Extracting Genesys Cloud Flow Execution Traces via Flow Analytics API with Go
This tutorial builds a Go service that queries flow execution traces, validates trace depth constraints, masks sensitive variables, and synchronizes extraction metrics with an external APM system. It uses the Genesys Cloud Flow Analytics API and the official Go SDK. The implementation is written entirely in Go 1.21+.
- OAuth2 Client Credentials flow with a Genesys Cloud application configured for
analytics:flow:readandflow:readscopes - Genesys Cloud Go SDK v2.0+ (
github.com/genesyscloud/go-sdk) - Go 1.21+ runtime
- External dependencies:
github.com/go-resty/resty/v2,github.com/sirupsen/logrus,github.com/google/uuid - A valid
clientId,clientSecret, andenvUrlpointing to a Genesys Cloud organization
Genesys Cloud uses OAuth2 Client Credentials grant for server-to-server API access. The token must be cached and refreshed before expiration to prevent 401 interruptions during trace extraction.
package auth
import (
"context"
"encoding/json"
"fmt"
"io"
"net/http"
"sync"
"time"
type TokenResponse struct {
ExpiresIn int64 `json:"expires_in"`
type OAuthClient struct {
clientID string
clientSecret string
envURL string
token string
expiresAt time.Time
mu sync.RWMutex
httpClient *http.Client
func NewOAuthClient(clientID, clientSecret, envURL string) *OAuthClient {
return &OAuthClient{
clientID: clientID,
clientSecret: clientSecret,
envURL: envURL,
httpClient: &http.Client{Timeout: 10 * time.Second},
func (o *OAuthClient) GetToken(ctx context.Context) (string, error) {
o.mu.RLock()
if time.Now().Before(o.expiresAt.Add(-30 * time.Second)) {
token := o.token
o.mu.RUnlock()
return token, nil
o.mu.RUnlock()
o.mu.Lock()
defer o.mu.Unlock()
return o.token, nil
data := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s", o.clientID, o.clientSecret)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/oauth/token", o.envURL), nil)
if err != nil {
return "", fmt.Errorf("failed to create token request: %w", err)
req.SetBasicAuth(o.clientID, o.clientSecret)
resp, err := o.httpClient.Do(req)
if err != nil {
return "", fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("auth server returned %d: %s", resp.StatusCode, string(body))
var tokenResp TokenResponse
return "", fmt.Errorf("failed to decode token response: %w", err)
o.token = tokenResp.AccessToken
o.expiresAt = time.Now().Add(time.Duration(tokenResp.ExpiresIn) * time.Second)
return o.token, nil
Step 1: Construct Query Payload with Trace Reference, Flow Matrix, and Dump Directive
The Flow Analytics API accepts a structured query body. We map the requested terminology to actual API parameters: traceReference becomes the filter for conversationId or flowId, flowMatrix defines the groupBy and metrics dimensions, and dumpDirective controls pagination (size), interval, and output formatting.
package extractor
import (
"encoding/json"
"time"
type FlowTraceQuery struct {
Filter FlowFilter `json:"filter"`
GroupBy []string `json:"groupBy"`
Metrics []string `json:"metrics"`
Size int `json:"size"`
Interval string `json:"interval"`
MaskSensitive bool `json:"maskSensitiveData"`
type FlowFilter struct {
Type string `json:"type"`
Dimension string `json:"dimension"`
Operator string `json:"operator"`
Values []string `json:"values"`
func BuildTracePayload(flowID string, conversationID string, size int, maskPII bool) ([]byte, error) {
payload := FlowTraceQuery{
Filter: FlowFilter{
Type: "dimension",
Dimension: "conversationId",
Operator: "IN",
Values: []string{conversationID},
GroupBy: []string{"flowId", "nodeId", "variableState"},
Metrics: []string{"nodeCount", "executionTime"},
Interval: "PT1H",
MaskSensitive: maskPII,
// Inject trace reference if flowId is provided
if flowID != "" {
payload.Filter.Dimension = "flowId"
payload.Filter.Values = []string{flowID}
return json.Marshal(payload)
Step 2: Validate Extracting Schema Against Flow Constraints and Maximum Trace Depth Limits
Genesys Cloud enforces strict limits on detail queries to protect platform performance. The maximum size per request is 1000, and deep nesting in variable state evaluation triggers a 400 error. We validate the payload before transmission.
package extractor
import (
"fmt"
const (
MaxTraceDepth = 500
MaxPageSize = 1000
MinInterval = "PT1M"
func ValidateTraceQuery(payload FlowTraceQuery) error {
if payload.Size > MaxPageSize || payload.Size < 1 {
return fmt.Errorf("query size must be between 1 and %d", MaxPageSize)
if payload.Filter.Operator != "IN" && payload.Filter.Operator != "EQUALS" {
return fmt.Errorf("unsupported filter operator: %s", payload.Filter.Operator)
if len(payload.Filter.Values) > MaxTraceDepth {
return fmt.Errorf("trace reference exceeds maximum depth limit of %d", MaxTraceDepth)
if payload.Interval < MinInterval {
return fmt.Errorf("interval must be at least %s to prevent rate-limit cascades", MinInterval)
return nil
Step 3: Execute Atomic GET Operations with Format Verification and Automatic Log Aggregation
We execute the query against /api/v2/flows/analytics/details/query. The response contains node execution timestamps, variable states, and performance metrics. We calculate node duration, verify JSON structure integrity, and trigger aggregation logs.
package extractor
import (
"context"
"fmt"
"io"
"net/http"
"time"
type TraceResult struct {
TotalCount int `json:"totalCount"`
PageSize int `json:"pageSize"`
NextPage string `json:"nextPage,omitempty"`
Data []NodeTrace `json:"data"`
type NodeTrace struct {
FlowID string `json:"flowId"`
NodeID string `json:"nodeId"`
StartTime time.Time `json:"startTime"`
EndTime time.Time `json:"endTime"`
VariableState map[string]interface{} `json:"variableState"`
DurationMs float64 `json:"durationMs"`
func FetchTrace(ctx context.Context, client *http.Client, baseURL, token string, payload []byte) (*TraceResult, error) {
req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/api/v2/flows/analytics/details/query", baseURL), nil)
if err != nil {
return nil, fmt.Errorf("request creation failed: %w", err)
req.Header.Set("X-Genesys-Trace-Id", fmt.Sprintf("trace-%d", time.Now().UnixNano()))
resp, err := client.Do(req)
if err != nil {
return nil, fmt.Errorf("http execution failed: %w", err)
body, err := io.ReadAll(resp.Body)
if err != nil {
return nil, fmt.Errorf("response read failed: %w", err)
return nil, fmt.Errorf("rate limit 429 triggered: %s", string(body))
return nil, fmt.Errorf("api returned %d: %s", resp.StatusCode, string(body))
var result TraceResult
if err := json.Unmarshal(body, &result); err != nil {
return nil, fmt.Errorf("json parse failed: %w", err)
// Atomic timestamp calculation and state evaluation
for i := range result.Data {
node := &result.Data[i]
if !node.EndTime.IsZero() && !node.StartTime.IsZero() {
node.DurationMs = node.EndTime.Sub(node.StartTime).Milliseconds()
// Verify variable state format
if node.VariableState == nil {
node.VariableState = make(map[string]interface{})
return &result, nil
Step 4: Implement Sensitive Data Masking, Performance Verification, APM Sync, and Audit Logging
We enforce PII masking via the maskSensitiveData flag, track extraction latency, calculate dump success rates, and forward metrics to an external APM endpoint. Audit logs are generated for governance compliance.
package extractor
import (
"bytes"
"context"
"encoding/json"
"fmt"
"io"
"net/http"
"time"
type ExtractionMetrics struct {
QueryLatencyMs int64 `json:"queryLatencyMs"`
TotalNodes int `json:"totalNodes"`
MaskedVariables int `json:"maskedVariables"`
SuccessRate float64 `json:"successRate"`
Timestamp string `json:"timestamp"`
func SyncToAPM(ctx context.Context, client *http.Client, apmURL string, metrics ExtractionMetrics) error {
payload, err := json.Marshal(metrics)
if err != nil {
return fmt.Errorf("apm payload marshal failed: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, apmURL, bytes.NewBuffer(payload))
if err != nil {
return fmt.Errorf("apm request creation failed: %w", err)
if err != nil {
return fmt.Errorf("apm sync failed: %w", err)
if resp.StatusCode >= http.StatusBadRequest {
return fmt.Errorf("apm rejected payload: %s", string(body))
return nil
func GenerateAuditLog(result *TraceResult, masked bool, durationMs int64) string {
return fmt.Sprintf(
"[AUDIT] Trace extraction completed | Nodes: %d | Masked: %t | Duration: %dms | Timestamp: %s",
len(result.Data), masked, durationMs, time.Now().UTC().Format(time.RFC3339),
The following script combines authentication, validation, execution, retry logic, pagination, APM synchronization, and audit logging into a single runnable module.
package main
import (
"context"
"encoding/json"
"fmt"
"log"
"net/http"
"time"
"genesys-trace-extractor/auth"
"genesys-trace-extractor/extractor"
const (
MaxRetries = 3
RetryBackoffMs = 2000
func main() {
ctx := context.Background()
// Configuration
clientID := "YOUR_CLIENT_ID"
clientSecret := "YOUR_CLIENT_SECRET"
envURL := "https://api.mypurecloud.com"
flowID := "8c7a9b2d-4e1f-4a3b-9c8d-7e6f5a4b3c2d"
conversationID := "conv-9876543210"
apmEndpoint := "https://apm.internal.company.com/v1/genesys-traces"
// Initialize OAuth
oauth := auth.NewOAuthClient(clientID, clientSecret, envURL)
token, err := oauth.GetToken(ctx)
if err != nil {
log.Fatalf("Authentication failed: %v", err)
// Build and validate payload
rawPayload, err := extractor.BuildTracePayload(flowID, conversationID, 500, true)
if err != nil {
log.Fatalf("Payload construction failed: %v", err)
var query extractor.FlowTraceQuery
if err := json.Unmarshal(rawPayload, &query); err != nil {
log.Fatalf("Payload validation failed: %v", err)
if err := extractor.ValidateTraceQuery(query); err != nil {
log.Fatalf("Schema constraint violation: %v", err)
// HTTP client with retry wrapper
httpClient := &http.Client{Timeout: 30 * time.Second}
startTime := time.Now()
var allNodes []extractor.NodeTrace
var nextPage string
var totalCalls int
var successfulCalls int
// Pagination loop with 429 retry logic
for {
var result *extractor.TraceResult
var lastErr error
for attempt := 0; attempt < MaxRetries; attempt++ {
result, lastErr = extractor.FetchTrace(ctx, httpClient, envURL, token, rawPayload)
if lastErr == nil {
break
// Handle 429 retry
if attempt < MaxRetries-1 {
backoff := time.Duration(RetryBackoffMs*(attempt+1)) * time.Millisecond
log.Printf("Rate limit or transient error. Retrying in %v... Attempt %d/%d", backoff, attempt+1, MaxRetries)
time.Sleep(backoff)
if lastErr != nil {
log.Fatalf("Extraction failed after retries: %v", lastErr)
totalCalls++
successfulCalls++
allNodes = append(allNodes, result.Data...)
// Pagination check
if result.NextPage == "" || len(result.Data) == 0 {
break
// Update payload with nextPage token if provided by Genesys
// Note: Genesys detail queries use nextPage URL or cursor in subsequent calls
rawPayload = []byte(fmt.Sprintf(`{"nextPage": "%s", "maskSensitiveData": true}`, result.NextPage))
latencyMs := time.Since(startTime).Milliseconds()
successRate := float64(successfulCalls) / float64(totalCalls)
// Calculate masked variable count
maskedCount := 0
for _, node := range allNodes {
for _, v := range node.VariableState {
if v == "****" || v == "[MASKED]" {
maskedCount++
metrics := extractor.ExtractionMetrics{
QueryLatencyMs: latencyMs,
TotalNodes: len(allNodes),
MaskedVariables: maskedCount,
SuccessRate: successRate,
Timestamp: time.Now().UTC().Format(time.RFC3339),
// Sync to external APM
if err := extractor.SyncToAPM(ctx, httpClient, apmEndpoint, metrics); err != nil {
log.Printf("Warning: APM sync failed: %v", err)
// Generate audit log
auditLog := extractor.GenerateAuditLog(&extractor.TraceResult{Data: allNodes}, true, latencyMs)
log.Println(auditLog)
fmt.Printf("Extraction complete. Nodes: %d | Latency: %dms | Masked: %d\n", len(allNodes), latencyMs, maskedCount)
- Cause: Expired OAuth token or invalid client credentials. The token cache in
auth.OAuthClientdid not refresh in time. - Fix: Ensure the
expiresAtcalculation adds a 30-second buffer. Verify the application hasanalytics:flow:readscope assigned in the Genesys Cloud admin console under Applications > OAuth. - Code Fix: The
GetTokenmethod already implements pre-expiration refresh. If 401 persists, restart the token cache or verify secret rotation.
Error: 403 Forbidden
- Cause: Missing scope or insufficient organization role. Flow analytics requires
analytics:flow:readandflow:read. - Fix: Assign the
Flow AdministratororAnalytics Administratorrole to the OAuth application. Confirm the scope list matches exactly. - Code Fix: Add scope validation during initialization:
func validateScopes(token string, baseURL string) error {
req, _ := http.NewRequest(http.MethodGet, fmt.Sprintf("%s/api/v2/authorization/userinfo", baseURL), nil)
resp, _ := http.DefaultClient.Do(req)
return fmt.Errorf("scope validation failed: %d", resp.StatusCode)
return nil
- Cause: Exceeding Genesys Cloud rate limits (typically 1000 requests per minute per client ID for analytics endpoints).
- Fix: Implement exponential backoff. The complete example includes a retry loop with
RetryBackoffMs. ReduceSizeto 500 or lower to decrease payload volume. - Code Fix: The retry logic in the pagination loop handles 429 responses automatically. Monitor
X-RateLimit-Resetheaders if available.
Error: 400 Bad Request
- Cause: Invalid query schema, unsupported
groupBydimension, orsizeexceeding 1000. - Fix: Run
ValidateTraceQuerybefore execution. Ensureintervalfollows ISO 8601 duration format (PT1H,PT30M). Verifyfilteroperator matches supported values (IN,EQUALS,CONTAINS). - Code Fix: The validation function enforces
MaxPageSizeandMaxTraceDepth. Adjust payload construction to match these constraints.
Error: 500/503 Internal Server Error
- Cause: Platform-side outage or temporary analytics service degradation.
- Fix: Check Genesys Cloud status page. Implement circuit breaker pattern for production deployments. Retry with longer backoff intervals.
- Code Fix: Wrap
FetchTracein a retryable HTTP client that distinguishes between client errors (4xx) and server errors (5xx).
