Exporting Genesys Cloud Flow Definitions via the Flow API with Node.js
A Node.js module that exports Genesys Cloud Flow definition JSON, validates structure against engine constraints, verifies asset availability, tracks latency, generates audit logs, and synchronizes exports with external version control systems via webhooks. This tutorial uses the Genesys Cloud Flow API and the official Node.js SDK for authentication. The implementation covers modern JavaScript with axios for precise HTTP control.
- OAuth Client Credentials grant type with scopes:
flow:export,flow:read - Genesys Cloud region endpoint (e.g.,
https://api.mypurecloud.com) - Node.js 18 or later
- Dependencies:
npm install genesys-cloud-purecloud-platform-client axios uuid - Access to a Flow ID and optional version tag
Genesys Cloud OAuth 2.0 requires a client credentials flow for server-to-server integrations. The official SDK handles token acquisition and caching automatically. You must instantiate the AuthApi with your client ID, secret, and region. The SDK caches the access token and refreshes it before expiration.
const { AuthApi, PlatformClient } = require('genesys-cloud-purecloud-platform-client');
const GENESYS_REGION = 'https://api.mypurecloud.com';
const CLIENT_ID = process.env.GENESYS_CLIENT_ID;
const CLIENT_SECRET = process.env.GENESYS_CLIENT_SECRET;
async function initializeAuthClient() {
const authApi = new AuthApi();
await authApi.clientCredentialsLogin(CLIENT_ID, CLIENT_SECRET, [
'flow:export',
'flow:read'
const platformClient = new PlatformClient();
const token = platformClient.authClient.getAccessToken();
axiosInstance: axios.create({
baseURL: GENESYS_REGION,
headers: {
Authorization: `Bearer ${token}`,
'Accept': 'application/json'
refreshToken: async () => {
await authApi.clientCredentialsLogin(CLIENT_ID, CLIENT_SECRET, ['flow:export', 'flow:read']);
const newToken = platformClient.authClient.getAccessToken();
axiosInstance.defaults.headers.Authorization = `Bearer ${newToken}`;
Step 1: Construct Export Request and Execute Atomic GET
The Flow Export API uses a GET request at /api/v2/flows/{flowId}/export. You must pass includeDependencies=true to bundle referenced assets, format=json for structured output, and optionally specify a version tag. The request is atomic and returns the complete flow definition. You must implement retry logic for HTTP 429 responses to handle rate limiting.
const MAX_RETRIES = 3;
const RETRY_DELAY_MS = 1000;
async function fetchFlowDefinition(axiosInstance, flowId, version = null) {
const params = {
includeDependencies: true,
format: 'json',
version: version || undefined
let attempt = 0;
let response;
while (attempt <= MAX_RETRIES) {
response = await axiosInstance.get(`/api/v2/flows/${flowId}/export`, { params });
break;
} catch (error) {
if (error.response && error.response.status === 429) {
attempt++;
const retryAfter = error.response.headers['retry-after']
? parseInt(error.response.headers['retry-after'], 10)
: RETRY_DELAY_MS;
console.log(`Rate limited (429). Retrying attempt ${attempt}/${MAX_RETRIES} after ${retryAfter}ms.`);
await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
continue;
throw error;
if (attempt > MAX_RETRIES) {
throw new Error('Export failed after maximum retry attempts due to rate limiting.');
return response.data;
Step 2: Validate Export Schema and Enforce Size Limits
Genesys Cloud enforces a maximum export size (approximately 5 MB) and expects a specific JSON structure. You must verify the response size before parsing and validate required schema fields. The flow definition must contain version, type, initialEntityId, and entities. Missing fields indicate a corrupted or unsupported export.
const MAX_EXPORT_SIZE_BYTES = 5 * 1024 * 1024; // 5 MB
function validateExportSchema(rawData, flowId) {
// Check raw size before JSON parsing
const byteSize = Buffer.byteLength(JSON.stringify(rawData), 'utf8');
if (byteSize > MAX_EXPORT_SIZE_BYTES) {
throw new Error(`Export exceeds maximum size limit: ${byteSize} bytes. Consider splitting dependencies or reducing flow complexity.`);
const requiredFields = ['version', 'type', 'initialEntityId', 'entities'];
const missingFields = requiredFields.filter(field => !(field in rawData));
if (missingFields.length > 0) {
throw new Error(`Invalid flow definition schema. Missing required fields: ${missingFields.join(', ')}`);
if (typeof rawData.entities !== 'object' || Array.isArray(rawData.entities)) {
throw new Error('Flow definition "entities" must be a non-array object mapping entity IDs to definitions.');
return rawData;
Step 3: Implement Circular Reference and Asset Availability Checks
Flow definitions may contain cross-references between entities. Circular references cause serialization failures during downstream processing. You must traverse the entity graph to detect cycles. Additionally, you must verify that all referenced assets exist and are accessible. The verification pipeline checks internal entity references and flags missing external dependencies.
function detectCircularReferences(flowDefinition) {
const seen = new Set();
const stack = new Set();
function traverse(entityId) {
if (stack.has(entityId)) {
throw new Error(`Circular reference detected in flow definition at entity: ${entityId}`);
if (seen.has(entityId)) return;
seen.add(entityId);
stack.add(entityId);
const entity = flowDefinition.entities[entityId];
if (!entity) {
stack.delete(entityId);
return;
// Traverse common reference fields in Genesys flows
const referenceFields = ['nextEntityId', 'trueEntityId', 'falseEntityId', 'entityId', 'queueId', 'scriptId'];
for (const field of referenceFields) {
if (entity[field]) {
traverse(entity[field]);
// Handle arrays of references
if (entity.actionConfig && Array.isArray(entity.actionConfig)) {
entity.actionConfig.forEach(action => {
if (action.entityId) traverse(action.entityId);
// Start traversal from initial entity
traverse(flowDefinition.initialEntityId);
function verifyAssetAvailability(flowDefinition) {
const entityIds = Object.keys(flowDefinition.entities);
const missingAssets = [];
// Check all referenced IDs exist in the exported entities
const referencedIds = new Set();
for (const entityId of entityIds) {
const refFields = ['nextEntityId', 'trueEntityId', 'falseEntityId', 'queueId', 'scriptId', 'ivrId'];
refFields.forEach(field => {
if (entity[field]) referencedIds.add(entity[field]);
for (const refId of referencedIds) {
if (!entityIds.includes(refId)) {
missingAssets.push(refId);
if (missingAssets.length > 0) {
console.warn(`Asset availability warning: ${missingAssets.length} referenced IDs not found in export. Verify dependencies or include missing assets.`);
return { verified: true, missingAssets };
Step 4: Webhook Synchronization, Metrics, and Audit Logging
Export completion must trigger synchronization with external version control systems. You will POST the validated JSON to a configurable webhook URL. The module tracks export latency, validates JSON integrity, and generates structured audit logs for governance compliance.
const { v4: uuidv4 } = require('uuid');
async function exportFlow(axiosInstance, flowId, version, webhookUrl) {
const exportStartTime = Date.now();
const exportId = uuidv4();
const auditLog = {
exportId,
flowId,
version: version || 'latest',
status: 'started',
latencyMs: 0,
jsonValid: false,
sizeBytes: 0,
errors: []
// Step 1: Fetch
const rawData = await fetchFlowDefinition(axiosInstance, flowId, version);
auditLog.sizeBytes = Buffer.byteLength(JSON.stringify(rawData), 'utf8');
// Step 2: Validate Schema & Size
const validatedData = validateExportSchema(rawData, flowId);
auditLog.jsonValid = true;
// Step 3: Circular Reference Check
detectCircularReferences(validatedData);
// Step 4: Asset Verification
const assetCheck = verifyAssetAvailability(validatedData);
if (assetCheck.missingAssets.length > 0) {
auditLog.errors.push(`Missing assets: ${assetCheck.missingAssets.join(', ')}`);
// Step 5: Webhook Sync
if (webhookUrl) {
await axios.post(webhookUrl, {
exportId,
flowId,
version: validatedData.version,
definition: validatedData,
metadata: auditLog
timeout: 10000
auditLog.webhookSynced = true;
auditLog.status = 'completed';
auditLog.latencyMs = Date.now() - exportStartTime;
console.log(`[AUDIT] Export ${auditLog.status}: ${JSON.stringify(auditLog)}`);
return { data: validatedData, audit: auditLog };
} catch (error) {
auditLog.status = 'failed';
auditLog.errors.push(error.message);
console.error(`[AUDIT] Export failed: ${JSON.stringify(auditLog)}`);
throw error;
The following script combines authentication, export execution, validation, and webhook synchronization into a single runnable module. Replace environment variables with your credentials and webhook endpoint.
const FLOW_ID = process.env.TARGET_FLOW_ID;
const WEBHOOK_URL = process.env.EXPORT_WEBHOOK_URL;
const FLOW_VERSION = process.env.FLOW_VERSION || null;
headers: {
async function fetchFlowDefinition(axiosInstance, flowId, version) {
const params = {
format: 'json',
let attempt = 0;
const response = await axiosInstance.get(`/api/v2/flows/${flowId}/export`, { params });
} catch (error) {
attempt++;
: RETRY_DELAY_MS;
continue;
throw error;
function validateExportSchema(rawData) {
throw new Error(`Export exceeds maximum size limit: ${byteSize} bytes.`);
throw new Error('Flow definition "entities" must be a non-array object.');
return rawData;
if (stack.has(entityId)) throw new Error(`Circular reference detected at entity: ${entityId}`);
seen.add(entityId);
if (!entity) { stack.delete(entityId); return; }
const refFields = ['nextEntityId', 'trueEntityId', 'falseEntityId', 'entityId', 'queueId', 'scriptId'];
refFields.forEach(field => { if (entity[field]) traverse(entity[field]); });
entity.actionConfig.forEach(action => { if (action.entityId) traverse(action.entityId); });
['nextEntityId', 'trueEntityId', 'falseEntityId', 'queueId', 'scriptId', 'ivrId'].forEach(field => {
const missingAssets = Array.from(referencedIds).filter(id => !entityIds.includes(id));
console.warn(`Asset availability warning: ${missingAssets.length} referenced IDs not found in export.`);
async function runExport() {
console.log('Initializing Genesys Cloud authentication...');
const { axiosInstance } = await initializeAuthClient();
const auditLog = {
exportId,
flowId: FLOW_ID,
version: FLOW_VERSION || 'latest',
status: 'started',
latencyMs: 0,
jsonValid: false,
sizeBytes: 0,
errors: []
console.log(`Fetching flow definition for ID: ${FLOW_ID}`);
const rawData = await fetchFlowDefinition(axiosInstance, FLOW_ID, FLOW_VERSION);
console.log('Validating export schema and size constraints...');
const validatedData = validateExportSchema(rawData);
console.log('Checking for circular references...');
console.log('Verifying asset availability...');
if (WEBHOOK_URL) {
console.log(`Synchronizing with external version control via webhook: ${WEBHOOK_URL}`);
await axios.post(WEBHOOK_URL, {
exportId,
flowId: FLOW_ID,
metadata: auditLog
timeout: 10000
console.log(`[AUDIT] Export completed: ${JSON.stringify(auditLog)}`);
console.log('Flow definition successfully exported and validated.');
} catch (error) {
process.exit(1);
runExport().catch(err => {
console.error('Unhandled error during export:', err);
process.exit(1);
Error: HTTP 401 Unauthorized
Cause: The OAuth token expired or the client credentials are invalid.
Fix: Ensure the SDK refreshes the token before making requests. The provided code caches the token via PlatformClient. If running long-lived processes, implement a token refresh middleware that calls authApi.clientCredentialsLogin when response.status === 401.
Error: HTTP 403 Forbidden
Cause: The OAuth client lacks the flow:export scope, or the service account does not have the necessary Flow permissions in the Genesys Cloud admin console.
Fix: Grant the flow:export scope to the OAuth client. Assign the service account the “Flow Builder” or “Flow Admin” role. Verify permissions via /api/v2/oauth/clients/{clientId}.
Cause: The export operation exceeds the platform rate limit, especially when includeDependencies=true triggers multiple internal lookups.
Fix: The retry logic in fetchFlowDefinition handles 429 responses by parsing the Retry-After header. If cascading failures occur, implement exponential backoff and stagger export requests across multiple Flow IDs.
Error: Export Exceeds Maximum Size Limit
Cause: The flow definition exceeds 5 MB due to embedded dependencies, large IVR scripts, or complex routing configurations.
Fix: Disable includeDependencies if downstream systems can resolve references independently. Split monolithic flows into modular sub-flows. Use the version parameter to export a smaller historical version if available.
Error: Circular Reference Detected
Cause: Entities reference each other in a loop (e.g., Entity A routes to Entity B, which routes back to Entity A). The flow engine allows this at runtime, but JSON serialization fails during export validation.
Fix: Review the flow topology in the Genesys Cloud UI or analyze the entities map. Break cycles by introducing an intermediate decision node or using a queue as a buffer. The validation function throws immediately to prevent corrupted payloads.
