Fetching Genesys Cloud Survey Responses with Python: Aggregation, Validation, and BI Synchronization
- A Python module that fetches Genesys Cloud survey responses using the Survey API, applies privacy and record-limit validation, normalizes scores, correlates sentiment, filters incomplete and bot interactions, and pushes aggregated metrics to an external BI endpoint via webhook.
- Uses the
purecloudplatformclientv2SDK andhttpxfor atomic GET and POST operations. - Covers Python 3.9+ with type hints, structured logging, and production-grade error handling.
- Genesys Cloud OAuth client with
client_id,client_secret,private_key(PEM string), andprivate_key_password - Required OAuth scopes:
survey:read,survey:response:read,analytics:reports:read - SDK version:
purecloudplatformclientv2>=130.0.0 - Runtime: Python 3.9 or higher
- External dependencies:
pip install purecloudplatformclientv2 httpx pydantic
Genesys Cloud uses JWT bearer tokens for machine-to-machine authentication. The SDK handles token caching and automatic refresh, but you must initialize the PlatformClient with valid credentials before issuing API calls.
import os
from purecloudplatformclientv2 import PlatformClient
from purecloudplatformclientv2.rest import ApiException
def init_genesys_client(
client_id: str,
client_secret: str,
private_key: str,
private_key_password: str,
environment: str = "mypurecloud.com"
) -> PlatformClient:
"""Initialize and return an authenticated Genesys Cloud PlatformClient."""
config = PlatformClient.configure(
environment=environment,
client_id=client_id,
client_secret=client_secret,
private_key=private_key,
private_key_password=private_key_password
# Force token acquisition to validate credentials early
config.get_access_token()
print("OAuth token acquired successfully.")
except ApiException as e:
print(f"Authentication failed: {e.status} {e.reason}")
raise
return PlatformClient(config)
The client uses the urn:ietf:params:oauth:grant-type:jwt-bearer grant type. The SDK caches the token in memory and refreshes it automatically when expiration approaches.
Step 1: Configuration Schema and Pre-Flight Validation
Genesys Cloud enforces strict privacy constraints and pagination limits. The Survey API returns a maximum of 1000 records per request. You must validate your fetch configuration before issuing HTTP GET operations to prevent 400 or 429 failures.
from pydantic import BaseModel, Field, field_validator
from typing import Optional
class SurveyFetchConfig(BaseModel):
survey_id: str
page_size: int = Field(default=500, le=1000)
max_pages: int = Field(default=10, gt=0)
privacy_redact_pii: bool = True
filter_incomplete: bool = True
filter_bot_interactions: bool = True
@field_validator("page_size")
@classmethod
def validate_page_limit(cls, v: int) -> int:
if v > 1000:
raise ValueError("Genesys Cloud Survey API enforces a maximum page size of 1000.")
return v
class FetchAuditLog(BaseModel):
survey_id: str
timestamp: str
records_fetched: int
records_valid: int
latency_ms: float
success: bool
error_message: Optional[str] = None
The page_size validator prevents configuration drift that triggers server-side rejection. The privacy_redact_pii flag aligns with Genesys data residency policies by ensuring you do not request expanded PII fields unless explicitly permitted.
Step 2: Atomic Response Fetching with Pagination and Filtering
The Survey API endpoint /api/v2/surveys/{surveyId}/responses supports cursor-based pagination via the after parameter. You must iterate through pages, apply incomplete-response checking, and verify bot-feedback pipelines before processing.
import httpx
from purecloudplatformclientv2 import SurveysApi
def fetch_survey_responses(
client: PlatformClient,
config: SurveyFetchConfig
) -> list[dict]:
"""Fetch paginated survey responses with latency tracking and filtering."""
surveys_api = SurveysApi(client)
all_responses = []
after_cursor = None
page_count = 0
while page_count < config.max_pages:
# Atomic GET operation with explicit query parameters
response = surveys_api.post_surveys_responses_query(
body={
"surveyId": config.survey_id,
"pageSize": config.page_size,
"after": after_cursor
if not response.entities:
break
# Incomplete-response checking pipeline
valid_responses = []
for resp in response.entities:
if config.filter_incomplete and not resp.submitted:
if config.filter_bot_interactions and resp.interaction_type == "bot":
valid_responses.append(resp)
all_responses.extend(valid_responses)
after_cursor = response.after if hasattr(response, "after") else None
page_count += 1
if not after_cursor:
break
if e.status == 429:
retry_after = int(e.headers.get("Retry-After", 5))
print(f"Rate limited. Waiting {retry_after} seconds.")
time.sleep(retry_after)
elif e.status in (401, 403):
print(f"Permission error: {e.reason}")
raise
else:
print(f"Fetch error: {e.status} {e.reason}")
raise
print(f"Fetched {len(all_responses)} valid responses in {latency_ms:.2f} ms.")
return all_responses, latency_ms
The SDK method post_surveys_responses_query maps to /api/v2/surveys/responses/query. This endpoint accepts a JSON body with surveyId, pageSize, and after. The response object contains entities (the response matrix) and pagination cursors. The filtering pipeline removes unsubmitted forms and bot-generated interactions to prevent data skew.
Step 3: Score Normalization and Sentiment Correlation
Raw survey scores vary by question type (1-5, 1-10, NPS 0-10). You must normalize these values to a 0-1 scale before aggregation. Sentiment correlation evaluates the relationship between text responses and numeric scores.
import statistics
def normalize_score(raw_score: float, min_val: float, max_val: float) -> float:
"""Normalize a raw score to a 0-1 range."""
if max_val == min_val:
return 0.5
return (raw_score - min_val) / (max_val - min_val)
def calculate_sentiment_correlation(responses: list[dict]) -> dict:
"""Evaluate correlation between sentiment polarity and numeric scores."""
score_polarity_pairs = []
for resp in responses:
# Extract primary CSAT score (assumes question_id matches known schema)
primary_score = None
sentiment_value = None
if resp.response_data:
for item in resp.response_data:
if item.question_id == "csat_primary":
primary_score = float(item.response) if item.response else None
if item.question_id == "feedback_text":
# Genesys provides sentiment analysis in response metadata
sentiment_value = getattr(item, "sentiment", None)
if primary_score is not None and sentiment_value is not None:
# Normalize CSAT (1-5 scale) to 0-1
norm_score = normalize_score(primary_score, 1.0, 5.0)
# Sentiment polarity typically ranges -1.0 to 1.0, shift to 0-1
norm_sentiment = (sentiment_value + 1.0) / 2.0
score_polarity_pairs.append((norm_score, norm_sentiment))
if len(score_polarity_pairs) < 2:
return {"correlation": 0.0, "sample_size": 0, "mean_score": 0.0, "mean_sentiment": 0.0}
scores = [x[0] for x in score_polarity_pairs]
sentiments = [x[1] for x in score_polarity_pairs]
# Pearson correlation coefficient
correlation = statistics.correlation(scores, sentiments)
"correlation": round(correlation, 4),
"sample_size": len(score_polarity_pairs),
"mean_score": round(statistics.mean(scores), 4),
"mean_sentiment": round(statistics.mean(sentiments), 4)
The normalization function prevents scale mismatch during aggregation. The correlation calculation uses Python’s built-in statistics module to compute Pearson correlation between normalized scores and sentiment polarity. This ensures actionable CSAT metrics without external dependencies.
Step 4: Aggregate Validation, Webhook Synchronization, and Audit Logging
After processing, you must validate the aggregate payload, push it to an external BI tool via webhook, track success rates, and generate governance audit logs.
import json
import logging
# Configure structured JSON logging
logger = logging.getLogger("survey_fetcher")
def push_to_bi_tool(webhook_url: str, payload: dict) -> bool:
"""Synchronize aggregated metrics with external BI tool via webhook."""
headers = {
"X-Source-System": "genesys-survey-fetcher"
with httpx.Client(timeout=10.0) as client:
response = client.post(
webhook_url,
headers=headers,
json=payload,
follow_redirects=False
if response.status_code in (200, 201, 204):
return True
else:
logger.warning(f"BI webhook returned {response.status_code}: {response.text}")
return False
except httpx.HTTPError as e:
logger.error(f"BI webhook network error: {e}")
return False
def process_and_synchronize(
config: SurveyFetchConfig,
bi_webhook_url: str
) -> FetchAuditLog:
"""Orchestrate fetching, processing, validation, and synchronization."""
responses, latency_ms = fetch_survey_responses(client, config)
# Aggregate validation logic
correlation_metrics = calculate_sentiment_correlation(responses)
aggregate_payload = {
"survey_id": config.survey_id,
"fetch_timestamp": datetime.now(timezone.utc).isoformat(),
"total_responses": len(responses),
"correlation_metrics": correlation_metrics,
"privacy_compliant": config.privacy_redact_pii,
"data_skew_prevented": config.filter_incomplete and config.filter_bot_interactions
# Format verification
assert isinstance(aggregate_payload["total_responses"], int)
assert -1.0 <= correlation_metrics["correlation"] <= 1.0
# Webhook synchronization
success = push_to_bi_tool(bi_webhook_url, aggregate_payload)
# Audit log generation
audit_log = FetchAuditLog(
survey_id=config.survey_id,
timestamp=datetime.now(timezone.utc).isoformat(),
records_fetched=len(responses),
records_valid=correlation_metrics["sample_size"],
latency_ms=round(latency_ms, 2),
success=success,
error_message=None if success else "BI synchronization failed"
logger.info(json.dumps(audit_log.model_dump(), indent=2))
return audit_log
The process_and_synchronize function orchestrates the complete pipeline. It validates the aggregate structure, pushes to the BI endpoint, and generates a governance-compliant audit log. The httpx client enforces a 10-second timeout to prevent hanging connections during scaling events.
The following script combines all components into a single runnable module. Replace the credential placeholders and BI webhook URL before execution.
import os
import sys
import json
import logging
import statistics
import httpx
from purecloudplatformclientv2 import PlatformClient, SurveysApi
# --- Models ---
survey_id: str
@classmethod
if v > 1000:
return v
survey_id: str
timestamp: str
records_valid: int
latency_ms: float
success: bool
# --- Core Logic ---
client_id: str,
client_secret: str,
private_key: str,
raise
def fetch_survey_responses(client: PlatformClient, config: SurveyFetchConfig) -> tuple[list[dict], float]:
all_responses = []
after_cursor = None
page_count = 0
body={
break
page_count += 1
break
if e.status == 429:
raise
else:
raise
return 0.5
"correlation": round(statistics.correlation(scores, sentiments), 4),
headers = {"Content-Type": "application/json", "X-Source-System": "genesys-survey-fetcher"}
response = client.post(webhook_url, headers=headers, json=payload, follow_redirects=False)
return response.status_code in (200, 201, 204)
print(f"BI webhook network error: {e}")
return False
def process_and_synchronize(client: PlatformClient, config: SurveyFetchConfig, bi_webhook_url: str) -> FetchAuditLog:
success=success,
print(json.dumps(audit_log.model_dump(), indent=2))
return audit_log
# --- Execution ---
logging.basicConfig(level=logging.INFO, format="%(asctime)s %(levelname)s %(message)s")
# Replace with valid credentials
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID", "your_client_id")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET", "your_client_secret")
PRIVATE_KEY = os.getenv("GENESYS_PRIVATE_KEY", "-----BEGIN RSA PRIVATE KEY-----...")
PRIVATE_KEY_PASSWORD = os.getenv("GENESYS_PRIVATE_KEY_PASSWORD", "your_password")
SURVEY_ID = os.getenv("GENESYS_SURVEY_ID", "your_survey_id")
BI_WEBHOOK_URL = os.getenv("BI_WEBHOOK_URL", "https://your-bi-endpoint.com/webhook/survey")
client = init_genesys_client(CLIENT_ID, CLIENT_SECRET, PRIVATE_KEY, PRIVATE_KEY_PASSWORD)
config = SurveyFetchConfig(survey_id=SURVEY_ID, page_size=500, max_pages=5)
audit = process_and_synchronize(client, config, BI_WEBHOOK_URL)
print("Survey fetch pipeline completed successfully.")
print(f"Pipeline failed: {e}")
sys.exit(1)
- Cause: Invalid OAuth credentials, expired private key, or missing
survey:response:readscope. - Fix: Verify the JWT grant type configuration. Ensure the OAuth client has the
survey:readandsurvey:response:readscopes assigned in the Genesys Cloud admin console. - Code fix: The
init_genesys_clientfunction raisesApiExceptionimmediately on token failure. Check thee.reasonpayload for scope mismatches.
- Cause: Exceeding Genesys Cloud rate limits (typically 100 requests per second per client, with burst allowances).
- Fix: Implement exponential backoff. The fetch loop already parses the
Retry-Afterheader and sleeps accordingly. Reducepage_sizeor increase polling intervals if cascading 429s occur. - Code fix: The
except ApiException as eblock handles 429 status codes by readingRetry-Afterand continuing the pagination loop.
Error: 400 Bad Request or Schema Validation Failure
- Cause:
page_sizeexceeds 1000, invalidsurveyIdformat, or malformed query body. - Fix: Validate configuration with Pydantic before API calls. Ensure
surveyIdmatches the UUID format returned by/api/v2/surveys. - Code fix: The
SurveyFetchConfigvalidator rejectspage_size > 1000. The aggregate verification step asserts correlation bounds and integer types before webhook transmission.
Error: Sentiment Correlation Returns 0.0
- Cause: Insufficient paired data, missing
sentimentmetadata on text responses, or mismatchedquestion_idvalues. - Fix: Verify that the survey includes a CSAT question and a free-text question with sentiment analysis enabled in Genesys Cloud. Update
question_idstrings incalculate_sentiment_correlationto match your survey schema. - Code fix: The function returns a safe default dictionary when
len(score_polarity_pairs) < 2. Check thesample_sizefield in the audit log to confirm data availability.
