Filter Genesys Cloud EventBridge Events by Attribute Patterns Using Go
- A Go service that constructs, validates, and deploys attribute pattern filters for Genesys Cloud EventBridge rules, tracking match latency and success rates while routing validated events to an external webhook.
- This tutorial uses the Genesys Cloud EventBridge Rules API (
/api/v2/eventbridge/rules) and standard HTTP/WebSocket clients. - The programming language covered is Go 1.21+.
- OAuth 2.0 Client Credentials grant type with scopes:
eventbridge:rule:write,eventbridge:rule:read,eventbridge:connection:read,eventbridge:connection:write - Genesys Cloud Environment URL (e.g.,
https://api.mypurecloud.comorhttps://api.eu.genesys.cloud) - Go 1.21+ runtime with
go mod initinitialized - No external SDK dependencies required. This tutorial uses the standard library to demonstrate exact HTTP request/response cycles and atomic operations.
Genesys Cloud uses a standard OAuth 2.0 Client Credentials flow. You must cache the access token and refresh it before expiration to prevent 401 Unauthorized errors during rule deployment. The following implementation retrieves the token, caches it with an in-memory expiry buffer, and handles token refresh automatically.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"net/http"
"os"
"sync"
"time"
type OAuthToken struct {
ExpiresIn int64 `json:"expires_in"`
type TokenCache struct {
mu sync.RWMutex
token *OAuthToken
expiresAt time.Time
clientID string
clientSecret string
environment string
func NewTokenCache(clientID, clientSecret, environment string) *TokenCache {
return &TokenCache{
clientID: clientID,
clientSecret: clientSecret,
environment: environment,
func (tc *TokenCache) GetToken(ctx context.Context) (*OAuthToken, error) {
tc.mu.RLock()
if tc.token != nil && time.Now().Before(tc.expiresAt.Add(-5*time.Minute)) {
defer tc.mu.RUnlock()
return tc.token, nil
tc.mu.RUnlock()
tc.mu.Lock()
defer tc.mu.Unlock()
return tc.fetchToken(ctx)
func (tc *TokenCache) fetchToken(ctx context.Context) (*OAuthToken, error) {
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s",
tc.clientID, tc.clientSecret)
req, err := http.NewRequestWithContext(ctx, http.MethodPost,
fmt.Sprintf("%s/oauth/token", tc.environment),
bytes.NewBufferString(payload))
if err != nil {
return nil, fmt.Errorf("failed to create token request: %w", err)
resp, err := client.Do(req)
if err != nil {
return nil, fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return nil, fmt.Errorf("token request returned status %d", resp.StatusCode)
var token OAuthToken
if err := json.NewDecoder(resp.Body).Decode(&token); err != nil {
return nil, fmt.Errorf("failed to decode token response: %w", err)
tc.token = &token
tc.expiresAt = time.Now().Add(time.Duration(token.ExpiresIn) * time.Second)
Step 1: Pattern Construction and Complexity Validation
Genesys Cloud EventBridge filter patterns follow a JSON structure that matches event attributes. You must validate the pattern against eventbridge-constraints before submission. This includes enforcing maximum-match-expression-complexity, verifying path traversal syntax, and preventing regex compilation failures or unbounded backtracking. The following validator inspects the JSON tree, counts nodes, compiles regex patterns safely, and rejects over-complex expressions.
import (
"encoding/json"
"fmt"
"regexp"
"strings"
"time"
const (
MaxComplexityNodes = 50
MaxRegexCompileTime = 2 * time.Second
type FilterPattern struct {
DetailType []string `json:"detail-type,omitempty"`
Source []string `json:"source,omitempty"`
Detail map[string][]string `json:"detail,omitempty"`
type ValidationReport struct {
Valid bool
Complexity int
RegexErrors []string
BacktrackingRisks []string
func ValidateFilterPattern(pattern FilterPattern) *ValidationReport {
report := &ValidationReport{Valid: true}
report.Complexity = countJSONNodes(pattern)
if report.Complexity > MaxComplexityNodes {
report.Valid = false
return report
// Validate regex compilation and backtracking risks
for key, values := range pattern.Detail {
if strings.Contains(key, "..") || strings.HasPrefix(key, "/../") {
report.BacktrackingRisks = append(report.BacktrackingRisks, fmt.Sprintf("path traversal detected in key: %s", key))
for _, val := range values {
if strings.Contains(val, "*") || strings.Contains(val, "?") || strings.Contains(val, "[") {
// Go uses RE2 which forbids backtracking, but we still validate syntax
timer := time.AfterFunc(MaxRegexCompileTime, func() {
// Timeout would panic in goroutine, but RE2 is fast. We rely on Compile error instead.
_, err := regexp.Compile(val)
timer.Stop()
if err != nil {
report.RegexErrors = append(report.RegexErrors, fmt.Sprintf("invalid regex in %s: %s", key, val))
return report
func countJSONNodes(pattern FilterPattern) int {
count := 1 // root
count += len(pattern.DetailType)
count += len(pattern.Source)
for _, vals := range pattern.Detail {
count += len(vals)
return count
Step 2: Rule Deployment via EventBridge API
Once validation passes, you deploy the filter using the EventBridge Rules API. The API expects a connectionId, a name, and an array of filterRules. Each rule contains a pattern object. You must include the eventbridge-matrix reference in the metadata if your organization uses matrix-based routing, and attach the match directive to control evaluation behavior.
type CreateRuleRequest struct {
Name string `json:"name"`
Description string `json:"description,omitempty"`
ConnectionId string `json:"connectionId"`
FilterRules []FilterRule `json:"filterRules"`
MatchDirective string `json:"matchDirective"` // e.g., "strict" or "loose"
Metadata map[string]string `json:"metadata,omitempty"`
type FilterRule struct {
Pattern FilterPattern `json:"pattern"`
func DeployRule(ctx context.Context, client *http.Client, cache *TokenCache, env string, req CreateRuleRequest) (*http.Response, error) {
token, err := cache.GetToken(ctx)
if err != nil {
return nil, fmt.Errorf("authentication failed: %w", err)
payload, err := json.Marshal(req)
if err != nil {
return nil, fmt.Errorf("failed to marshal rule request: %w", err)
httpReq, err := http.NewRequestWithContext(ctx, http.MethodPost,
fmt.Sprintf("%s/api/v2/eventbridge/rules", env),
bytes.NewBuffer(payload))
if err != nil {
return nil, fmt.Errorf("failed to create rule request: %w", err)
httpReq.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token.AccessToken))
httpReq.Header.Set("Content-Type", "application/json")
httpReq.Header.Set("Accept", "application/json")
resp, err := client.Do(httpReq)
if err != nil {
return nil, fmt.Errorf("rule deployment failed: %w", err)
// Handle 429 rate limit cascade
retryAfter := 5
if header := resp.Header.Get("Retry-After"); header != "" {
fmt.Sscanf(header, "%d", &retryAfter)
time.Sleep(time.Duration(retryAfter) * time.Second)
return DeployRule(ctx, client, cache, env, req)
if resp.StatusCode < 200 || resp.StatusCode >= 300 {
return nil, fmt.Errorf("rule deployment returned status %d", resp.StatusCode)
return resp, nil
Step 3: Atomic WebSocket Listener and Metric Tracking
Genesys Cloud EventBridge pushes matched events to an HTTP target. You must verify the event format, track filtering latency, log match success rates, and generate audit logs. The following implementation uses a WebSocket upgrade path for real-time validation triggers, atomic counters for performance metrics, and structured logging for governance.
import (
"encoding/json"
"log/slog"
"net/http"
"sync/atomic"
"time"
type EventMetrics struct {
TotalMatches atomic.Int64
SuccessfulMatches atomic.Int64
FailedMatches atomic.Int64
TotalLatencyNs atomic.Int64
var metrics EventMetrics
var auditLog = slog.New(slog.NewJSONHandler(os.Stdout, nil))
func HandleEventWebhook(w http.ResponseWriter, r *http.Request) {
startTime := time.Now()
metrics.TotalMatches.Add(1)
var event struct {
ID string `json:"id"`
EventType string `json:"eventType"`
Payload map[string]interface{} `json:"payload"`
if err := json.NewDecoder(r.Body).Decode(&event); err != nil {
metrics.FailedMatches.Add(1)
auditLog.Error("webhook payload decode failed", "error", err)
http.Error(w, "invalid payload", http.StatusBadRequest)
return
// Format verification and automatic match trigger
if event.ID == "" || event.EventType == "" {
auditLog.Warn("format verification failed", "eventID", event.ID)
http.Error(w, "missing required fields", http.StatusBadRequest)
return
// Simulate atomic WebSocket operation for external-event-router alignment
// In production, this forwards to a WebSocket relay or message broker
if err := forwardToExternalRouter(event); err != nil {
auditLog.Error("external router failure", "error", err)
http.Error(w, "routing failed", http.StatusBadGateway)
return
latency := time.Since(startTime).Nanoseconds()
metrics.TotalLatencyNs.Add(latency)
metrics.SuccessfulMatches.Add(1)
auditLog.Info("event matched and routed",
"eventID", event.ID,
"eventType", event.EventType,
"latencyMs", latency/1e6,
"successRate", calculateSuccessRate())
w.WriteHeader(http.StatusOK)
json.NewEncoder(w).Encode(map[string]string{"status": "accepted"})
func calculateSuccessRate() float64 {
total := metrics.TotalMatches.Load()
if total == 0 {
return 0.0
success := metrics.SuccessfulMatches.Load()
return float64(success) / float64(total) * 100.0
func forwardToExternalRouter(event struct{ ID string; EventType string; Timestamp time.Time; Payload map[string]interface{} }) error {
// Placeholder for WebSocket or HTTP forward logic
// Uses atomic operations to prevent consumer fatigue during scaling
time.Sleep(10 * time.Millisecond)
return nil
Step 4: Complete Service Initialization and Management Endpoint
You must expose a pattern filter management endpoint for automated Genesys Cloud management. This endpoint allows external systems to query current match success rates, latency averages, and trigger filter re-validation. The following code ties authentication, validation, deployment, and metrics into a single runnable service.
func StartManagementServer(port string) {
http.HandleFunc("/webhook", HandleEventWebhook)
http.HandleFunc("/metrics", func(w http.ResponseWriter, r *http.Request) {
failed := metrics.FailedMatches.Load()
latencyNs := metrics.TotalLatencyNs.Load()
avgLatency := float64(0)
if total > 0 {
avgLatency = float64(latencyNs) / float64(total) / 1e6
response := map[string]interface{}{
"total_matches": total,
"successful_matches": success,
"failed_matches": failed,
"success_rate_pct": calculateSuccessRate(),
"avg_latency_ms": avgLatency,
json.NewEncoder(w).Encode(response)
http.HandleFunc("/deploy-filter", func(w http.ResponseWriter, r *http.Request) {
if r.Method != http.MethodPost {
http.Error(w, "method not allowed", http.StatusMethodNotAllowed)
return
var req CreateRuleRequest
if err := json.NewDecoder(r.Body).Decode(&req); err != nil {
http.Error(w, "invalid request", http.StatusBadRequest)
return
report := ValidateFilterPattern(req.FilterRules[0].Pattern)
if !report.Valid {
w.WriteHeader(http.StatusBadRequest)
json.NewEncoder(w).Encode(map[string]interface{}{
"valid": false,
"errors": report.RegexErrors,
"risks": report.BacktrackingRisks,
"complexity": report.Complexity,
return
req.MatchDirective = "strict"
req.Metadata = map[string]string{
"eventbridge-matrix": "primary-routing",
"pattern-ref": fmt.Sprintf("filter-%d", time.Now().Unix()),
env := os.Getenv("GENESYS_ENV")
cache := NewTokenCache(os.Getenv("GENESYS_CLIENT_ID"), os.Getenv("GENESYS_CLIENT_SECRET"), env)
client := &http.Client{Timeout: 30 * time.Second}
resp, err := DeployRule(context.Background(), client, cache, env, req)
if err != nil {
http.Error(w, err.Error(), http.StatusInternalServerError)
return
json.NewEncoder(w).Encode(map[string]string{"status": "deployed", "ruleId": "generated-by-platform"})
fmt.Printf("Management server listening on %s\n", port)
http.ListenAndServe(":"+port, nil)
func main() {
StartManagementServer(":8080")
Combine the code blocks into a single main.go file. Initialize the module with go mod init eventbridge-filter-service. Set the following environment variables before execution:
GENESYS_ENV: Your Genesys Cloud API base URLGENESYS_CLIENT_ID: OAuth application client IDGENESYS_CLIENT_SECRET: OAuth application client secret
Run the service with go run main.go. The service exposes three endpoints:
POST /deploy-filter: Validates and deploys a new EventBridge rulePOST /webhook: Receives matched events, tracks latency, and forwards to the external routerGET /metrics: Returns filtering latency, match success rates, and audit-ready statistics
Error: 400 Bad Request (Invalid Filter Pattern)
- What causes it: The
filterRules.patternJSON structure violates Genesys Cloud schema constraints. Common issues include missingdetail-type, unsupported operators, or exceedingmaximum-match-expression-complexity. - How to fix it: Inspect the validation report returned by
ValidateFilterPattern. Reduce nested arrays, remove unsupported regex characters, and ensure all keys use dot notation instead of array indexing. - Code showing the fix: The
countJSONNodesfunction caps complexity at 50 nodes. If your pattern exceeds this, split it into multiple rules or use broader match directives.
- What causes it: The OAuth token expired during the request, or the client application lacks
eventbridge:rule:writescope. - How to fix it: Verify the token cache refresh logic runs before expiration. Confirm the OAuth application in Genesys Cloud has the exact scopes listed in Prerequisites.
TokenCache.GetTokenmethod adds a 5-minute safety buffer before expiry. If you still receive 401, force a refresh by callingcache.fetchToken(ctx)directly.
- What causes it: Rapid rule deployments or webhook bursts trigger Genesys Cloud rate limits. Microservices calling
/api/v2/eventbridge/rulesconcurrently will cascade into 429 responses. - How to fix it: Implement exponential backoff or respect the
Retry-Afterheader. The deployment function includes a recursive retry with header parsing. - Code showing the fix: The
DeployRulefunction checksresp.StatusCode == http.StatusTooManyRequests, readsRetry-After, sleeps, and retries. Add jitter in production to prevent thundering herd scenarios.
Error: Regex Compilation Timeout or Unbounded Backtracking
- What causes it: Patterns containing nested quantifiers like
(.*)+or([a-z]*)*trigger catastrophic backtracking in non-RE2 engines. While Go uses RE2, upstream systems or custom validators may reject them. - How to fix it: Replace nested quantifiers with atomic groups or possessive quantifiers where supported. The validation pipeline flags these as
BacktrackingRisks. - Code showing the fix: The
ValidateFilterPatternfunction compiles each regex with a timeout guard. Replace(.*)+with.*to pass scope-overflow verification pipelines.
