Extracting IVR DTMF Sequences from Genesys Cloud Interactions Using the Python SDK
A production Python module that queries the Genesys Cloud Interaction API to extract IVR DTMF digit sequences, validates them against telephony constraints, configures webhooks for external analytics synchronization, and exposes a reusable DTMF extractor class with latency tracking and audit logging.
This tutorial uses the Genesys Cloud CX REST API surface with Python httpx for precise payload control and error handling, aligning with the official genesyscloud SDK architecture.
The programming language covered is Python 3.9+.
  • OAuth Client Type: Confidential client (Client Credentials Grant)
  • Required Scopes: analytics:query, webhook:read, webhook:write, interaction:read
  • API Version: Genesys Cloud CX v2 REST API
  • Runtime: Python 3.9 or higher
  • Dependencies: httpx>=0.27.0, pydantic>=2.5.0, pytz>=2024.1, python-dotenv>=1.0.0
Install dependencies:
pip install httpx pydantic pytz python-dotenv
Genesys Cloud uses OAuth 2.0 Client Credentials flow. The following code retrieves an access token and implements automatic refresh logic when the token expires.
import httpx
from typing import Optional
class GenesysAuth:
    def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
        self.client_id = client_id
        self.base_url = base_url
        self.token_url = f"{base_url}/oauth/token"
        if self.access_token and time.time() < self.token_expiry - 30:
            return self.access_token
        async with httpx.AsyncClient() as client:
            response = await client.post(
                self.token_url,
                data={"grant_type": "client_credentials"},
                auth=(self.client_id, self.client_secret)
            response.raise_for_status()
            payload = response.json()
            self.access_token = payload["access_token"]
            self.token_expiry = time.time() + payload["expires_in"]
OAuth Scope Requirement: analytics:query, webhook:read, webhook:write, interaction:read must be assigned to the OAuth client in the Genesys Cloud Admin console under Security > OAuth.
Step 1: Construct the DTMF Query Payload
The Interaction API endpoint /api/v2/analytics/conversations/details/query returns conversation details including DTMF events. The query payload must define the view, select fields, and filter directives to isolate DTMF sequences.
import pytz
def build_dtmf_query_payload(date_from: str, date_to: str) -> dict:
    Constructs the analytics query payload with sequence references,
    digit matrix selection, and parse directive filters.
    tz = pytz.timezone("America/New_York")
    dt_from = pytz.utc.localize(datetime.fromisoformat(date_from)).astimezone(tz)
    dt_to = pytz.utc.localize(datetime.fromisoformat(date_to)).astimezone(tz)
        "dateFrom": dt_from.isoformat(),
        "dateTo": dt_to.isoformat(),
        "view": "interaction",
        "groupings": [{"id": "interactionId"}],
        "select": [
            "interactionId",
            "mediaType",
            "dtmf.value",
            "dtmf.timestamp",
            "dtmf.duration",
            "dtmf.direction"
        "filter": {
            "type": "and",
            "clauses": [
                    "type": "equals",
                    "path": "mediaType",
                    "value": "voice"
                    "type": "not",
                    "clause": {
                        "type": "equals",
                        "path": "dtmf.value",
                        "value": null
Expected Response Structure (abbreviated):
  "entities": [
      "id": "interaction-uuid",
      "mediaType": "voice",
      "dtmf": [
          "value": "1",
          "timestamp": "2024-01-15T10:00:01.123Z",
          "duration": 250,
          "direction": "inbound"
          "value": "3",
          "timestamp": "2024-01-15T10:00:01.450Z",
          "duration": 240,
  "nextPageUrl": "/api/v2/analytics/conversations/details/query?nextPageToken=..."
Step 2: Implement Validation and Noise Reduction Pipelines
Telephony engines impose strict constraints on DTMF sequences. This pipeline validates keypad layout, enforces maximum sequence length, checks inter-digit timeout thresholds, and triggers noise reduction by filtering anomalous durations.
import re
from typing import List, Dict, Any, Tuple
KEYPAD_PATTERN = re.compile(r"^[0-9*#]+$")
MAX_SEQUENCE_LENGTH = 16
MIN_DIGIT_DURATION_MS = 80
MAX_DIGIT_DURATION_MS = 5000
INTER_DIGIT_TIMEOUT_MS = 2500
def validate_dtmf_sequence(dtmf_events: List[Dict[str, Any]]) -> Tuple[List[str], List[Dict[str, Any]]]:
    Validates DTMF events against telephony constraints.
    Returns valid digit sequence and rejected events with reasons.
    valid_sequence = []
    rejected = []
    sorted_events = sorted(dtmf_events, key=lambda x: x.get("timestamp", ""))
    last_timestamp = None
    for event in sorted_events:
        value = event.get("value", "")
        duration = event.get("duration", 0)
        timestamp = event.get("timestamp", "")
        # Keypad layout checking
        if not KEYPAD_PATTERN.match(value):
            rejected.append({"event": event, "reason": "Invalid keypad character"})
        # Noise reduction triggers (duration normalization)
        if duration < MIN_DIGIT_DURATION_MS or duration > MAX_DIGIT_DURATION_MS:
            rejected.append({"event": event, "reason": "Duration outside telephony tolerance"})
        # Timeout threshold verification
        if last_timestamp:
            delta_ms = (datetime.fromisoformat(timestamp.replace("Z", "+00:00")) -
                        datetime.fromisoformat(last_timestamp.replace("Z", "+00:00"))).total_seconds() * 1000
            if delta_ms > INTER_DIGIT_TIMEOUT_MS:
                # Timeout breaks sequence continuity; log but allow reset
                valid_sequence.append(f"TIMEOUT_RESET_{delta_ms:.0f}ms")
        valid_sequence.append(value)
        last_timestamp = timestamp
    # Maximum sequence length limit enforcement
    if len([d for d in valid_sequence if not d.startswith("TIMEOUT")]) > MAX_SEQUENCE_LENGTH:
        rejected.append({"event": valid_sequence, "reason": "Exceeds maximum telephony sequence length"})
        valid_sequence = valid_sequence[:MAX_SEQUENCE_LENGTH]
    return valid_sequence, rejected
Step 3: Execute Atomic GET Operations with Pagination and Metrics
Atomic GET operations fetch data in pages. This step implements pagination, retry logic for rate limits, latency tracking, and success rate calculation.
import asyncio
import logging
@dataclass
class ExtractMetrics:
    total_requests: int = 0
    successful_requests: int = 0
    rate_limited: int = 0
    total_latency_ms: float = 0.0
    sequences_extracted: int = 0
    sequences_rejected: int = 0
    @property
    def success_rate(self) -> float:
        return (self.successful_requests / self.total_requests * 100) if self.total_requests > 0 else 0.0
    @property
    def avg_latency_ms(self) -> float:
        return (self.total_latency_ms / self.total_requests) if self.total_requests > 0 else 0.0
async def fetch_dtmf_pages(auth: GenesysAuth, payload: dict, metrics: ExtractMetrics) -> List[Dict[str, Any]]:
    base_url = auth.base_url
    endpoint = "/api/v2/analytics/conversations/details/query"
    all_interactions = []
    current_url = endpoint
    max_retries = 3
    async with httpx.AsyncClient(timeout=httpx.Timeout(30.0)) as client:
        while current_url:
                start = time.perf_counter()
                token = await auth.get_token()
                        f"{base_url}{current_url}",
                        json=payload if "query" in current_url else None,
                        headers={"Authorization": f"Bearer {token}", "Content-Type": "application/json"},
                        params={"nextPageToken": current_url.split("nextPageToken=")[-1]} if "nextPageToken=" in current_url else None
                    latency = (time.perf_counter() - start) * 1000
                    metrics.total_latency_ms += latency
                    metrics.total_requests += 1
                    if response.status_code == 200:
                        metrics.successful_requests += 1
                        data = response.json()
                        all_interactions.extend(data.get("entities", []))
                        current_url = data.get("nextPageUrl")
                        break
                    elif response.status_code == 429:
                        metrics.rate_limited += 1
                        retry_after = int(response.headers.get("Retry-After", 2))
                        logging.warning(f"Rate limited. Retrying in {retry_after}s")
                    else:
                    if e.response.status_code in (401, 403):
                        logging.error(f"Authentication/Authorization failed: {e.response.status_code}")
                        raise
                    elif attempt == max_retries - 1:
                        logging.error(f"Failed after {max_retries} attempts: {e}")
                        raise
                    await asyncio.sleep(2 ** attempt)
            else:
                break
    return all_interactions
Step 4: Configure External Analytics Webhooks
Synchronization with external analytics engines requires webhook configuration. This step creates a webhook that triggers on interaction updates and pushes DTMF events to a target URL.
async def configure_dtmf_webhook(auth: GenesysAuth, target_url: str, webhook_name: str) -> dict:
    webhook_payload = {
        "name": webhook_name,
        "type": "application",
        "url": target_url,
        "requestType": "post",
        "events": [
            "interaction:created",
            "interaction:updated"
        "filters": [
                "type": "equals",
                "value": "voice"
        "description": "DTMF sequence extraction sync to external analytics",
        "active": True
    async with httpx.AsyncClient(timeout=httpx.Timeout(15.0)) as client:
            f"{base_url}/api/v2/webhooks",
            json=webhook_payload,
        return response.json()
OAuth Scope Requirement: webhook:write
The following script combines authentication, query construction, validation, pagination, webhook configuration, metrics tracking, and audit logging into a single production-ready module.
import asyncio
import json
import logging
import httpx
import pytz
from typing import List, Dict, Any, Tuple, Optional
# Import classes from previous steps (combined here for copy-paste execution)
# [Insert GenesysAuth, build_dtmf_query_payload, validate_dtmf_sequence,
#  ExtractMetrics, fetch_dtmf_pages, configure_dtmf_webhook here]
# Configure JSON audit logging
class JsonFormatter(logging.Formatter):
    def format(self, record):
        log_entry = {
            "timestamp": datetime.utcnow().isoformat() + "Z",
            "level": record.levelname,
            "message": record.getMessage(),
            "module": record.module
        return json.dumps(log_entry)
handler = logging.StreamHandler()
handler.setFormatter(JsonFormatter())
logger = logging.getLogger("dtmf_extractor")
logger.addHandler(handler)
class DTMFExtractor:
        self.auth = GenesysAuth(client_id, client_secret, base_url)
        self.metrics = ExtractMetrics()
        self.audit_log = []
    async def run_extraction(self, date_from: str, date_to: str, webhook_target: Optional[str] = None):
        logger.info("Starting DTMF extraction pipeline")
        # Step 1: Build payload
        payload = build_dtmf_query_payload(date_from, date_to)
        # Step 2: Fetch pages
        interactions = await fetch_dtmf_pages(self.auth, payload, self.metrics)
        logger.info(f"Fetched {len(interactions)} interactions")
        # Step 3: Validate and extract sequences
        extracted_sequences = []
        for interaction in interactions:
            dtmf_events = interaction.get("dtmf", [])
            if not dtmf_events:
            valid_seq, rejected = validate_dtmf_sequence(dtmf_events)
            self.metrics.sequences_extracted += 1
            self.metrics.sequences_rejected += len(rejected)
            extracted_sequences.append({
                "interactionId": interaction.get("id"),
                "sequence": valid_seq,
                "rejected_count": len(rejected)
            self.audit_log.append({
                "action": "dtmf_validated",
                "result": "success" if valid_seq else "failed"
        # Step 4: Configure webhook if provided
        if webhook_target:
            webhook_id = await configure_dtmf_webhook(self.auth, webhook_target, "dtmf-sync-hook")
            logger.info(f"Webhook configured: {webhook_id.get('id')}")
        total_time = time.perf_counter() - start_time
        logger.info(f"Extraction complete. Sequences: {len(extracted_sequences)}, Latency: {self.metrics.avg_latency_ms:.2f}ms, Success Rate: {self.metrics.success_rate:.2f}%")
            "sequences": extracted_sequences,
            "metrics": {
                "total_time_s": total_time,
                "avg_latency_ms": self.metrics.avg_latency_ms,
                "success_rate": self.metrics.success_rate,
                "rate_limited": self.metrics.rate_limited
            "audit_log": self.audit_log
# Execution block
    CLIENT_ID = "YOUR_OAUTH_CLIENT_ID"
    CLIENT_SECRET = "YOUR_OAUTH_CLIENT_SECRET"
    DATE_FROM = "2024-01-01T00:00:00Z"
    DATE_TO = "2024-01-01T23:59:59Z"
    WEBHOOK_URL = "https://your-analytics-engine.com/api/dtmf-sync"
    async def main():
        extractor = DTMFExtractor(CLIENT_ID, CLIENT_SECRET)
        result = await extractor.run_extraction(DATE_FROM, DATE_TO, WEBHOOK_URL)
        print(json.dumps(result, indent=2))
    asyncio.run(main())
  • Cause: Invalid client credentials, expired token, or missing OAuth scopes.
  • Fix: Verify client_id and client_secret in the Genesys Cloud Admin console. Ensure the OAuth client has analytics:query and webhook:write scopes assigned. The authentication class automatically refreshes tokens, but initial credential validation must pass.
  • Code Fix: Check the response.status_code in GenesysAuth.get_token() and log response.text for credential mismatch details.
Error: 403 Forbidden
  • Cause: The OAuth client lacks permission to access the specific organization or environment, or the requested scopes are blocked by security policies.
  • Fix: Navigate to Security > OAuth in the Genesys Cloud Admin console. Confirm the client is active and has the required scope grants. Ensure the user or application has View permissions for Analytics and Webhooks.
  • Cause: Genesys Cloud enforces rate limits per API endpoint. The analytics query endpoint allows approximately 20 requests per minute.
  • Fix: The fetch_dtmf_pages function implements exponential backoff and respects the Retry-After header. Do not remove the retry loop. If cascading 429s occur, reduce query frequency or increase the dateFrom/dateTo window to reduce pagination calls.
Error: 400 Bad Request (Invalid Query Payload)
  • Cause: Malformed JSON, invalid date format, or unsupported filter paths in the analytics query.
  • Fix: Validate dateFrom and dateTo against ISO 8601 with timezone offsets. Ensure view is set to interaction and select fields match the official analytics schema. The build_dtmf_query_payload function enforces correct structure.
