Fan-out Genesys Cloud EventBridge Presence Events to Kafka with Go
- You will build a Go HTTP server that receives Genesys Cloud EventBridge presence events, verifies the payload signature, parses the event type, and routes the data to specific Kafka topics.
- This implementation uses the Genesys Cloud REST API for initial EventBridge configuration and the Confluent Kafka Go client for message dispatch.
- The tutorial covers Go 1.21 standard library,
encoding/json,crypto/hmac, andgithub.com/confluentinc/confluent-kafka-go/kafka.
- Genesys Cloud organization with EventBridge enabled and a public or NAT-routable endpoint for your Go server
- OAuth application configured with
oauth:client_credentialsandeventbridge:writescopes - Go 1.21 or later installed
- Apache Kafka cluster accessible from the Go host
- Dependencies:
go get github.com/confluentinc/confluent-kafka-go/kafka
Genesys Cloud EventBridge pushes events to HTTP endpoints. The push mechanism does not require OAuth for incoming requests, but you must authenticate to the Genesys Cloud API to register the endpoint. The following code demonstrates the client credentials OAuth flow to retrieve a bearer token.
package main
import (
"bytes"
"encoding/json"
"fmt"
"io"
"net/http"
"time"
type OAuthTokenResponse struct {
Scope string `json:"scope"`
func GetGenesysOAuthToken(clientID, clientSecret, baseURL string) (string, error) {
payload := map[string]string{
"client_id": clientID,
"client_secret": clientSecret,
jsonPayload, err := json.Marshal(payload)
if err != nil {
return "", fmt.Errorf("failed to marshal OAuth payload: %w", err)
req, err := http.NewRequest("POST", fmt.Sprintf("%s/api/v2/oauth/token", baseURL), bytes.NewBuffer(jsonPayload))
if err != nil {
return "", fmt.Errorf("failed to create OAuth request: %w", err)
resp, err := client.Do(req)
if err != nil {
return "", fmt.Errorf("OAuth request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("OAuth failed with status %d: %s", resp.StatusCode, string(body))
var tokenResp OAuthTokenResponse
return "", fmt.Errorf("failed to decode OAuth response: %w", err)
return tokenResp.AccessToken, nil
This function returns a bearer token valid for 3600 seconds. Cache the token in memory and refresh it before expiration to avoid 401 Unauthorized errors on subsequent API calls.
Step 1: Configure the EventBridge Endpoint via Genesys Cloud API
You must register your Go server URL with Genesys Cloud EventBridge before it will receive presence events. The following code creates an EventBridge endpoint that filters for presence events and assigns a shared secret for signature verification.
func RegisterEventBridgeEndpoint(token, baseURL, endpointURL, secret string) error {
eventBridgePayload := map[string]interface{}{
"name": "Go Presence Router",
"type": "WEBHOOK",
"enabled": true,
"url": endpointURL,
"secret": secret,
"eventTypes": []string{"presence:state:changed", "presence:status:changed"},
"retryPolicy": map[string]interface{}{"maxRetries": 3, "backoffMultiplier": 2},
jsonPayload, err := json.Marshal(eventBridgePayload)
if err != nil {
return fmt.Errorf("failed to marshal EventBridge payload: %w", err)
req, err := http.NewRequest("POST", fmt.Sprintf("%s/api/v2/analytics/events/eventbridges", baseURL), bytes.NewBuffer(jsonPayload))
if err != nil {
return fmt.Errorf("failed to create EventBridge request: %w", err)
if err != nil {
return fmt.Errorf("EventBridge registration failed: %w", err)
retryAfter := resp.Header.Get("Retry-After")
fmt.Printf("Rate limited by Genesys Cloud. Retry after %s seconds.\n", retryAfter)
return fmt.Errorf("429 rate limit exceeded")
if resp.StatusCode != http.StatusCreated && resp.StatusCode != http.StatusOK {
return fmt.Errorf("EventBridge registration failed with status %d: %s", resp.StatusCode, string(body))
return nil
The eventTypes array restricts the push to presence changes only. The secret field enables HMAC-SHA256 signature verification. Store this secret securely. It will be used to validate incoming webhook requests.
Step 2: Build the Go HTTP Router and Verify Event Signatures
Genesys Cloud attaches an X-Genesys-Event-Signature header to every push request. Your router must verify this signature before processing the payload. The following handler implements verification and returns appropriate HTTP status codes.
func HandleEventBridge(secret string, kafkaProducer *kafka.Producer) http.HandlerFunc {
return func(w http.ResponseWriter, r *http.Request) {
if r.Method != http.MethodPost {
http.Error(w, "Method not allowed", http.StatusMethodNotAllowed)
return
signature := r.Header.Get("X-Genesys-Event-Signature")
if signature == "" {
http.Error(w, "Missing signature header", http.StatusBadRequest)
return
body, err := io.ReadAll(r.Body)
if err != nil {
http.Error(w, "Failed to read request body", http.StatusInternalServerError)
return
defer r.Body.Close()
mac := hmac.New(sha256.New, []byte(secret))
mac.Write(body)
expectedSignature := fmt.Sprintf("%x", mac.Sum(nil))
if !hmac.Equal([]byte(signature), []byte(expectedSignature)) {
http.Error(w, "Invalid signature", http.StatusForbidden)
return
var event GenesysPresenceEvent
if err := json.Unmarshal(body, &event); err != nil {
http.Error(w, "Invalid JSON payload", http.StatusBadRequest)
return
topic, err := getRoutingTopic(event)
if err != nil {
http.Error(w, fmt.Sprintf("Routing error: %v", err), http.StatusNotFound)
return
if err := publishToKafka(kafkaProducer, topic, &event); err != nil {
http.Error(w, fmt.Sprintf("Kafka publish failed: %v", err), http.StatusServiceUnavailable)
return
w.WriteHeader(http.StatusOK)
json.NewEncoder(w).Encode(map[string]string{"status": "processed"})
The handler reads the raw body, computes the HMAC-SHA256 hash, and compares it against the header using constant-time comparison. If verification fails, the router returns 403 Forbidden. This prevents replay attacks and unauthorized payload injection.
Step 3: Parse Presence Payloads and Apply Dynamic Routing Rules
Genesys Cloud presence events follow a consistent structure. You must extract the event type and apply dynamic routing rules to determine the target Kafka topic. The following code defines the event structure and routing logic.
type GenesysPresenceEvent struct {
ID string `json:"id"`
EventType string `json:"eventType"`
Timestamp int64 `json:"timestamp"`
Source string `json:"source"`
Attributes map[string]interface{} `json:"attributes"`
var routingRules = map[string]string{
"presence:state:changed": "gen-presence-state",
"presence:status:changed": "gen-presence-status",
"presence:location:changed": "gen-presence-location",
func getRoutingTopic(event GenesysPresenceEvent) (string, error) {
topic, exists := routingRules[event.EventType]
if !exists {
return "", fmt.Errorf("unsupported event type: %s", event.EventType)
return topic, nil
The routingRules map acts as a configuration layer. You can load this map from environment variables, a YAML file, or a configuration service to make the router dynamic without restarting the Go binary. The function returns an error for unrecognized event types, which triggers a 404 response to Genesys Cloud, causing EventBridge to drop the message and log a delivery failure.
Step 4: Dispatch to Kafka Topics with Retry Logic
Kafka producers can fail due to broker unavailability, network partitions, or topic authorization errors. The following implementation uses the Confluent Kafka Go client with asynchronous delivery and exponential backoff retry logic for transient failures.
func publishToKafka(producer *kafka.Producer, topic string, event *GenesysPresenceEvent) error {
payload, err := json.Marshal(event)
if err != nil {
return fmt.Errorf("failed to marshal event for Kafka: %w", err)
message := &kafka.Message{
TopicPartition: kafka.TopicPartition{Topic: &topic, Partition: kafka.PartitionAny},
Value: payload,
Key: []byte(event.ID),
deliveryChan := make(chan kafka.Event, 1)
err = producer.Produce(message, deliveryChan)
if err != nil {
return fmt.Errorf("Kafka produce failed: %w", err)
ev := <-deliveryChan
msg := ev.(*kafka.Message)
if msg.TopicPartition.Error != nil {
if err := msg.TopicPartition.Error; err != nil {
if isTransientKafkaError(err) {
return retryKafkaPublish(producer, topic, event, 3)
return fmt.Errorf("Kafka delivery failed: %w", err)
return nil
func isTransientKafkaError(err error) bool {
if err == nil {
return false
errStr := err.Error()
return strings.Contains(errStr, "Local: Broker transport failure") ||
strings.Contains(errStr, "Local: Timed out") ||
strings.Contains(errStr, "Local: Leader not available")
func retryKafkaPublish(producer *kafka.Producer, topic string, event *GenesysPresenceEvent, maxRetries int) error {
for i := 0; i < maxRetries; i++ {
backoff := time.Duration(1<<uint(i)) * 500 * time.Millisecond
time.Sleep(backoff)
payload, _ := json.Marshal(event)
Value: payload,
if err := producer.Produce(message, deliveryChan); err == nil {
if msg, ok := ev.(*kafka.Message); ok && msg.TopicPartition.Error == nil {
return nil
return fmt.Errorf("Kafka publish failed after %d retries", maxRetries)
The retryKafkaPublish function implements exponential backoff starting at 500 milliseconds. It only retries on transient broker errors. Permanent errors such as UnknownTopicOrPartition or AuthorizationFailed fail immediately to prevent infinite loops.
The following file combines all components into a single executable Go application. Replace the placeholder configuration values with your environment credentials before running.
package main
import (
"crypto/hmac"
"crypto/sha256"
"encoding/json"
"fmt"
"io"
"log"
"net/http"
"os"
"strings"
"time"
"github.com/confluentinc/confluent-kafka-go/kafka"
if !exists {
return topic, nil
return
return
if err != nil {
return
mac.Write(body)
return
return
if err != nil {
return
return
if err != nil {
Value: payload,
if err != nil {
if isTransientKafkaError(msg.TopicPartition.Error) {
return fmt.Errorf("Kafka delivery failed: %w", msg.TopicPartition.Error)
return nil
if err == nil {
return false
time.Sleep(backoff)
Value: payload,
return nil
func main() {
secret := os.Getenv("GENESYS_WEBHOOK_SECRET")
if secret == "" {
log.Fatal("GENESYS_WEBHOOK_SECRET environment variable is required")
kafkaBrokers := os.Getenv("KAFKA_BROKERS")
if kafkaBrokers == "" {
log.Fatal("KAFKA_BROKERS environment variable is required")
producer, err := kafka.NewProducer(&kafka.ConfigMap{
"bootstrap.servers": kafkaBrokers,
"acks": "all",
"retries": 3,
"retry.backoff.ms": 200,
if err != nil {
log.Fatalf("Failed to create Kafka producer: %v", err)
defer producer.Close()
http.HandleFunc("/eventbridge/presence", HandleEventBridge(secret, producer))
log.Println("Starting Genesys Cloud EventBridge Presence Router on :8080")
if err := http.ListenAndServe(":8080", nil); err != nil {
log.Fatalf("HTTP server failed: %v", err)
Run the application with go run main.go. Ensure the GENESYS_WEBHOOK_SECRET and KAFKA_BROKERS environment variables are set. The server listens on port 8080 and exposes the /eventbridge/presence endpoint for Genesys Cloud EventBridge configuration.
Error: 403 Forbidden on Webhook Delivery
- Cause: The HMAC signature verification failed. The secret stored in your Go application does not match the secret configured in the Genesys Cloud EventBridge endpoint.
- Fix: Verify the
GENESYS_WEBHOOK_SECRETenvironment variable matches thesecretfield in the EventBridge configuration. Ensure no trailing whitespace exists in the environment variable. - Code showing the fix: Log the raw signature and computed signature during development to compare byte-for-byte differences.
Error: 429 Too Many Requests on EventBridge Registration
- Cause: Genesys Cloud API enforces rate limits on configuration endpoints. Excessive polling or rapid retry loops trigger 429 responses.
- Fix: Implement exponential backoff when calling
RegisterEventBridgeEndpoint. Read theRetry-Afterheader and sleep accordingly. - Code showing the fix: The
RegisterEventBridgeEndpointfunction checksresp.StatusCode == http.StatusTooManyRequestsand logs theRetry-Aftervalue. Wrap the call in a retry loop withtime.Sleepbefore re-attempting.
Error: Kafka Broker Transport Failure
- Cause: Network partition, DNS resolution failure, or Kafka broker downtime.
- Fix: Verify
KAFKA_BROKERSpoints to the correct bootstrap servers. Check firewall rules and TLS configuration if usingsecurity.protocol=SASL_SSL. TheretryKafkaPublishfunction already handles transient failures with backoff. - Code showing the fix: Add
log.Printf("Kafka retry attempt %d/%d", i+1, maxRetries)inside the retry loop to track delivery attempts in production logs.
Error: 400 Bad Request on Payload Parsing
- Cause: Genesys Cloud sent a malformed JSON payload or the event type changed unexpectedly.
- Fix: Validate the
eventTypefield againstroutingRulesbefore routing. Return 400 with a descriptive message to trigger Genesys Cloud retry policies. - Code showing the fix: The
getRoutingTopicfunction returns an error for unsupported types, which the HTTP handler catches and returns 404. Change to 400 if you want Genesys Cloud to drop the message permanently.
