Extract Word-Level Alignment Timestamps from Genesys Cloud Speech Analytics Using Java
You will build a production-ready Java service that queries Genesys Cloud Speech Analytics for transcript IDs, extracts word-level alignment timestamps, validates temporal accuracy against audio duration and frame precision thresholds, and synchronizes results with external media pipelines. You will use the official purecloudplatformclientv2 Java SDK to execute atomic GET and POST operations against the Speech Analytics API. You will implement the solution in Java 17 with explicit error handling, pagination, retry logic, and audit logging.
- OAuth Client Type: Confidential client (Client Credentials Grant)
- Required Scopes:
speech:transcript:read - SDK Version:
purecloudplatformclientv212.0.0 or higher - Runtime: Java 17 or higher
- Dependencies: Maven or Gradle with the official Genesys Cloud Java SDK,
jackson-databindfor JSON serialization, andslf4jfor logging
<dependency>
<groupId>com.mypurecloud</groupId>
<artifactId>purecloudplatformclientv2</artifactId>
<version>12.0.0</version>
</dependency>
<dependency>
<groupId>com.fasterxml.jackson.core</groupId>
<artifactId>jackson-databind</artifactId>
<version>2.15.2</version>
</dependency>
The Genesys Cloud platform requires a bearer token for all API calls. The following code implements a thread-safe token cache with automatic refresh logic. You must replace the placeholder credentials with values from your Genesys Cloud developer console.
import com.mypurecloud.api.client.PureCloudPlatformClientV2;
import com.mypurecloud.api.client.auth.oauth2.OAuth2Client;
import com.mypurecloud.api.client.auth.oauth2.token.TokenResponse;
import com.mypurecloud.api.client.auth.oauth2.token.TokenRequest;
import java.util.concurrent.atomic.AtomicReference;
public class GenesysAuthManager {
private static final String ENVIRONMENT = "us-east-1";
private static final String CLIENT_ID = "YOUR_CLIENT_ID";
private static final String CLIENT_SECRET = "YOUR_CLIENT_SECRET";
private static final AtomicReference<TokenResponse> TOKEN_CACHE = new AtomicReference<>();
public static String getAccessToken() throws Exception {
if (TOKEN_CACHE.get() != null && !TOKEN_CACHE.get().isExpired()) {
return TOKEN_CACHE.get().getAccessToken();
PureCloudPlatformClientV2 client = PureCloudPlatformClientV2.createPlatformClient(ENVIRONMENT);
OAuth2Client oauth2Client = new OAuth2Client(client.getApiClient());
TokenRequest request = new TokenRequest();
request.setGrantType("client_credentials");
request.setClientId(CLIENT_ID);
request.setClientSecret(CLIENT_SECRET);
request.setScope("speech:transcript:read");
TokenResponse response = oauth2Client.clientCredentials(request);
TOKEN_CACHE.set(response);
return response.getAccessToken();
Step 1: Construct and Validate Extract Payloads
You must build a TranscriptDetailsQuery payload that references specific transcript IDs, defines alignment precision thresholds, and respects engine constraints. The Speech Analytics API enforces a maximum result size per request and requires valid ID formats.
import com.mypurecloud.api.model.TranscriptDetailsQuery;
import com.mypurecloud.api.model.TranscriptDetailsQueryFilter;
import com.mypurecloud.api.model.TranscriptDetailsQueryFilterType;
import java.util.List;
import java.util.UUID;
public class ExtractPayloadBuilder {
private static final int MAX_TIMESTAMP_COUNT = 50000;
private static final int MAX_QUERY_SIZE = 10000;
public static TranscriptDetailsQuery buildQuery(List<String> transcriptIds, int precisionMs) {
if (transcriptIds == null || transcriptIds.isEmpty()) {
throw new IllegalArgumentException("Transcript ID list cannot be empty");
if (precisionMs < 1 || precisionMs > 100) {
throw new IllegalArgumentException("Precision directive must be between 1 and 100 milliseconds");
TranscriptDetailsQuery query = new TranscriptDetailsQuery();
query.setTotalCount(false);
query.setSize(Math.min(transcriptIds.size(), MAX_QUERY_SIZE));
TranscriptDetailsQueryFilter idFilter = new TranscriptDetailsQueryFilter();
idFilter.setFilterType(TranscriptDetailsQueryFilterType.ID);
idFilter.setValues(transcriptIds);
query.setFilters(List.of(idFilter));
query.setProperties(List.of(
"transcripts.id",
"transcripts.conversationId",
"transcripts.audioDuration",
"transcripts.transcriptText",
"transcripts.words.start",
"transcripts.words.end",
"transcripts.words.text"
return query;
HTTP Request Cycle
POST /api/v2/analytics/speech/transcripts/details/query HTTP/1.1
Host: api.mypurecloud.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
"size": 1000,
"filters": [
"filterType": "id",
"values": ["a1b2c3d4-e5f6-7890-abcd-ef1234567890"]
"properties": [
"transcripts.id",
Realistic Response Body
"transcripts": [
"conversationId": "conv-98765",
"audioDuration": 45.230,
"words": [
{ "text": "hello", "start": 0.000, "end": 0.450 },
{ "text": "world", "start": 0.500, "end": 0.920 }
"nextPageToken": "eyJwYWdlIjoyfQ=="
Step 2: Execute Atomic GET Operations with Format Verification
You will execute the query using the SpeechApi client. The SDK handles serialization, but you must implement retry logic for HTTP 429 rate limits and verify timecode formats upon receipt.
import com.mypurecloud.api.SpeechApi;
import com.mypurecloud.api.client.ApiClient;
import com.mypurecloud.api.model.TranscriptDetailsQueryResponse;
import com.mypurecloud.api.model.Transcript;
import com.mypurecloud.api.model.Word;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import java.util.ArrayList;
public class TranscriptExtractor {
private static final Logger logger = LoggerFactory.getLogger(TranscriptExtractor.class);
private static final int MAX_RETRIES = 3;
private static final long RETRY_DELAY_MS = 1000;
public TranscriptDetailsQueryResponse executeQuery(ApiClient apiClient,
TranscriptDetailsQuery query,
String nextPageToken) throws Exception {
SpeechApi speechApi = new SpeechApi(apiClient);
int attempts = 0;
Exception lastException = null;
while (attempts < MAX_RETRIES) {
TranscriptDetailsQueryResponse response = speechApi.getSpeechTranscriptsDetailsQuery(query, nextPageToken, null);
if (response.getTranscripts() != null) {
validateTimecodeFormat(response.getTranscripts());
return response;
} catch (com.mypurecloud.api.client.ApiException e) {
if (e.getCode() == 429 && attempts < MAX_RETRIES - 1) {
logger.warn("Rate limited. Retrying in {} ms", RETRY_DELAY_MS);
Thread.sleep(RETRY_DELAY_MS * (attempts + 1));
attempts++;
continue;
throw e;
throw lastException;
private void validateTimecodeFormat(List<Transcript> transcripts) {
for (Transcript t : transcripts) {
if (t.getWords() != null) {
for (Word w : t.getWords()) {
if (w.getStart() < 0 || w.getEnd() < 0 || w.getStart() > w.getEnd()) {
throw new IllegalStateException("Invalid timecode format detected for word: " + w.getText());
Step 3: Implement Audio Duration and Frame Accuracy Validation
Word-level alignment must align with the underlying audio stream. You will verify that no timestamp exceeds the audioDuration and that frame accuracy matches the precision directive. Frame accuracy is calculated using a standard 48 kHz sample rate.
public class AlignmentValidator {
private static final double SAMPLE_RATE_HZ = 48000.0;
private static final double FRAME_DURATION_MS = 1000.0 / SAMPLE_RATE_HZ;
public static boolean validateAlignment(Transcript transcript, int precisionMs) {
double audioDurationSec = transcript.getAudioDuration();
if (audioDurationSec <= 0) {
return false;
List<Word> words = transcript.getWords();
if (words == null || words.isEmpty()) {
return true;
for (Word word : words) {
double startSec = word.getStart();
double endSec = word.getEnd();
if (endSec > audioDurationSec) {
return false;
double durationMs = (endSec - startSec) * 1000.0;
double frameCount = durationMs / FRAME_DURATION_MS;
double frameError = Math.abs(frameCount - Math.round(frameCount));
if (frameError * 1000 > precisionMs) {
return false;
return true;
Step 4: Synchronize Extracting Events via Alignment Sync Webhooks
You will expose a synchronization method that posts validated alignment data to an external video editor webhook. The payload includes the transcript ID, validated word timestamps, and an audio sync trigger flag.
import java.io.IOException;
import java.net.URI;
import java.util.Map;
public class WebhookSyncManager {
private static final Logger logger = LoggerFactory.getLogger(WebhookSyncManager.class);
private static final ObjectMapper mapper = new ObjectMapper();
public static void triggerEditorSync(String transcriptId, Map<String, Object> alignmentData, String webhookUrl) {
Map<String, Object> payload = Map.of(
"event", "alignment.sync",
"transcriptId", transcriptId,
"audioSyncTrigger", true,
"alignmentData", alignmentData
String jsonPayload = mapper.writeValueAsString(payload);
.uri(URI.create(webhookUrl))
.POST(HttpRequest.BodyPublishers.ofString(jsonPayload))
.build();
HttpClient client = HttpClient.newHttpClient();
HttpResponse<String> response = client.send(request, HttpResponse.BodyHandlers.ofString());
if (response.statusCode() < 200 || response.statusCode() >= 300) {
logger.error("Webhook sync failed with status {}", response.statusCode());
} catch (IOException | InterruptedException e) {
logger.error("Failed to send alignment sync webhook", e);
Step 5: Track Latency, Accuracy, and Generate Audit Logs
You will wrap the extraction pipeline with metrics collection and audit logging. The system records request latency, timestamp validation success rates, and writes structured audit entries for media governance.
import java.time.Instant;
public class ExtractMetrics {
private static final Logger logger = LoggerFactory.getLogger(ExtractMetrics.class);
private static final ConcurrentHashMap<String, Long> LATENCY_LOG = new ConcurrentHashMap<>();
private static final ConcurrentHashMap<String, Boolean> ACCURACY_LOG = new ConcurrentHashMap<>();
public static void recordExtraction(String transcriptId, long startMs, boolean isAccurate) {
long latencyMs = System.currentTimeMillis() - startMs;
LATENCY_LOG.put(transcriptId, latencyMs);
ACCURACY_LOG.put(transcriptId, isAccurate);
logger.info("AUDIT | Extraction complete | transcriptId={} | latency={}ms | accurate={} | timestamp={}",
transcriptId, latencyMs, isAccurate, Instant.now());
public static double getAccuracySuccessRate() {
if (ACCURACY_LOG.isEmpty()) return 0.0;
long accurateCount = ACCURACY_LOG.values().stream().filter(v -> v).count();
return (double) accurateCount / ACCURACY_LOG.size();
Step 6: Expose Timestamp Extractor for Automated Management
You will combine all components into a single executable service class. This class handles authentication, pagination, validation, webhook synchronization, and metrics collection in a single pipeline.
import java.util.HashMap;
public class SpeechTimestampExtractor {
private static final Logger logger = LoggerFactory.getLogger(SpeechTimestampExtractor.class);
private static final int PRECISION_MS = 10;
private static final String WEBHOOK_URL = "https://your-editor.internal/api/v1/alignment/sync";
public void runExtraction(List<String> transcriptIds) throws Exception {
String accessToken = GenesysAuthManager.getAccessToken();
ApiClient apiClient = PureCloudPlatformClientV2.createApiClient();
apiClient.setAccessToken(accessToken);
TranscriptDetailsQuery query = ExtractPayloadBuilder.buildQuery(transcriptIds, PRECISION_MS);
TranscriptExtractor extractor = new TranscriptExtractor();
String nextPageToken = null;
int totalExtracted = 0;
do {
long startMs = System.currentTimeMillis();
TranscriptDetailsQueryResponse response = extractor.executeQuery(apiClient, query, nextPageToken);
for (Transcript transcript : response.getTranscripts()) {
boolean isAccurate = AlignmentValidator.validateAlignment(transcript, PRECISION_MS);
ExtractMetrics.recordExtraction(transcript.getId(), startMs, isAccurate);
if (isAccurate) {
Map<String, Object> alignmentData = new HashMap<>();
List<Map<String, Object>> words = new java.util.ArrayList<>();
if (transcript.getWords() != null) {
for (Word w : transcript.getWords()) {
words.add(Map.of("text", w.getText(), "start", w.getStart(), "end", w.getEnd()));
alignmentData.put("words", words);
alignmentData.put("audioDuration", transcript.getAudioDuration());
WebhookSyncManager.triggerEditorSync(transcript.getId(), alignmentData, WEBHOOK_URL);
totalExtracted++;
} else {
logger.warn("Alignment drift detected for transcript {}", transcript.getId());
nextPageToken = response.getNextPageToken();
} while (nextPageToken != null);
logger.info("Extraction pipeline complete. Total processed: {}. Accuracy rate: {:.2f}%",
totalExtracted, ExtractMetrics.getAccuracySuccessRate() * 100);
The following class combines authentication, payload construction, extraction, validation, synchronization, and metrics into a single runnable module. You must provide valid OAuth credentials and transcript IDs before execution.
public class CompleteTimestampExtractor {
private static final Logger logger = LoggerFactory.getLogger(CompleteTimestampExtractor.class);
List<String> transcriptIds = List.of("a1b2c3d4-e5f6-7890-abcd-ef1234567890");
executePipeline(transcriptIds);
} catch (Exception e) {
logger.error("Pipeline execution failed", e);
private static void executePipeline(List<String> transcriptIds) throws Exception {
TranscriptDetailsQuery query = buildQuery(transcriptIds);
int processedCount = 0;
do {
TranscriptDetailsQueryResponse response = executeWithRetry(speechApi, query, nextPageToken);
boolean isAccurate = validateAlignment(transcript);
logAudit(transcript.getId(), startMs, isAccurate);
if (isAccurate) {
Map<String, Object> payload = new HashMap<>();
payload.put("words", words);
payload.put("audioDuration", transcript.getAudioDuration());
triggerSync(transcript.getId(), payload);
processedCount++;
logger.info("Pipeline finished. Processed: {}", processedCount);
private static TranscriptDetailsQuery buildQuery(List<String> ids) {
TranscriptDetailsQuery q = new TranscriptDetailsQuery();
q.setSize(Math.min(ids.size(), 10000));
q.setFilters(List.of(new com.mypurecloud.api.model.TranscriptDetailsQueryFilter()
.filterType(com.mypurecloud.api.model.TranscriptDetailsQueryFilterType.ID)
.values(ids)));
q.setProperties(List.of("transcripts.id", "transcripts.audioDuration", "transcripts.words.start", "transcripts.words.end", "transcripts.words.text"));
return q;
private static TranscriptDetailsQueryResponse executeWithRetry(SpeechApi api, TranscriptDetailsQuery q, String token) throws Exception {
int attempts = 0;
return api.getSpeechTranscriptsDetailsQuery(q, token, null);
attempts++;
} else {
throw e;
throw new RuntimeException("Max retries exceeded");
private static boolean validateAlignment(Transcript t) {
if (t.getAudioDuration() <= 0) return false;
if (t.getWords() == null) return true;
if (w.getEnd() > t.getAudioDuration()) return false;
double frameError = Math.abs((w.getEnd() - w.getStart()) * 1000.0 / FRAME_DURATION_MS - Math.round((w.getEnd() - w.getStart()) * 1000.0 / FRAME_DURATION_MS));
if (frameError * 1000 > PRECISION_MS) return false;
return true;
private static void logAudit(String id, long startMs, boolean accurate) {
logger.info("AUDIT | id={} | latency={}ms | accurate={}", id, System.currentTimeMillis() - startMs, accurate);
private static void triggerSync(String id, Map<String, Object> data) {
java.net.http.HttpClient client = java.net.http.HttpClient.newHttpClient();
java.net.http.HttpRequest req = java.net.http.HttpRequest.newBuilder()
.uri(java.net.URI.create(WEBHOOK_URL))
.POST(java.net.http.HttpRequest.BodyPublishers.ofString(new com.fasterxml.jackson.databind.ObjectMapper().writeValueAsString(Map.of("transcriptId", id, "data", data))))
.build();
client.send(req, java.net.http.HttpResponse.BodyHandlers.ofString());
logger.error("Webhook sync failed for {}", id, e);
- Cause: Expired or invalid OAuth token, or missing
speech:transcript:readscope. - Fix: Verify the client credentials match a confidential application. Ensure the token cache refreshes before expiration. The
GenesysAuthManagerclass implements automatic refresh logic. - Code Fix: Check
TokenResponse.isExpired()before API calls. Revoke and regenerate the client secret if rotated.
Error: 403 Forbidden
- Cause: The OAuth application lacks the
speech:transcript:readscope, or the requesting identity lacks organizational permissions for Speech Analytics. - Fix: Navigate to the developer console, edit the application, and add
speech:transcript:read. Assign the calling user to a role with Speech Analytics access.
- Cause: Exceeding the platform rate limit for the
/api/v2/analytics/speech/transcripts/details/queryendpoint. - Fix: Implement exponential backoff. The
executeWithRetrymethod includes a 429 handler that sleeps and retries up to three times. Reduce batch sizes if cascading 429s occur.
Error: 400 Bad Request (Schema Validation)
- Cause: Invalid transcript ID format, exceeding maximum query size, or malformed filter structure.
- Fix: Validate IDs against UUID v4 format before submission. Enforce
size <= 10000. EnsurefilterTypematchesTranscriptDetailsQueryFilterType.ID.
- Cause: Alignment engine constraints violated, such as requesting unsupported precision thresholds or corrupted audio metadata.
- Fix: Keep
precisionMsbetween 1 and 100. Verify audio files are fully processed before extraction. Retry after a brief delay to allow backend indexing to complete.
