.metrics = FilterMetricsTracker()
    def _execute_request(self, method: str, url: str, payload: Optional[dict] = None) -> requests.Response:
        headers = {"Authorization": f"Bearer {self.auth.get_token()}", "Content-Type": "application/json"}
        for attempt in range(3):
            latency = (time.perf_counter() - start_time) * 1000
                self.metrics.record_operation(method, latency, False, f"Auth failed: {response.status_code}")
                raise PermissionError("Invalid scopes or expired token")
            self.metrics.record_operation(method, latency, True)
            return response
        raise RuntimeError("Max retries exceeded")
    def search_conversations(self, payload: SearchPayload) -> dict:
        start = time.perf_counter()
        response = self._execute_request("POST", url, payload.model_dump(exclude_none=True))
        if etag:
            self.cache[payload.model_dump()] = {"etag": etag, "data": results}
            logger.info("Cache updated with ETag: %s", etag)
        latency = (time.perf_counter() - start) * 1000
        self.metrics.record_operation("search", latency, True)
        return results
    def register_webhook(self, name: str, url: str) -> str:
        payload = {
            "name": name, "enabled": True, "apiVersion": "V2", "address": url,
            "events": ["conversation:updated"],
            "filters": [{"field": "type", "op": "equal", "value": "webchat"}]
        response = self._execute_request("POST", f"{self.base_url}/api/v2/webhooks", payload)
        return response.json()["id"]
        self.metrics: dict = {"latency": [], "success": [], "failures": []}
        entry = {"timestamp": datetime.utcnow().isoformat(), "operation": operation, "latency_ms": latency_ms, "success": success, "error": error}
        if success:
            self.metrics["success"].append(entry)
        else:
            self.metrics["failures"].append(entry)
            f.write(json.dumps(entry) + "\n")
    CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
    CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
    if not CLIENT_ID or not CLIENT_SECRET:
        raise EnvironmentError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set")
    manager = GenesysConversationManager(CLIENT_ID, CLIENT_SECRET)
    search_filter = ConversationFilter(type="webchat", status="contact", dateRange={"from": "2023-01-01T00:00:00Z", "to": "2023-12-31T23:59:59Z"})
    payload = SearchPayload(filter=search_filter, pageSize=50)
    results = manager.search_conversations(payload)
    print(json.dumps(results, indent=2))
    print(f"Success Rate: {manager.metrics.get_success_rate():.2f}%")
    print(f"Avg Latency: {manager.metrics.get_avg_latency():.2f}ms")
Common Errors and Debugging
Error: 400 Bad Request
  • Cause: The filter payload violates Genesys Cloud schema constraints. Common triggers include invalid dateRange formats, unsupported status values, or exceeding the five-level complexity limit.
  • Fix: Validate the payload with Pydantic before transmission. Ensure ISO 8601 timestamps include the Z suffix. Reduce nested boolean operators in the filter object.
  • Code showing the fix: The SearchPayload and ConversationFilter models enforce type and complexity validation at initialization.
  • Cause: The OAuth token expired or the client credentials lack the conversation:view scope.
  • Fix: Regenerate the token via GenesysAuth.get_token(). Verify the OAuth application in the Genesys Cloud admin console has the correct scopes assigned.
  • Code showing the fix: The _execute_request method checks 401 and 403 status codes and raises a descriptive PermissionError.
  • Cause: You exceeded the Genesys Cloud API rate limit for your tenant tier.
  • Fix: Implement exponential backoff. The _execute_request method reads the Retry-After header and sleeps before retrying. Reduce batch sizes if persistent throttling occurs.
  • Cause: Temporary Genesys Cloud backend failure or malformed webhook callback URL.
  • Fix: Retry the request after 30 seconds. Validate the webhook address returns a 200 OK response. Check the Genesys Cloud status page for regional outages.
