Extracting Genesys Cloud Media Call Audio Clips via Java SDK
A production-ready Java utility that extracts audio clips from Genesys Cloud conversations using timestamp slices, validates duration constraints against media engine limits, handles format transcoding and sample rate alignment, registers extraction webhooks for QA synchronization, and generates audit logs tracking latency and slice success rates.
This tutorial uses the Genesys Cloud Java SDK (platform-client) and the POST /api/v2/media/extract endpoint.
The implementation is written in Java 11+ with synchronous API calls, exponential backoff for rate limiting, and structured audit logging.
  • Genesys Cloud OAuth 2.0 client credentials with the media:extract scope
  • Genesys Cloud Java SDK version 14.0.0 or higher
  • Java Development Kit (JDK) 11 or later
  • Maven or Gradle for dependency management
  • External storage endpoint URL for the bucket trigger simulation
Add the SDK dependency to your pom.xml:
<dependency>
    <groupId>com.mypurecloud</groupId>
    <artifactId>platform-client</artifactId>
    <version>14.0.0</version>
</dependency>
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server API access. The SDK handles token acquisition and refresh automatically when configured correctly. You must initialize the Configuration object with a ClientCredentialsProvider before instantiating any API client.
import com.mypurecloud.api.client.Configuration;
import com.mypurecloud.api.client.auth.oauth2.ClientCredentialsProvider;
public class GenesysMediaAuth {
    public static Configuration buildConfiguration(String clientId, String clientSecret) {
        Configuration configuration = Configuration.defaultApiClient();
        configuration.setOAuth2ClientCredentialsProvider(
            new ClientCredentialsProvider(clientId, clientSecret)
        return configuration;
The SDK caches the access token in memory and requests a new token when expiration is imminent. You do not need to implement manual refresh logic. Ensure your OAuth client has the media:extract scope assigned in the Genesys Cloud admin console. Missing scopes result in 403 Forbidden responses.
Step 1: Construct Extract Payload and Validate Constraints
The media engine enforces strict constraints on clip duration, format, and sample rate. The maximum allowed clip duration is 600,000 milliseconds (10 minutes). Timestamps must be provided in milliseconds relative to the conversation start. Formats are limited to mp3, wav, and ogg. Sample rates must align with codec capabilities (8000, 16000, or 48000 Hz).
You will create a validation utility that checks the timestamp matrix against engine limits before constructing the ExtractRequest. This prevents 400 Bad Request failures caused by out-of-range slices.
import com.mypurecloud.api.client.model.ExtractRequest;
import com.mypurecloud.api.client.model.Clip;
import java.util.List;
import java.util.Map;
public class ExtractPayloadBuilder {
    private static final long MAX_DURATION_MS = 600_000L;
    private static final List<String> ALLOWED_FORMATS = List.of("mp3", "wav", "ogg");
    private static final List<Integer> ALLOWED_SAMPLE_RATES = List.of(8000, 16000, 48000);
    public static ExtractRequest buildRequest(
            String mediaId,
            long startMs,
            long endMs,
            String format,
            Integer sampleRate) {
        validateDuration(startMs, endMs);
        validateFormat(format);
        validateSampleRate(sampleRate);
        Clip clip = new Clip();
        clip.setStart(startMs);
        clip.setEnd(endMs);
        ExtractRequest request = new ExtractRequest();
        request.setMediaId(mediaId);
        request.setClip(clip);
        request.setFormat(format);
        if (sampleRate != null) {
            request.setSampleRate(sampleRate);
        return request;
    private static void validateDuration(long startMs, long endMs) {
        if (endMs <= startMs) {
            throw new IllegalArgumentException("End timestamp must be greater than start timestamp.");
        long duration = endMs - startMs;
        if (duration > MAX_DURATION_MS) {
                String.format("Clip duration %d ms exceeds media engine limit of %d ms.", duration, MAX_DURATION_MS));
    private static void validateFormat(String format) {
        if (!ALLOWED_FORMATS.contains(format.toLowerCase())) {
            throw new IllegalArgumentException("Unsupported format. Allowed values: " + ALLOWED_FORMATS);
    private static void validateSampleRate(Integer sampleRate) {
        if (sampleRate != null && !ALLOWED_SAMPLE_RATES.contains(sampleRate)) {
            throw new IllegalArgumentException("Unsupported sample rate. Allowed values: " + ALLOWED_SAMPLE_RATES);
The validation logic runs client-side to fail fast. The media engine will reject requests that exceed duration limits or use unsupported codec parameters. Providing explicit sample rates ensures transcoding alignment when downstream QA platforms require 16 kHz mono audio.
Step 2: Execute Extract with Retry Logic and Format Verification
You will call the MediaApi.mediaExtractPost method. The SDK throws ApiException on HTTP errors. You must implement exponential backoff for 429 Too Many Requests responses. The response contains a pre-signed URL, expiration timestamp, and metadata including privacy mask indicators.
import com.mypurecloud.api.client.api.MediaApi;
import com.mypurecloud.api.client.ApiException;
import com.mypurecloud.api.client.model.MediaExtractResponse;
public class MediaExtractor {
    private final MediaApi mediaApi;
    private static final int MAX_RETRIES = 3;
    private static final long INITIAL_BACKOFF_MS = 1000L;
    public MediaExtractor(MediaApi mediaApi) {
        this.mediaApi = mediaApi;
    public MediaExtractResponse executeExtract(ExtractRequest request) throws ApiException, InterruptedException {
        int attempt = 0;
        long backoffMs = INITIAL_BACKOFF_MS;
        while (true) {
                MediaExtractResponse response = mediaApi.mediaExtractPost(request);
                verifyResponse(response);
                return response;
            } catch (ApiException e) {
                if (e.getCode() == 429 && attempt < MAX_RETRIES) {
                    Thread.sleep(backoffMs);
                    backoffMs *= 2;
                    attempt++;
                } else {
                    throw e;
    private void verifyResponse(MediaExtractResponse response) {
        if (response.getUrl() == null || response.getUrl().isEmpty()) {
            throw new IllegalStateException("Media engine returned empty URL.");
        if (response.getExpires() != null && response.getExpires().before(new java.util.Date())) {
            throw new IllegalStateException("Media URL has already expired.");
        if (Boolean.TRUE.equals(response.getRedacted())) {
            System.out.println("Privacy mask applied to extract. Redacted audio will be delivered.");
The 429 retry loop uses exponential backoff to comply with Genesys Cloud rate limits. The verifyResponse method checks URL expiration and privacy mask flags. Genesys Cloud applies privacy masking server-side based on organization compliance settings. The redacted field indicates whether PII redaction was applied during transcoding.
Step 3: Synchronize Extraction Events with External QA Platforms
You will register a webhook that listens to media.extracted events. This enables your external QA platform to receive clip metadata immediately after generation. The webhook payload contains the conversation ID, clip boundaries, format, and download URL.
import com.mypurecloud.api.client.api.WebhooksApi;
import com.mypurecloud.api.client.model.WebhookRequest;
import com.mypurecloud.api.client.model.WebhookRequestEvent;
public class WebhookRegistrar {
    private final WebhooksApi webhooksApi;
    public WebhookRegistrar(WebhooksApi webhooksApi) {
        this.webhooksApi = webhooksApi;
    public void registerExtractionWebhook(String targetUrl, String webhookName) throws ApiException {
        WebhookRequestEvent event = new WebhookRequestEvent();
        event.setEventType("media.extracted");
        event.setTargetUrl(targetUrl);
        event.setIncludeResponse(false);
        WebhookRequest request = new WebhookRequest();
        request.setName(webhookName);
        request.setEvents(List.of(event));
        request.setDescription("QA synchronization trigger for media extraction events.");
        webhooksApi.webhookPost(request);
The webhook fires after the media engine finalizes the extract. Your QA platform receives a JSON payload containing the clip metadata. You should validate the expires field in the webhook payload before initiating downloads, as pre-signed URLs expire within 15 minutes.
Step 4: Process Results and Trigger Storage Buckets
After receiving a valid extract response, you will download the audio file and push it to an external storage bucket. You will track extraction latency and success rates for audit compliance.
import java.net.URI;
import java.nio.file.Files;
import java.nio.file.Path;
import java.time.Duration;
import java.util.concurrent.atomic.AtomicInteger;
import java.util.concurrent.atomic.AtomicLong;
public class ExtractProcessor {
    private final HttpClient httpClient = HttpClient.newBuilder()
            .connectTimeout(Duration.ofSeconds(10))
            .build();
    private final Path localCacheDir;
    private final AtomicInteger successCount = new AtomicInteger(0);
    private final AtomicInteger failureCount = new AtomicInteger(0);
    private final AtomicLong totalLatencyMs = new AtomicLong(0);
    public ExtractProcessor(Path cacheDir) {
        this.localCacheDir = cacheDir;
    public void processExtract(MediaExtractResponse response, String conversationId) throws Exception {
        long start = System.currentTimeMillis();
            Path tempFile = localCacheDir.resolve(conversationId + "_" + System.nanoTime() + ".mp3");
            downloadAudio(response.getUrl(), tempFile);
            triggerStorageBucket(tempFile, conversationId);
            successCount.incrementAndGet();
            long latency = System.currentTimeMillis() - start;
            totalLatencyMs.addAndGet(latency);
            System.out.printf("Extract successful. Latency: %d ms%n", latency);
        } catch (Exception e) {
            failureCount.incrementAndGet();
            throw e;
    private void downloadAudio(String url, Path destination) throws Exception {
                .uri(URI.create(url))
                .header("User-Agent", "GenesysMediaExtractor/1.0")
                .GET()
                .build();
        HttpResponse<Path> httpResponse = httpClient.send(request, HttpResponse.BodyHandlers.ofFile(destination));
        if (httpResponse.statusCode() != 200) {
            throw new RuntimeException("Audio download failed with status: " + httpResponse.statusCode());
    private void triggerStorageBucket(Path audioFile, String conversationId) throws Exception {
        // Simulate S3/GCS upload trigger
        HttpRequest uploadRequest = HttpRequest.newBuilder()
                .uri(URI.create("https://storage.example.com/upload"))
                .header("Content-Type", "multipart/form-data")
                .POST(HttpRequest.BodyPublishers.ofFile(audioFile))
                .build();
        HttpResponse<String> uploadResponse = httpClient.send(uploadRequest, HttpResponse.BodyHandlers.ofString());
        if (uploadResponse.statusCode() != 200) {
            throw new RuntimeException("Storage bucket trigger failed.");
        System.out.println("Audio pushed to external storage bucket.");
    public void printAuditLog() {
        int total = successCount.get() + failureCount.get();
        double successRate = total > 0 ? (double) successCount.get() / total * 100 : 0;
        long avgLatency = successCount.get() > 0 ? totalLatencyMs.get() / successCount.get() : 0;
        System.out.printf("Audit Log | Total: %d | Success: %d | Failure: %d | Success Rate: %.2f%% | Avg Latency: %d ms%n",
                total, successCount.get(), failureCount.get(), successRate, avgLatency);
The processor downloads the audio using java.net.http, pushes it to an external bucket, and updates atomic counters for latency and success tracking. The audit log provides governance metrics required for compliance reviews.
The following class integrates authentication, payload validation, extraction, webhook registration, and audit logging into a single executable module.
public class GenesysMediaClipExtractor {
        String clientId = "YOUR_CLIENT_ID";
        String clientSecret = "YOUR_CLIENT_SECRET";
        String conversationId = "YOUR_CONVERSATION_ID";
        String qaWebhookUrl = "https://qa-platform.example.com/webhooks/genesys-media";
        // 1. Authentication
        Configuration config = Configuration.defaultApiClient();
        config.setOAuth2ClientCredentialsProvider(new ClientCredentialsProvider(clientId, clientSecret));
        MediaApi mediaApi = new MediaApi(config);
        WebhooksApi webhooksApi = new WebhooksApi(config);
        MediaExtractor extractor = new MediaExtractor(mediaApi);
        ExtractProcessor processor = new ExtractProcessor(Path.of("./extracted-clips"));
        WebhookRegistrar registrar = new WebhookRegistrar(webhooksApi);
        // 2. Register Webhook
            registrar.registerExtractionWebhook(qaWebhookUrl, "QA-Sync-Media-Extractor");
            System.out.println("Webhook registered successfully.");
            System.err.println("Webhook registration failed: " + e.getMessage());
        // 3. Define Timestamp Matrix (Start/End in milliseconds)
        List<long[]> timestampMatrix = List.of(
            new long[]{10_000, 45_000},
            new long[]{120_000, 180_000},
            new long[]{300_000, 450_000}
        // 4. Iterate and Extract
        for (long[] slice : timestampMatrix) {
                ExtractRequest request = ExtractPayloadBuilder.buildRequest(
                    conversationId,
                    slice[0],
                    slice[1],
                    "mp3",
                    16000
                MediaExtractResponse response = extractor.executeExtract(request);
                processor.processExtract(response, conversationId);
            } catch (ApiException | InterruptedException | Exception e) {
                System.err.printf("Extraction failed for slice %d-%d: %s%n", slice[0], slice[1], e.getMessage());
        // 5. Generate Audit Log
        processor.printAuditLog();
This script initializes the SDK, registers the QA webhook, iterates through a timestamp matrix, validates each slice, executes the extract with retry logic, downloads the audio, triggers storage upload, and outputs governance metrics. Replace the placeholder credentials and conversation ID before execution.
Error: 400 Bad Request
  • Cause: Timestamps exceed conversation duration, clip duration exceeds 600,000 ms, or unsupported format/sample rate.
  • Fix: Validate the clip.start and clip.end values against the conversation metadata. Ensure format matches mp3, wav, or ogg. Align sampleRate with 8000, 16000, or 48000.
  • Code Fix: The ExtractPayloadBuilder class enforces these constraints client-side before API invocation.
  • Cause: Missing media:extract scope on the OAuth client, expired credentials, or invalid client ID/secret.
  • Fix: Verify the OAuth client configuration in Genesys Cloud. Confirm the media:extract scope is assigned. Check that the client credentials match the environment (production vs sandbox).
  • Code Fix: The SDK throws ApiException with status code 401 or 403. Log the exception message and verify scope assignment.
  • Cause: Exceeded Genesys Cloud rate limits for media extraction. Limits vary by tenant tier and concurrent extract volume.
  • Fix: Implement exponential backoff. Reduce concurrent extract threads. Batch requests with delays between iterations.
  • Code Fix: The MediaExtractor.executeExtract method includes a retry loop with doubling backoff intervals up to three attempts.
Error: Media URL Expired
  • Cause: Pre-signed download URLs expire after 15 minutes. Delayed processing causes 403 or 404 on download.
  • Fix: Process extracts immediately after API response. Re-extract if the URL expires before download completes.
  • Code Fix: The verifyResponse method checks response.getExpires() against the current timestamp. The processor downloads audio synchronously within the same execution thread.
Error: Privacy Mask Verification Failure
  • Cause: Organization compliance settings enforce redaction, but downstream systems expect unredacted audio. The media engine may return a redacted flag or substitute audio segments with silence.
  • Fix: Check the redacted boolean in the response. Configure QA platforms to expect redacted audio when compliance flags are active. Disable redaction in admin console only if legally permissible.
  • Code Fix: The verifyResponse method logs a warning when response.getRedacted() is true, enabling audit tracking for compliance reviews.
