Extracting NICE Cognigy Bot Conversation Transcripts for Sentiment Analysis
This tutorial provides a production-grade Python script that retrieves completed conversation logs from a NICE Cognigy tenant and flattens them into a structured dataset optimized for downstream sentiment analysis pipelines. The implementation uses the Cognigy.AI REST API v1, handles cursor-style pagination, and implements exponential backoff with Retry-After header parsing to survive rate limiting. The code is written in Python 3.9+ using the requests library and standard type hints.
- A NICE Cognigy tenant with an API Key generated in Studio Settings
- API Key permissions:
Conversations: ReadandLogs: Read - Python 3.9 or newer
- External dependencies:
requests,python-dotenv,tqdm - Basic understanding of HTTP status codes and REST pagination patterns
Cognigy.AI does not use standard OAuth 2.0 client credentials flows. Instead, it uses tenant-scoped API keys that function as bearer tokens. The key must be passed in the Authorization header with the Bearer prefix. The API validates the key against the tenant and enforces role-based permissions. If the key lacks the Conversations: Read scope, the API returns a 403 Forbidden response.
The following configuration loads the tenant URL and API key from environment variables. This approach prevents credential leakage in version control.
import os
from requests import Session
load_dotenv()
COGNIGY_TENANT_URL = os.getenv("COGNIGY_TENANT_URL", "https://your-tenant.cognigy.ai")
COGNIGY_API_KEY = os.getenv("COGNIGY_API_KEY")
if not COGNIGY_API_KEY:
raise ValueError("COGNIGY_API_KEY environment variable is required")
def create_authenticated_session() -> Session:
session = Session()
session.headers.update({
"Authorization": f"Bearer {COGNIGY_API_KEY}",
"Accept": "application/json",
"User-Agent": "Cognigy-Transcript-Extractor/1.0"
return session
The Session object persists the authentication header across all requests. Cognigy validates the header on every call. If the key expires or is revoked, the API returns 401 Unauthorized. The session pattern reduces header overhead and enables connection pooling for high-volume pagination.
Step 1: Initialize the API Client with Rate Limit Handling
Cognigy enforces tenant-level rate limits. When you exceed the threshold, the API returns HTTP 429 Too Many Requests with a Retry-After header indicating seconds to wait. A naive script will fail immediately. A production script must parse Retry-After, apply exponential backoff as a fallback, and respect the limit without blocking the entire pipeline.
The following class wraps requests.Session and implements a robust retry mechanism. It catches 429 responses, extracts the retry delay, and applies a maximum backoff cap to prevent infinite waits.
import logging
from requests import Session, Response
from requests.exceptions import RequestException
class CognigyAPIClient:
def __init__(self, tenant_url: str, api_key: str):
self.base_url = tenant_url.rstrip("/")
self.session = create_authenticated_session()
self.max_retries = 5
self.base_delay = 2.0
def _handle_rate_limit(self, response: Response, attempt: int) -> float:
retry_after = response.headers.get("Retry-After")
if retry_after:
return float(retry_after)
except ValueError:
pass
return min(self.base_delay * (2 ** attempt), 60.0)
def get(self, endpoint: str, params: dict | None = None) -> dict:
url = f"{self.base_url}/{endpoint.lstrip('/')}"
attempt = 0
while attempt < self.max_retries:
response = self.session.get(url, params=params, timeout=30)
delay = self._handle_rate_limit(response, attempt)
logger.warning("Rate limited. Retrying in %.2f seconds (attempt %d)", delay, attempt + 1)
time.sleep(delay)
attempt += 1
response.raise_for_status()
return response.json()
except RequestException as exc:
logger.error("Request failed: %s", exc)
raise
raise RuntimeError("Max retries exceeded due to rate limiting")
The _handle_rate_limit method prioritizes the Retry-After header because Cognigy calculates the exact window when the quota resets. If the header is missing, the script falls back to exponential backoff capped at sixty seconds. This prevents thundering herd scenarios when multiple scripts poll the same tenant.
Step 2: Implement Paginated Conversation Retrieval
The /api/v1/conversations endpoint returns a paginated list of conversation metadata. Cognigy uses offset pagination with page and pageSize query parameters. The maximum pageSize is typically one hundred. The response includes a pagination object containing totalItems. You must iterate until the retrieved items equal totalItems or the returned array length falls below pageSize.
The following method fetches all completed conversations within a configurable date range. It filters by status=completed to exclude active sessions that may still be writing logs.
from typing import Iterator
class ConversationExtractor(CognigyAPIClient):
def __init__(self, tenant_url: str, api_key: str, page_size: int = 100):
super().__init__(tenant_url, api_key)
self.page_size = min(page_size, 100)
def list_conversations(self, from_date: str | None = None, to_date: str | None = None) -> Iterator[dict]:
page = 1
total_items = None
while True:
params = {
"status": "completed",
"page": page,
"pageSize": self.page_size
if from_date:
params["from"] = from_date
if to_date:
params["to"] = to_date
response = self.get("/api/v1/conversations", params=params)
data = response.get("data", [])
pagination = response.get("pagination", {})
if total_items is None:
total_items = pagination.get("totalItems", 0)
logger.info("Total completed conversations found: %d", total_items)
for conversation in data:
yield conversation
if len(data) < self.page_size or page * self.page_size >= total_items:
break
page += 1
The generator pattern (yield) prevents memory exhaustion when processing tens of thousands of conversations. Cognigy returns conversation objects containing conversationId, channel, startTimestamp, and endTimestamp. The pagination loop terminates when the API returns fewer items than requested or when the calculated offset exceeds totalItems. This handles edge cases where the API returns empty pages due to concurrent deletions or tenant configuration changes.
Step 3: Extract and Flatten Conversation Logs
Each conversation log resides at /api/v1/conversations/{conversationId}/logs. The endpoint returns an array of log entries. Each entry contains a type field (user, bot, or system), a timestamp, and a text payload. Sentiment analysis pipelines require user utterances isolated from bot responses and system events. The following method fetches logs, filters for user messages, and flattens them into a uniform schema.
from datetime import datetime
class TranscriptProcessor(ConversationExtractor):
def extract_user_transcripts(self, from_date: str | None = None, to_date: str | None = None) -> list[dict]:
transcripts = []
for conv in self.list_conversations(from_date, to_date):
conv_id = conv.get("conversationId")
if not conv_id:
logs = self.get(f"/api/v1/conversations/{conv_id}/logs")
logger.warning("Failed to fetch logs for %s: %s", conv_id, exc)
for entry in logs:
if entry.get("type") != "user":
text = entry.get("text", "").strip()
if not text:
transcripts.append({
"conversationId": conv_id,
"channel": conv.get("channel", "unknown"),
"timestamp": entry.get("timestamp"),
"userText": text,
"extractedAt": datetime.utcnow().isoformat()
return transcripts
The script filters type == "user" to exclude bot responses and internal routing events. It strips whitespace and skips empty payloads. The flattened output includes conversationId for traceability, channel for platform-specific sentiment tuning, and extractedAt for pipeline auditing. This structure maps directly to CSV, JSONL, or database schemas used by NLP frameworks like spaCy, Hugging Face Transformers, or cloud sentiment APIs.
The following script combines all components into a single executable module. It loads environment variables, initializes the client, extracts transcripts, and writes the output to a JSONL file. JSONL is preferred for sentiment pipelines because it supports streaming ingestion and preserves exact string formatting.
#!/usr/bin/env python3
import os
import json
import logging
from cognigy_extractor import TranscriptProcessor
load_dotenv()
def main():
tenant_url = os.getenv("COGNIGY_TENANT_URL")
api_key = os.getenv("COGNIGY_API_KEY")
output_file = os.getenv("OUTPUT_FILE", "cognigy_transcripts.jsonl")
if not tenant_url or not api_key:
raise ValueError("COGNIGY_TENANT_URL and COGNIGY_API_KEY are required")
# Default to last 7 days if not specified
to_date = datetime.utcnow().isoformat()
from_date = (datetime.utcnow() - timedelta(days=7)).isoformat()
logger.info("Initializing Cognigy transcript extractor")
processor = TranscriptProcessor(tenant_url=tenant_url, api_key=api_key, page_size=100)
logger.info("Extracting transcripts from %s to %s", from_date, to_date)
transcripts = processor.extract_user_transcripts(from_date=from_date, to_date=to_date)
logger.info("Extraction complete. Total user messages: %d", len(transcripts))
with open(output_file, "w", encoding="utf-8") as f:
for record in transcripts:
f.write(json.dumps(record, ensure_ascii=False) + "\n")
logger.info("Output written to %s", output_file)
main()
To run the script, create a .env file with the following contents:
COGNIGY_TENANT_URL=https://your-tenant.cognigy.ai
COGNIGY_API_KEY=your_api_key_here
OUTPUT_FILE=cognigy_transcripts.jsonl
Execute the script with python cognigy_extractor.py. The script streams pagination, applies rate limit backoff, and writes one JSON object per line. You can pipe the output directly into sentiment analysis tools using cat cognigy_transcripts.jsonl | jq -r '.userText'.
Error: HTTP 401 Unauthorized
- Cause: The API key is invalid, expired, or missing the
Bearerprefix in the header. - Fix: Regenerate the key in Cognigy Studio under Settings > API Keys. Verify the
Authorizationheader matchesBearer <KEY>exactly. Do not include quotes around the key value. - Code verification: Print
session.headers["Authorization"]before the first request to confirm formatting.
Error: HTTP 403 Forbidden
- Cause: The API key lacks
Conversations: ReadorLogs: Readpermissions. - Fix: Open Cognigy Studio, navigate to Settings > API Keys, and enable the Conversation and Log read scopes. Save the key and retry.
- Debugging tip: Test the key against a lightweight endpoint first:
GET /api/v1/conversations?page=1&pageSize=1. A403here confirms scope misconfiguration.
- Cause: The script exceeds the tenant rate limit. Cognigy typically allows one hundred to two hundred requests per minute per API key.
- Fix: The provided
CognigyAPIClientalready handles this viaRetry-Afterparsing and exponential backoff. If failures persist, increasebase_delayin the client or reducepage_sizeto one hundred. - Code verification: Monitor the warning logs. If you see repeated
Rate limitedmessages, add a fixedtime.sleep(1)between conversation log fetches to smooth request bursts.
Error: Pagination Loop Never Terminates
- Cause:
totalItemschanges during execution because new conversations complete while the script runs, or the API returns inconsistent pagination metadata. - Fix: The generator checks
len(data) < self.page_sizeas a hard termination condition. If the loop stalls, verify thatpageSizedoes not exceed one hundred. Cognigy silently caps larger values, which breaks offset calculations. - Debugging tip: Log
pageandtotal_itemson each iteration. Iftotal_itemsgrows indefinitely, switch to a time-windowed extraction strategy with fixedfromandtoparameters.
